    Applied change to config.txt, MM fails to boot.
    13 Posts 5 Posters 7.5k Views 6 Watching
      Richard238
      Update to 2.4.0, and made the sudo nano /boot/config.txt dtoverlay=vc4-kms-v3d change.
      Shut down Pi, powered Pi back on, and now fails to boot, showing just a cursor top left of monitor.
        Richard238
        Comment out the dtoverlay=vc4-kms-v3d change, and Pi boots, MM starts OK.
        Does it matter where in config.txt that the new line is placed?
          Richard238
          Or…, is it best to use the sudo raspi-config /Advanced/… route?
            JoeFranz
            Did you remove these entries in the config.txt?
            display_rotate = 1
            avoid_warnings = 1
              Richard238
              display_rotate = 1 - is commented out (I’m happy with MM in landscape mode)
              avoid_warnings = 1 - line doesn’t exist.
                mochman Module Developer
                I had the same issue. I changed dtoverlay=vc4-kms-v3d to dtoverlay=vc4-fkms-v3d and was able to boot up again.
                  Richard238
                  That doesn’t work for me, MM boots to a few lines about blocks, then nothing else.
                  • MichMichM Offline
                    MichMich
                    Did you try the rasps-config tool to configure the GL driver?
                      Richard238
                      No, because if that kills it, I don’t know how to bring it back - what file to edit etc…?
                      MichMichM 1 Reply Last reply Reply Quote 0
                      • MichMichM Offline
                        MichMich @Richard238
                        @richard238 It just modifies the config.txt for you in a save way. There is a bigger chance of you killing your pi doing it manually than using the config tool.
                          Richard238
                          Ok, when I get time, I’ll create a backup of the MM SD card first, and then try the GUI config tool.
                          Thanks.
                            Sun
                            Mine installation was successful.
                            First I update rp3
                            #sudo apt-get update
                            #sudo apt-get upgrade
                            #cd MagicMirror/
                            #git pull && npm install
                            #cd
                            #sudo nano /boot/config.txt (add in config.txt and save)
                            display_rotate=1
                            #sudo raspi-config
                            Advanced Options
                            GL Driver
                            G1 GL (Full KMS) OpenGL desktop driver with full KMS
                            #sudo reboot
                            ***I cannot remeber if I did this process or not
                            #sudo nano ~/.config/lxsession/LXDE-pi/autostart
                            @xrandr --output HDMI-1 --rotate right (add to autostart)
                              Richard238
                              Done through raspi-config, seems ok, boots and runs fine.
                              sudo vcgencmd measure_temp
                              shows 56.9C
