    MMM-GooglePhotos
    294 Posts 56 Posters 371.2k Views 59 Watching
      sdetweil @roccodicarlo
      @roccodicarlo ok, then the token tool won’t work…
      are u doing the cli on purpose?
      • ? Offline
        A Former User
        Copy url and open browser in other pc. Do the process then return to your rpi.
          roccodicarlo
          ok I will try. The reason I am doing cli was because with desktop gui, I found it very sluggish on the rpi zero.
          ? 1 Reply Last reply Reply Quote 1
          • ? Offline
            A Former User @roccodicarlo
            @roccodicarlo
            I’m worrying, your node version has to be ^8.3 at least.
              roccodicarlo
              My node version is 10.16…so it should be ok
              • P Offline
                philmavedzenge
                @Sean i really like this module and have been using it for sometime now. I have noticed with the new update that there is a padding of about 10px around the screen. Is there a way of removing that? I use my screen in landscape mode only. Thanks in advance
                • P Offline
                  philmavedzenge @philmavedzenge
                  @philmavedzenge said in MMM-GooglePhotos:
                  @Sean nevermind, i fixed it in custom.css
                  • G Offline
                    gonzonia @Guest
                    @Sean Awesome work! Loving the update!
                      Samwise
                      Hey, so i’m not sure what this means, but it happens whenever I try to start it:
                      pi@sam-raspberrypi:~/MagicMirror $ npm start
                      magicmirror@2.7.1 start /home/pi/MagicMirror
                      sh run-start.sh
                      /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
                      npm ERR! file sh
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno ENOENT
                      npm ERR! syscall spawn
                      npm ERR! magicmirror@2.7.1 start: sh run-start.sh
                      npm ERR! spawn ENOENT
                      npm ERR!
                      npm ERR! Failed at the magicmirror@2.7.1 start script.
                      npm ERR! /home/pi/.npm/_logs/2020-04-02T05_53_17_399Z-debug.log
                      S ? S 3 Replies Last reply Reply Quote 0
                        Samwise @Samwise
                        also, the auto start script doesn’t seem to work either
                        • ? Offline
                          A Former User @Samwise
                          @Samwise said in MMM-GooglePhotos:
                          npm ERR! file sh
                          That seems not related to module itself. Your environment seems missing some dependency.
                          Try to this.
                          sudo apt-get install libgconf-2-4
                            sdetweil @Samwise
                            libgconf-2.so.4:
                            try this from a terminal window
                            magicmirror@2.7.1
                            version 2.7.1 is pretty old…
                            edit the package.json file and change
                            "start","sh run-start.sh"
                            to
                            "start"."sh ./run-start.sh"
                            check to see if run-start.sh is in the ~/MagicMirror folder, if not then do
                            cd ~/MagicMirror
                            cule -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >run-start.sh
                            chmod +x run-start.sh
                            • G Offline
                              gonzonia
                              The new info box is not aligning correctly for me. It’s showing mostly off the screen.
                              Screenshot
                              • ? Offline
                                A Former User @gonzonia
                                @gonzonia
                                Show me your configuration of MMM-GooglePhotos.
                                G 2 Replies Last reply Reply Quote 0
                                • O Offline
                                  orayoflighto Project Sponsor
                                  I just updated to the latest And my photos stopped displaying. Anyone else have this issue?
                                  I just get Loading…
                                  S Z O 3 Replies Last reply Reply Quote 0
                                    sdetweil @orayoflighto
                                    @orayoflighto open the developers window ctrl-shift-i on the keyboard, select the console tab and scroll up for any errors
                                    did u also run npm install in the MMM-GooglePhotos folder?
                                    • G Offline
                                      gonzonia @Guest
                                      @Sean I commented out autoInfoPosition because it seemed to break when I turned that on. The showWidth/showHeight match the screen resolution showing on the dekstop.
                                        			module: "MMM-GooglePhotos",
                                      			position: "fullscreen_below",
                                      			albums: ["NixPlay","MM-Family2"], // Set your album name. like ["My wedding", "family share", "Travle to Paris"]
                                      			updateInterval: 1000 * 60, // minimum 10 seconds.
                                      			sort: "random", // "old", "random"
                                      			uploadAlbum: null, // Only album created by `create_uploadable_album.js`.
                                      			condition: {
                                      				fromDate: null, // Or "2018-03", RFC ... format available
                                      				toDate: null, // Or "2019-12-25",
                                      				minWidth: null, // Or 400
                                      				maxWidth: null, // Or 8000
                                      				minHeight: null, // Or 400
                                      				maxHeight: null, // Or 8000
                                      				minWHRatio: null,
                                      				maxWHRatio: null,
                                      				// WHRatio = Width/Height ratio ( ==1 : Squared Photo,   < 1 : Portraited Photo, > 1 : Landscaped Photo)
                                      			showWidth: 1680, // These values will be used for quality of downloaded photos to show. real size to show in your MagicMirror region is recommended.
                                      			showHeight: 1050,
                                      			timeFormat: "relative", //"YYYY/MM/DD HH:mm", // Or `relative` can be used.
                                      			//autoInfoPosition: true,
                                      • K Offline
                                        Kevinho195
                                        Hi @Sean,
                                        thanks for the great update. I want to hide the blurred background and did add
                                        GPHOTO_BACK {
                                        	display:none;
                                        #GPHOTO_INFO {
                                        	display:none;
                                        to my custom.css but it the blurred background is still there. For the info tab it did work and it disappeared. What am I missing?
                                        • ? Offline
                                          A Former User @Kevinho195
                                          @Kevinho195
                                          You’ve missed #
                                          • G Offline
                                            gonzonia @Guest
                                            @Sean Any idea what’s going on with the info box?
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
