    change current weather colors - time and wind
    16 Posts 5 Posters 18.9k Views 5 Watching
    • K
      karde
      Have successfully changed all desired colors on “current weather” module thanks to Anachors post (https://forum.magicmirror.builders/topic/351/add-a-background-image), but haven’t been able to change wind speed text and sunrise / sunset time, does anyone know how to do this in custom.css :(, thanks!
      What I wan’t to change is the “1.5” and “21:38” (and the sunrise time as well) in the below picture:
      THANKS for all/any help! :)
      • P
        pugsly
        Not sure about the Wind stuff but I did want the sunrise/sunset to change so here is the code for your custom.css for that.
        .wi.dimmed.wi-sunset {
        color: orange;
        .wi.dimmed.wi-sunrise {
        color: yellow;
        • K
          karde
          Thanks for your help!!
          But that’s for the icon right? I’m trying to change the texts, “1.5” and “21:38”, but thanks for your help!
          cowboysdudeC P strawberry 3.141S 3 Replies Last reply Reply Quote 0
          • cowboysdudeC
            cowboysdude Module Developer @karde
            @karde said in change current weather colors - time and wind:
            Still done through the custom.css… not sure what they are as I use a different module for weather.
            • P
              pugsly @karde
              @karde I know its .normal in main.css but I do not know how to make it only change color for only one module. if you change .normal it will be for everything that uses .normal.
              Is that even possible that you do a .module.normal {color:blue;} in your custom.css. Even so you would be changing all the text in that module, as there is no ‘code’ for just that one section.
              Im no programer, so no clue. I only just figured out how to do the icons recently.
              • cowboysdudeC
                Hey @pugsly any help is good help!
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @karde
                  @karde I’m assuming you’re using this module https://github.com/RedNax67/MMM-WunderGround
                  due to the sunset and sunrise time is a span element and the following sibling of the icon you can apply this css rule in custom.css
                  .wi.dimmed.wi-sunrise + span, .wi.dimmed.wi-sunset + span {
                      color: orange;
                  • K
                    karde
                    THANKS YOU @pugsly and @cowboysdude!!!
                    You guys are great!! Thanks for all your help!
                    I got the text next to the wind icon to work as well, with:
                    .dimmed.wi-strong-wind + span {
                    color: #FFFFFF;
                    But… I missed one thing in my picture, you also have a wind direction next to the windspeed, say: “1.5 VNV”, anyone know who to change the “VNV” as well, couldn’t get it to work…:(
                    • strawberry 3.141S
                      @karde could you share your modules config i can’t get the same result as your screenshot in the first post. don’t forget to remove your api_key before posting
                      • K
                        karde @strawberry 3.141
                        @strawberry-3.141 I’ll be happy to!
                        But, to be honest, the picture I have included in the post isn’t my actual mirror, I’ve sent you a private message :)!
                        • strawberry 3.141S
                          @karde this is for the default module currentweather and not as I thought MMM-WunderGround
                          /* wind speed selector */
                          .currentweather > .module-content > div > div.normal.medium > *:nth-child(2),
                          /* wind direction selector */
                          .currentweather > .module-content > div > div.normal.medium > *:nth-child(3),
                          /* sunset/sunrise time selector */
                          .currentweather > .module-content > div > div.normal.medium > *:nth-child(6){
                              color: orange;
                          • K
                            karde
                            THANK YOU! And thanks everyone for all your time, I really appreciate it - alot!!!
                              A Former User
                              2_1477687812010_Screenshot 2016-10-29 03.45.42.png 1_1477687812010_Screenshot 2016-10-29 03.45.36.png 0_1477687812008_Screenshot 2016-10-29 03.45.31.png
                              Does anyone know where the CSS is managed for these Icons so can edit the colours?
                              Also has anyone done this already? and is there anything that needs special attention when doing?
                              Guessing custom CSS against
                              “01d”: “wi-day-sunny”,
                              “02d”: “wi-day-cloudy”,
                              “03d”: “wi-cloudy”,
                              “04d”: “wi-cloudy-windy”,
                              “09d”: “wi-showers”,
                              “10d”: “wi-rain”,
                              “11d”: “wi-thunderstorm”,
                              “13d”: “wi-snow”,
                              “50d”: “wi-fog”,
                              “01n”: “wi-night-clear”,
                              “02n”: “wi-night-cloudy”,
                              “03n”: “wi-night-cloudy”,
                              “04n”: “wi-night-cloudy”,
                              “09n”: “wi-night-showers”,
                              “10n”: “wi-night-rain”,
                              “11n”: “wi-night-thunderstorm”,
                              “13n”: “wi-night-snow”,
                              “50n”: “wi-night-alt-cloudy-windy”
                                A Former User @Guest
                                @wjdw87 said in change current weather colors - time and wind:
                                “03d”: “wi-cloudy”,
                                “10d”: “wi-rain”,
                                “13d”: “wi-snow”,
                                “50d”: “wi-fog”,
                                Yep some, getting there slowly…0_1477689106951_Screenshot 2016-10-29 04.10.57.png
                                body {
                                color: orange;
                                color: yellow;
                                .wi-day-sunny {
                                color: yellow;
                                .wi-day-cloudy {
                                color: yellow;
                                .wi-rain {
                                color: grey;
                                .wi-thunderstorm {
                                color: grey;
                                .wi-snow {
                                color: white;
                                .wi-fog {
                                color: white;
                                .wi-night-clear {
                                color: white;
                                .wi-night-cloudy {
                                color: grey;
                                .wi-night-showers {
                                color: blue;
                                .wi-night-rain {
                                color: blue;
                                .wi-thunderstorm {
                                color: yelow;
                                .wi-night-snow {
                                color: white;
                                .wi-night-alt-cloudy-windy {
                                color: grey;
                                • K
                                  karde
                                  I’m no expert on CSS, got my information from @Anachor’s post:
                                  https://forum.magicmirror.builders/topic/356/change-currentweather-colors,
                                  But you seem to have the hang on it, not sure if it helps you, but look in:
                                  ~/MagicMirror/modules/default/currentweather/ and do a grep in the .js file:
                                  cat currentweather.js | grep wi-
                                  To find out what the icons look at/represent, look at:
                                  https://erikflowers.github.io/weather-icons/
                                  I have also done some of this with the following code:
                                  #module_4_currentweather header {
                                  color: #FFFFFF;
                                  border-bottom: 1px solid #FFFFFF;
                                  #module_4_currentweather .wi-sunrise {
                                  color: #F2E791;
                                  Not sure what’s best, the module number is from your config.js file and the module_4 is the just module number from your config file, the fourth module.
                                  But like I said, might be some better way to do things, but It works for me :).
                                    A Former User
                                    Many thanks, actually just removed CW in exchange for WeatherUnderground (feed directly from the property and API’d down) so more realistic for us.
                                    Got to do the colours there next, for the icons, currently having troubles with the “C” instead of Celsius symbol :/
