Navigation
    • Search
    MagicMirror² v2.15.0 is available! For more information about this release, check out this topic.
    MMM-WunderGround Icon missing
    Troubleshooting
    1576
    • V
      vanhoekd 0 Module Developer last edited by
      Hi all,
      There seems to be a icon missing in the MMM-Wunderground module.
      It appeares again after i change the color option from true to false or the other way around, but only for some minutes.
      Is there a way to fix it?
      • A
        Arjan Project Sponsor last edited by
        Same here. I believe there was an update a few days ago and after that the problem started.
        • P
          Peter last edited by
          Same here.
          Sometimes it is back for a while.
          But most of the time it is gone …
          Peter
          • C
            clemy last edited by
            Same problem over here
            • C
              Now the module is not loading at all. Anyone the same problem?
              • T
                trividar last edited by
                Same issue with missing icons. Do anyone know how to see which icons are missing? @RedNax can you help us?
                Mykle1 1 Reply Last reply Reply Quote 0
                • Mykle1
                  Mykle1 Project Sponsor Module Developer @trividar last edited by
                  @trividar
                  RedNax profile “LAST ONLINE ABOUT A YEAR AGO”
                  • T
                    thobach last edited by
                    I also had this issue with MMM-WunderGround24Hours for about the last 2 days, but now it works again on that module after a refresh.
                    • Mykle1
                      Mykle1 Project Sponsor Module Developer @thobach last edited by
                      @thobach
                      It could be the data from the WunderGround API was bad. That would mess up the module.
                      • T
                        Please note this module was migrated to use the Dark Sky API and is now available as “MMM-DarkSky24Hours” under https://github.com/thobach/MMM-DarkSky24Hours.
