    Calendar Module +1 day Error
    14 Posts 7 Posters 12.0k Views 7 Watching
      StrIIker
      Hi! My Magic Mirror is showing that Halloween is in a month and then lists Nov 01 next to it (this is from the US Holidays calendar). Also other dates are offset by +1 day. Also, when I added an additional calendar, it’s showing incorrect dates for events… Is this a known ongoing bug? Any alternative calendar modules I should consider?
        StrIIker
        Please see an example of what I am seeing. Columbus day is on the 8th (not 9th), Haloween is on October 31 (not November 01) and the rest of the listed dates are wrong too… When I added a calendar with birthdays, I also was seeing a similar error so I removed it to see if this was the cause. My Pi’s clock is set to the correct timezone. Any advice around this would be greatly appreciated. It wasn’t doing this until recently and the only thing I had done was to add the birthday calendar (which I removed).
        I have tried reloading the modules, quitting and restarting magic mirror and rebooting the Pi. All to no avail.
          sdetweil
          What is the system time one set to?
          Where are u located?
            StrIIker @sdetweil
            @sdetweil said in Calendar Module +1 day Error:
            I am in New York / Eastern time zone. System time is set to Eastern / New York.
            I installed the MMM-MyCalendar module and it’s working with correct dates etc. I’d prefer to use the default one though.
            Current default time zone: ‘America/New_York’
            Local time is now: Wed Oct 3 16:09:57 EDT 2018.
            Universal Time is now: Wed Oct 3 20:09:57 UTC 2018.
            • N Offline
              Nilnik Project Sponsor
              Hi! If you put showEnd: false, in your config for calendar solves the problem.
              Oct 9th is and nov 1st when it ends.
                StrIIker @Nilnik
                @nilnik said in Calendar Module +1 day Error:
                Hi! I did try this and restarted. The problem persists. I placed that value in two locations… The config for the module and the config for the calendar. Neither has any impact. I also did not see this option mentioned in the GitHub documentation. Perhaps it’s an old value which was retired? Your observation does seem valid. I just wonder why it’s stuck in this mode for me.
                                        "module": "calendar",
                                        "header": "Calendar",
                                        "position": "top_left",
                                        "showEnd": "false",
                                        "config": {
                                                "calendars": [
        "symbol": "calendar-check-o ",
        "url": "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
        showend: "false",
        "color": "#FFFFFF"
                • N Offline
                  Hello again!
                  I Think that you shouldn’t put quotes rond false
                  Here is my config:
                  module: ‘calendar’,
                  header: ‘Kalender, Helg-och födelsedagar’,
                  position: ‘top_left’,
                  colored: true,
                  timeFormat: ‘absolute’,
                  maximumEntries: 12,
                  urgency: 2,
                  dateFormat: ‘Do MMM’,
                  fullDayEventDateFormat:‘Do MMM’,
                  showEnd: false,
                  getRelative: 48,
                  S 1 Reply Last reply Reply Quote 2
                    StrIIker @Nilnik
                    Hello again!
                    Here is my config:
                    module: ‘calendar’,
                    colored: true,
                    maximumEntries: 12,
                    urgency: 2,
                    showEnd: false,
                    getRelative: 48,
                    Hi! That did it! Thank you for your patience and help! I greatly appreciate the help and will certainly help others whenever I can.
                    To get this issue resolved, I had to include the showEnd value AND set the timeFormat to absolute as you have. Now my calendar displays the date correctly…
                    • N Offline
                      Glad to help. Have a nice weekend
                      • F Offline
                        felafel
                        Edit: I thought I had this problem but I put
                        			timeFormat: 'absolute',
                        			showEnd: false,
                        in the wrong section. Once I put it in the config it worked.
                          Blackmirror
                          Hello,
                          I have the same problem, but this fix will not solve my problem.
                                                  module: 'calendar',
                                                  classes: 'default everyone',
                                               //   header: 'Termine',
                                                  position: 'top_right',
        url: 'https://calendar.google.com/calendar/XXX',
        symbol: 'calender',
        colored: true,
        displayRepeatingCountTitle: 'Birthday',
        maximumEntries: 5,
        dateFormat: 'DD MMM',
        fullDayEventDateFormat:'DD MMM',
        showEnd: false,
        getRelative: 48,
        urgency: 2
                          And the chance from the date will not work.
                          The Date shows : Dec 8 and not 8 Dec.
                          Blackmirror
                          • Y Offline
                            yawns Moderator
                            It is a bit irritating where to put the config stuff. Some needs to go to config section directly, some need to go to the calendars section.
                            Please try this:
                            	module: 'calendar',
                            		displayRepeatingCountTitle: true,
                            		showEnd: false,
                            		getRelative: 48,
                            		urgency: 2,
                            				symbol: 'calender',
                            				colored: true,
                            				maximumEntries: 5,
                            				repeatingCountTitle: 'Birthday'
                              Blackmirror
                              Thanks. It’s work fine
                                Joerg633
                                Hello again,
                                i still have the same problem with goggle calendar fullday entries.
                                For example an entry for 2 fulldays (01/19-01/20) will be:
                                ics data from the google calendar link:
                                DTSTART;VALUE=DATE:20190119
                                DTEND;VALUE=DATE:20190121
                                So the module shows
                                So i check all timezone / language etc. settings, in MM, modules section and raspi settings with no success.
                                Calendar views in google calendar webpage, android calendar apps and also outlook 365 are correct (2 days not 3).
                                my config
                                		module: 'calendar',
                                		header: 'Familienkalender',
                                		position: 'bottom_left',
                                			maximumEntries: 13,
                                			displaySymbol: false,
                                			maxTitleLength: 24,
                                			fade: true,
                                			fadePoint: 0.7,
                                			fullDayEventDateFormat: 'Do MM k:mm',
                                			dateFormat: 'Do MMM k:mm',
                                			urgency: 0,
                                			colored: false,
                                			coloredSymbolOnly: true,
                                					url: 'https://calendar.google.com/calendar/ical/.../basic.ics'
                                Thanks for any hint
                                Joerg
