    MMM-NewsFeedTicker
    94 Posts 15 Posters 88.5k Views 14 Watching
    • G Offline
      Giarry88 @sdetweil
      @sdetweil said in MMM-NewsFeedTicker:
      @Giarry88 sounds like u didn’t install the module in the right place
      I’ve nstalled it in the Modules folders (outside of the Default folder, correct?)
        sdetweil @Giarry88
        @Giarry88 :8080/modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        says file not there
        you can get rid of this one by creating an empty custom.css (my installation script does this)
        :1 Refused to apply style from ‘http://localhost:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled
        touch ~/MagicMirror/css/custom.css
        • G Offline
          Giarry88 @sdetweil
          says file not there
          so…
          I created the custom.css (but I’ve added the command for removing the borders, because I had it in the main.css - yes…i know…my bad :grimacing_face: - also it seems I can’t remove the spacing at the top, but this is a ittle bit OT) now as you said it previously that error disappeared.
          Now I have only
          Load script: modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js
          GET http://localhost:8080/modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js net::ERR_ABORTED 404 (Not Found)
          Error on loading script: modules/MMM-NewsFeedTicker//MMM-NewsFeedTicker.js
          But this morning I’ve installed an other module (MMM-networrk-signal) in the same way and it is working properly
          Load script: modules/MMM-network-signal//MMM-network-signal.js
          Module registered: MMM-network-signal
          I am confused…
          EDIT
          My mistake was that I didn’t put capital letters in the name of the folder (I didn’t think it would have mattered)…
          Now I can see the red bar with “Loading” and in the console it keeps showing :
          MMM-NewsFeedTicker - unknown notification, ignoring: CLOCK_SECOND
          MMM-NewsFeedTicker - received notification: CLOCK_SECOND
            sdetweil @Giarry88
            @Giarry88 said in MMM-NewsFeedTicker:
            linux is case sensitive… windows is not
            look in the console where u start ed MagicMirror
            if pm2, the use the pm2 logs --lines=100 command to view the logs…
            the error more than likely is a bad url, ???
            • G Offline
              Giarry88 @sdetweil
              I don’t know why, when I closed and Opened again Magic Mirror, it wasn’t working at all; so I started with the backup of the config file and now it is working everything, ticker included. I think that I just needed to remove the default feed (especially the url - I was asking him to load the same feed on both modules -).
              Now I only have an issue with the stuttering ticker (but I’ve read something about it so I will try solving it by looking at those posts).
              Thanks again sdetweil, especially for your patience!
              • L Offline
                liquidevo
                Hi love the module can anyone help me out ? I want each of the headlines to be longer sometimes it cuts the headline midway so I cannot read completly , and also anyone knows if I can add the qr code to this module ?
                thank you
                • Cr4z33C Offline
                  Cr4z33
                  @justjim1220 I’ve moved to a NUC and your module is now scrolling incredibly smooth. :D
                  Only can you please tell me what to edit to avoid scrolling from right to left (after having scrolled from left to right)?
                  • Cr4z33C Offline
                    Cr4z33 @Cr4z33
                    @Cr4z33 said in MMM-NewsFeedTicker:
                    @BKeyport sorry for always bothering you lol, but you look still quite active here in the forums (despite of other developers that might have left). :)
                    Do you know by chance what to edit here?
                    • BKeyportB Offline
                      BKeyport Module Developer
                      I sure don’t, I’ve just started writing my own after running into the same problem as you.
                      • cowboysdudeC Offline
                        cowboysdude Module Developer
                        So you guys got it figured out? :)
                        • Cr4z33C Offline
                          Cr4z33 @cowboysdude
                          @cowboysdude not yet. :neutral_face:
                            What are you trying to do?
                            S Cr4z33C 2 Replies Last reply Reply Quote 0
                              sdetweil @cowboysdude
                              @cowboysdude make the ticket scroll left to right. I posted the solution in the other
                              topic
                              https://forum.magicmirror.builders/topic/13397/mmm-newsfeedticker-scroll-from-left-to-right-only/16
                              • Cr4z33C Offline
                                Cr4z33 @cowboysdude
                                @cowboysdude sorry for being late, but thanks for willing to help. :D
                                @sdetweil going to check right now thanks.
                                • 5 / 5
