    Synology Docker Tutorial?
    15 Posts 9 Posters 9.1k Views 10 Watching
    • C Offline
      cyberphox
      Anyone have tips or a tutorial on setting up MM2 in a Synology Docker?
      rudibaraniR 1 Reply Last reply Reply Quote 0
      • rudibaraniR Offline
        rudibarani Project Sponsor @cyberphox
        @cyberphox After downloading the registry “bastilimbach/docker-magicmirror:latest”
        • Name the container “MagicMirror”
        • I prefer setting a cpu limit to have a safeguard against rouge processes
        • Limiting it to max 4 GB of RAM works fine for me
        • Activate automatic restart
        • If you like, add a link to the MagicMirror on your Synology Desktop by adding “:8080” the url provided
        • Port: Make sure, 8080 is written on both sides of the table. If port 8080 is already in use, you can use another port on the left side.
        • Volume: I have added a screenshot for the folders I am linking in from my Synology. Make sure, you finish the setup before starting MagicMirror for the first time.
        • If you use the firewall (you should!), make sure, the rule “Docker MagicMirror” is active. It should have been generated from Docker automatically.
        When everything is ready, fire up the MagicMirror Docker image and follow the instructions for a regular setup.
        • C Offline
          cyberphox
          Thanks @rudibarani ! I’m gonna try and tackle it this week and appreciate your help!!!
          • C Offline
            cyberphox @cyberphox
            I’m getting close…got the container installed and started…just need to figure out how to enter the command in shell for it to run
            • kusselinK Offline
              kusselin
              @rudibarani said in Synology Docker Tutorial?:
              I took over the folders and the mount paths in the same way, but the css folder remains empty. I can open the magic mirror via browser if I enter IP: 8080 … but the background remains white and I have installed GIT Server over the package management and sometimes a module, but it is not displayed … only the standard modules. …
              the modules are installed in / docker / magicmirror / modules / default after starting the container is that correct?
              Greeting
              2020-12-05 17:49:35	stdout	[2020-12-05 17:49:35.556] [INFO]   Newsfeed-Fetcher: Broadcasting 132 items.
              2020-12-05 17:49:34	stdout	[2020-12-05 17:49:34.979] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:49:34	stdout	[2020-12-05 17:49:34.826] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics 404: Not Found
              2020-12-05 17:49:34	stdout	[2020-12-05 17:49:34.603] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:49:34	stdout	[2020-12-05 17:49:34.603] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/vqstln660rqn38fkrkd1gs2m2s%40group.calendar.google.com/private-c825df8caf155a9636d5d7db523f906f/basic.ics
              2020-12-05 17:49:34	stdout	[2020-12-05 17:49:34.600] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
              2020-12-05 17:49:34	stdout	[2020-12-05 17:49:34.600] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics
              2020-12-05 17:44:35	stdout	[2020-12-05 17:44:35.440] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:44:35	stdout	[2020-12-05 17:44:35.218] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics 404: Not Found
              2020-12-05 17:44:35	stdout	[2020-12-05 17:44:35.207] [INFO]   Newsfeed-Fetcher: Broadcasting 132 items.
              2020-12-05 17:44:34	stdout	[2020-12-05 17:44:34.437] [LOG]    Create new news fetcher for url: https://www.bild.de/rss-feeds/rss-16725492,feed=news.bild.html - Interval: 300000
              2020-12-05 17:44:34	stdout	[2020-12-05 17:44:34.435] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics - Interval: 300000
              2020-12-05 17:44:34	stdout	[2020-12-05 17:44:34.392] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/vqstln660rqn38fkrkd1gs2m2s%40group.calendar.google.com/private-c825df8caf155a9636d5d7db523f906f/basic.ics - Interval: 300000
              2020-12-05 17:42:53	stdout	Ready to go! Please point your browser to: http://0.0.0.0:8080
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.833] [LOG]
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.832] [LOG]    Sockets connected & modules started ...
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.831] [LOG]    Starting node helper for: newsfeed
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.830] [LOG]    Connecting socket for: newsfeed
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.829] [LOG]    Starting node helper for: calendar
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.828] [LOG]    Connecting socket for: calendar
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.827] [LOG]    Connecting socket for: updatenotification
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.826] [LOG]    Server started ...
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.817] [INFO]   You're using a full whitelist configuration to allow for all IPs
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.807] [LOG]    Starting server on port 8080 ...
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.374] [LOG]    All module helpers loaded.
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.373] [LOG]    Module helper loaded: newsfeed
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.373] [LOG]    Initializing new module helper ...
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.180] [LOG]    No helper found for module: MMM-PublicTransportHafas.
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.179] [LOG]    No helper found for module: weatherforecast.
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.178] [LOG]    No helper found for module: currentweather.
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.177] [LOG]    No helper found for module: compliments.
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.176] [LOG]    Module helper loaded: calendar
              2020-12-05 17:42:53	stdout	[2020-12-05 17:42:53.176] [LOG]    Initializing new module helper ...
              2020-12-05 17:42:52	stdout	[2020-12-05 17:42:52.130] [LOG]    No helper found for module: clock.
              2020-12-05 17:42:52	stdout	[2020-12-05 17:42:52.129] [LOG]    Module helper loaded: updatenotification
              2020-12-05 17:42:52	stdout	[2020-12-05 17:42:52.128] [LOG]    Initializing new module helper ...
              2020-12-05 17:42:51	stdout	[2020-12-05 17:42:51.917] [LOG]    No helper found for module: alert.
              2020-12-05 17:42:51	stdout	[2020-12-05 17:42:51.914] [LOG]    Loading module helpers ...
              2020-12-05 17:42:51	stdout	[2020-12-05 17:42:51.909] [LOG]    Loading config ...
              2020-12-05 17:42:51	stdout	[2020-12-05 17:42:51.875] [LOG]    Starting MagicMirror: v2.13.0
              2020-12-05 17:42:19	stdout	[2020-12-05 17:42:19.454] [LOG]    Stopping module helper: newsfeed
              2020-12-05 17:42:19	stdout	[2020-12-05 17:42:19.454] [LOG]    Stopping module helper: calendar
              2020-12-05 17:42:19	stdout	[2020-12-05 17:42:19.453] [LOG]    Stopping module helper: updatenotification
              2020-12-05 17:42:19	stdout	[2020-12-05 17:42:19.452] [LOG]    [SIGTERM] Received. Shutting down server...
              2020-12-05 17:41:16	stdout	[2020-12-05 17:41:16.536] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:41:16	stdout	[2020-12-05 17:41:16.417] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:41:16	stdout	[2020-12-05 17:41:16.253] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics 404: Not Found
              2020-12-05 17:41:16	stdout	[2020-12-05 17:41:16.138] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics 404: Not Found
              2020-12-05 17:41:16	stdout	[2020-12-05 17:41:16.126] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:41:16	stdout	[2020-12-05 17:41:16.126] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/vqstln660rqn38fkrkd1gs2m2s%40group.calendar.google.com/private-c825df8caf155a9636d5d7db523f906f/basic.ics
              2020-12-05 17:41:16	stdout	[2020-12-05 17:41:16.123] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
              2020-12-05 17:41:16	stdout	[2020-12-05 17:41:16.123] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics
              2020-12-05 17:41:16	stdout	[2020-12-05 17:41:16.110] [INFO]   Newsfeed-Fetcher: Broadcasting 132 items.
              2020-12-05 17:36:15	stdout	[2020-12-05 17:36:15.890] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:36:15	stdout	[2020-12-05 17:36:15.795] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics 404: Not Found
              2020-12-05 17:36:15	stdout	[2020-12-05 17:36:15.778] [INFO]   Newsfeed-Fetcher: Broadcasting 133 items.
              2020-12-05 17:36:15	stdout	[2020-12-05 17:36:15.421] [INFO]   Newsfeed-Fetcher: Broadcasting 132 items.
              2020-12-05 17:36:15	stdout	[2020-12-05 17:36:15.421] [LOG]    Use existing news fetcher for url: https://www.bild.de/rss-feeds/rss-16725492,feed=news.bild.html
              2020-12-05 17:36:15	stdout	[2020-12-05 17:36:15.415] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
              2020-12-05 17:36:15	stdout	[2020-12-05 17:36:15.415] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics
              2020-12-05 17:36:15	stdout	[2020-12-05 17:36:15.371] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:36:15	stdout	[2020-12-05 17:36:15.371] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/vqstln660rqn38fkrkd1gs2m2s%40group.calendar.google.com/private-c825df8caf155a9636d5d7db523f906f/basic.ics
              2020-12-05 17:35:14	stdout	[2020-12-05 17:35:14.086] [INFO]   Newsfeed-Fetcher: Broadcasting 132 items.
              2020-12-05 17:35:13	stdout	[2020-12-05 17:35:13.705] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:35:13	stdout	[2020-12-05 17:35:13.440] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics 404: Not Found
              2020-12-05 17:35:13	stdout	[2020-12-05 17:35:13.429] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics 404: Not Found
              2020-12-05 17:35:13	stdout	[2020-12-05 17:35:13.275] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:35:13	stdout	[2020-12-05 17:35:13.275] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/vqstln660rqn38fkrkd1gs2m2s%40group.calendar.google.com/private-c825df8caf155a9636d5d7db523f906f/basic.ics
              2020-12-05 17:35:13	stdout	[2020-12-05 17:35:13.270] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
              2020-12-05 17:35:13	stdout	[2020-12-05 17:35:13.237] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics
              2020-12-05 17:30:13	stdout	[2020-12-05 17:30:13.837] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:30:13	stdout	[2020-12-05 17:30:13.577] [INFO]   Newsfeed-Fetcher: Broadcasting 132 items.
              2020-12-05 17:30:13	stdout	[2020-12-05 17:30:13.055] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics 404: Not Found
              2020-12-05 17:30:12	stdout	[2020-12-05 17:30:12.766] [LOG]    Create new news fetcher for url: https://www.bild.de/rss-feeds/rss-16725492,feed=news.bild.html - Interval: 300000
              2020-12-05 17:30:12	stdout	[2020-12-05 17:30:12.748] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics - Interval: 300000
              2020-12-05 17:30:12	stdout	[2020-12-05 17:30:12.628] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/vqstln660rqn38fkrkd1gs2m2s%40group.calendar.google.com/private-c825df8caf155a9636d5d7db523f906f/basic.ics - Interval: 300000
              2020-12-05 17:26:40	stdout	Ready to go! Please point your browser to: http://0.0.0.0:8080
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.968] [LOG]
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.967] [LOG]    Sockets connected & modules started ...
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.966] [LOG]    Starting node helper for: newsfeed
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.965] [LOG]    Connecting socket for: newsfeed
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.963] [LOG]    Starting node helper for: calendar
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.962] [LOG]    Connecting socket for: calendar
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.960] [LOG]    Connecting socket for: updatenotification
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.949] [LOG]    Server started ...
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.940] [INFO]   You're using a full whitelist configuration to allow for all IPs
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.931] [LOG]    Starting server on port 8080 ...
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.748] [LOG]    All module helpers loaded.
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.747] [LOG]    Module helper loaded: newsfeed
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.747] [LOG]    Initializing new module helper ...
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.670] [LOG]    No helper found for module: MMM-PublicTransportHafas.
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.670] [LOG]    No helper found for module: weatherforecast.
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.669] [LOG]    No helper found for module: currentweather.
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.668] [LOG]    No helper found for module: compliments.
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.668] [LOG]    Module helper loaded: calendar
              2020-12-05 17:26:40	stdout	[2020-12-05 17:26:40.667] [LOG]    Initializing new module helper ...
              2020-12-05 17:26:39	stdout	[2020-12-05 17:26:39.829] [LOG]    No helper found for module: clock.
              2020-12-05 17:26:39	stdout	[2020-12-05 17:26:39.829] [LOG]    Module helper loaded: updatenotification
              2020-12-05 17:26:39	stdout	[2020-12-05 17:26:39.828] [LOG]    Initializing new module helper ...
              2020-12-05 17:26:39	stdout	[2020-12-05 17:26:39.751] [LOG]    No helper found for module: alert.
              2020-12-05 17:26:39	stdout	[2020-12-05 17:26:39.749] [LOG]    Loading module helpers ...
              2020-12-05 17:26:39	stdout	[2020-12-05 17:26:39.744] [LOG]    Loading config ...
              2020-12-05 17:26:39	stdout	[2020-12-05 17:26:39.719] [LOG]    Starting MagicMirror: v2.13.0
              2020-12-05 17:26:32	stdout	[2020-12-05 17:26:32.780] [LOG]    Stopping module helper: newsfeed
              2020-12-05 17:26:32	stdout	[2020-12-05 17:26:32.780] [LOG]    Stopping module helper: calendar
              2020-12-05 17:26:32	stdout	[2020-12-05 17:26:32.780] [LOG]    Stopping module helper: updatenotification
              2020-12-05 17:26:32	stdout	[2020-12-05 17:26:32.738] [LOG]    [SIGTERM] Received. Shutting down server...
              2020-12-05 17:21:37	stdout	[2020-12-05 17:21:37.780] [INFO]   Newsfeed-Fetcher: Broadcasting 132 items.
              2020-12-05 17:21:36	stdout	[2020-12-05 17:21:36.560] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:21:36	stdout	[2020-12-05 17:21:36.353] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics 404: Not Found
              2020-12-05 17:21:36	stdout	[2020-12-05 17:21:36.265] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:21:36	stdout	[2020-12-05 17:21:36.168] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:21:36	stdout	[2020-12-05 17:21:36.168] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/vqstln660rqn38fkrkd1gs2m2s%40group.calendar.google.com/private-c825df8caf155a9636d5d7db523f906f/basic.ics
              2020-12-05 17:21:36	stdout	[2020-12-05 17:21:36.162] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
              2020-12-05 17:21:36	stdout	[2020-12-05 17:21:36.161] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics
              2020-12-05 17:21:35	stdout	[2020-12-05 17:21:35.753] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics 404: Not Found
              2020-12-05 17:16:37	stdout	[2020-12-05 17:16:37.502] [INFO]   Newsfeed-Fetcher: Broadcasting 132 items.
              2020-12-05 17:16:35	stdout	[2020-12-05 17:16:35.940] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:16:35	stdout	[2020-12-05 17:16:35.638] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics 404: Not Found
              2020-12-05 17:16:35	stdout	[2020-12-05 17:16:35.525] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:16:35	stdout	[2020-12-05 17:16:35.524] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/vqstln660rqn38fkrkd1gs2m2s%40group.calendar.google.com/private-c825df8caf155a9636d5d7db523f906f/basic.ics
              2020-12-05 17:16:35	stdout	[2020-12-05 17:16:35.522] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
              2020-12-05 17:16:35	stdout	[2020-12-05 17:16:35.521] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics
              2020-12-05 17:11:37	stdout	[2020-12-05 17:11:37.375] [INFO]   Calendar-Fetcher: Broadcasting 10 events.
              2020-12-05 17:11:37	stdout	[2020-12-05 17:11:37.157] [INFO]   Newsfeed-Fetcher: Broadcasting 132 items.
              2020-12-05 17:11:36	stdout	[2020-12-05 17:11:36.668] [ERROR]  Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics 404: Not Found
              2020-12-05 17:11:35	stdout	[2020-12-05 17:11:35.884] [LOG]    Create new news fetcher for url: https://www.bild.de/rss-feeds/rss-16725492,feed=news.bild.html - Interval: 300000
              2020-12-05 17:11:35	stdout	[2020-12-05 17:11:35.776] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/kcb3jqvhnqem58u1jo14q0m00c%40group.calendar.google.com/private-426839fca2c51459341321f6f4e55e84/basic.ics - Interval: 300000
              2020-12-05 17:11:35	stdout	[2020-12-05 17:11:35.661] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/vqstln660rqn38fkrkd1gs2m2s%40group.calendar.google.com/private-c825df8caf155a9636d5d7db523f906f/basic.ics - Interval: 300000
              2020-12-05 17:09:51	stdout	Ready to go! Please point your browser to: http://0.0.0.0:8080
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.474] [LOG]
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.473] [LOG]    Sockets connected & modules started ...
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.472] [LOG]    Starting node helper for: newsfeed
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.470] [LOG]    Connecting socket for: newsfeed
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.469] [LOG]    Starting node helper for: calendar
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.467] [LOG]    Connecting socket for: calendar
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.465] [LOG]    Connecting socket for: updatenotification
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.464] [LOG]    Server started ...
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.447] [INFO]   You're using a full whitelist configuration to allow for all IPs
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.440] [LOG]    Starting server on port 8080 ...
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.176] [LOG]    All module helpers loaded.
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.176] [LOG]    Module helper loaded: newsfeed
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.175] [LOG]    Initializing new module helper ...
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.009] [LOG]    No helper found for module: fuel.
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.008] [LOG]    No helper found for module: weatherforecast.
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.007] [LOG]    No helper found for module: currentweather.
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.007] [LOG]    No helper found for module: compliments.
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.006] [LOG]    Module helper loaded: calendar
              2020-12-05 17:09:51	stdout	[2020-12-05 17:09:51.005] [LOG]    Initializing new module helper ...
              2020-12-05 17:09:48	stdout	[2020-12-05 17:09:48.206] [LOG]    No helper found for module: clock.
              2020-12-05 17:09:48	stdout	[2020-12-05 17:09:48.205] [LOG]    Module helper loaded: updatenotification
              2020-12-05 17:09:48	stdout	[2020-12-05 17:09:48.204] [LOG]    Initializing new module helper ...
              2020-12-05 17:09:48	stdout	[2020-12-05 17:09:47.747] [LOG]    No helper found for module: alert.
              2020-12-05 17:09:47	stdout	[2020-12-05 17:09:47.745] [LOG]    Loading module helpers ...
              2020-12-05 17:09:47	stdout	[2020-12-05 17:09:47.630] [LOG]    Loading config ...
              2020-12-05 17:09:47	stdout	[2020-12-05 17:09:47.622] [LOG]    Starting MagicMirror: v2.13.0
              2020-12-05 17:09:19	stdout	[2020-12-05 17:09:19.958] [LOG]    Stopping module helper: newsfeed
              2020-12-05 17:09:19	stdout	[2020-12-05 17:09:19.957] [LOG]    Stopping module helper: calendar
              2020-12-05 17:09:19	stdout	[2020-12-05 17:09:19.956] [LOG]    Stopping module helper: updatenotification
              2020-12-05 17:09:19	stdout	[2020-12-05 17:09:19.954] [LOG]    [SIGTERM] Received. Shutting down server...
              2020-12-05 17:07:17	stdout	Ready to go! Please point your browser to: http://0.0.0.0:8080
              2020-12-05 17:07:17	stdout	[2020-12-05 17:07:17.040] [LOG]
              2020-12-05 17:07:17	stdout	[2020-12-05 17:07:17.040] [LOG]    Sockets connected & modules started ...
              2020-12-05 17:07:17	stdout	[2020-12-05 17:07:17.039] [LOG]    Starting node helper for: newsfeed
              2020-12-05 17:07:17	stdout	[2020-12-05 17:07:17.038] [LOG]    Connecting socket for: newsfeed
              2020-12-05 17:07:17	stdout	[2020-12-05 17:07:17.037] [LOG]    Starting node helper for: calendar
              2020-12-05 17:07:17	stdout	[2020-12-05 17:07:17.037] [LOG]    Connecting socket for: calendar
              2020-12-05 17:07:17	stdout	[2020-12-05 17:07:17.035] [LOG]    Connecting socket for: updatenotification
              2020-12-05 17:07:17	stdout	[2020-12-05 17:07:17.032] [LOG]    Server started ...
              2020-12-05 17:07:17	stdout	[2020-12-05 17:07:17.020] [INFO]   You're using a full whitelist configuration to allow for all IPs
              2020-12-05 17:07:17	stdout	[2020-12-05 17:07:17.006] [LOG]    Starting server on port 8080 ...
              2020-12-05 17:07:16	stdout	[2020-12-05 17:07:16.412] [LOG]    All module helpers loaded.
              2020-12-05 17:07:16	stdout	[2020-12-05 17:07:16.412] [LOG]    Module helper loaded: newsfeed
              2020-12-05 17:07:16	stdout	[2020-12-05 17:07:16.411] [LOG]    Initializing new module helper ...
              2020-12-05 17:07:16	stdout	[2020-12-05 17:07:16.126] [LOG]    No helper found for module: fuel.
              2020-12-05 17:07:16	stdout	[2020-12-05 17:07:16.125] [LOG]    No helper found for module: weatherforecast.
              2020-12-05 17:07:16	stdout	[2020-12-05 17:07:16.090] [LOG]    No helper found for module: currentweather.
              2020-12-05 17:07:16	stdout	[2020-12-05 17:07:16.089] [LOG]    No helper found for module: compliments.
              2020-12-05 17:07:16	stdout	[2020-12-05 17:07:16.088] [LOG]    Module helper loaded: calendar
              2020-12-05 17:07:16	stdout	[2020-12-05 17:07:16.088] [LOG]    Initializing new module helper ...
              2020-12-05 17:07:15	stdout	[2020-12-05 17:07:15.146] [LOG]    No helper found for module: clock.
              2020-12-05 17:07:15	stdout	[2020-12-05 17:07:15.127] [LOG]    Module helper loaded: updatenotification
              2020-12-05 17:07:15	stdout	[2020-12-05 17:07:15.126] [LOG]    Initializing new module helper ...
              2020-12-05 17:07:14	stdout	[2020-12-05 17:07:14.877] [LOG]    No helper found for module: alert.
              2020-12-05 17:07:14	stdout	[2020-12-05 17:07:14.875] [LOG]    Loading module helpers ...
              2020-12-05 17:07:14	stdout	[2020-12-05 17:07:14.818] [LOG]    Loading config ...
              2020-12-05 17:07:14	stdout	[2020-12-05 17:07:14.662] [LOG]    Starting MagicMirror: v2.13.0
              2020-12-05 17:05:04	stdout	}
              2020-12-05 17:05:04	stdout	  ]
              2020-12-05 17:05:04	stdout	    '/opt/magic_mirror/serveronly/index.js'
              2020-12-05 17:05:04	stdout	    '/opt/magic_mirror/js/app.js',
              2020-12-05 17:05:04	stdout	  requireStack: [
              2020-12-05 17:05:04	stdout	  code: 'MODULE_NOT_FOUND',
              2020-12-05 17:05:04	stdout	    at Module.require (internal/modules/cjs/loader.js:1025:19) {
              2020-12-05 17:05:04	stdout	    at Function.Module._load (internal/modules/cjs/loader.js:878:14)
              2020-12-05 17:05:04	stdout	    at Module.load (internal/modules/cjs/loader.js:985:32)
              2020-12-05 17:05:04	stdout	    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
              2020-12-05 17:05:04	stdout	    at Module._compile (internal/modules/cjs/loader.js:1137:30)
              2020-12-05 17:05:04	stdout	    at Object.<anonymous> (/opt/magic_mirror/js/app.js:12:22)
              2020-12-05 17:05:04	stdout	    at require (internal/modules/cjs/helpers.js:72:18)
              2020-12-05 17:05:04	stdout	    at Function.Module._load (internal/modules/cjs/loader.js:841:27)
              2020-12-05 17:05:04	stdout	    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
              2020-12-05 17:05:04	stdout	- /opt/magic_mirror/serveronly/index.js
              2020-12-05 17:05:04	stdout	- /opt/magic_mirror/js/app.js
              2020-12-05 17:05:04	stdout	Require stack:
              2020-12-05 17:05:04	stdout	Error: Cannot find module '/opt/magic_mirror/js/../modules/default/defaultmodules.js'
              2020-12-05 17:05:04	stdout	  ^
              2020-12-05 17:05:04	stdout	  throw err;
              2020-12-05 17:05:04	stdout	internal/modules/cjs/loader.js:968
              2020-12-05 17:04:41	stdout	}
              2020-12-05 17:04:41	stdout	  ]
              2020-12-05 17:04:41	stdout	    '/opt/magic_mirror/serveronly/index.js'
              2020-12-05 17:04:41	stdout	    '/opt/magic_mirror/js/app.js',
              2020-12-05 17:04:41	stdout	  requireStack: [
              2020-12-05 17:04:41	stdout	  code: 'MODULE_NOT_FOUND',
              2020-12-05 17:04:41	stdout	    at Module.require (internal/modules/cjs/loader.js:1025:19) {
              2020-12-05 17:04:41	stdout	    at Function.Module._load (internal/modules/cjs/loader.js:878:14)
              2020-12-05 17:04:41	stdout	    at Module.load (internal/modules/cjs/loader.js:985:32)
              2020-12-05 17:04:41	stdout	    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
              2020-12-05 17:04:41	stdout	    at Module._compile (internal/modules/cjs/loader.js:1137:30)
              2020-12-05 17:04:41	stdout	    at Object.<anonymous> (/opt/magic_mirror/js/app.js:12:22)
              2020-12-05 17:04:41	stdout	    at require (internal/modules/cjs/helpers.js:72:18)
              2020-12-05 17:04:41	stdout	    at Function.Module._load (internal/modules/cjs/loader.js:841:27)
              2020-12-05 17:04:41	stdout	    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
              2020-12-05 17:04:41	stdout	- /opt/magic_mirror/serveronly/index.js
              2020-12-05 17:04:41	stdout	- /opt/magic_mirror/js/app.js
              2020-12-05 17:04:41	stdout	Require stack:
              2020-12-05 17:04:41	stdout	Error: Cannot find module '/opt/magic_mirror/js/../modules/default/defaultmodules.js'
              2020-12-05 17:04:41	stdout	  ^
              2020-12-05 17:04:41	stdout	  throw err;
              2020-12-05 17:04:41	stdout	internal/modules/cjs/loader.js:968
              2020-12-05 17:04:23	stdout	}
              2020-12-05 17:04:23	stdout	  ]
              2020-12-05 17:04:23	stdout	    '/opt/magic_mirror/serveronly/index.js'
              2020-12-05 17:04:23	stdout	    '/opt/magic_mirror/js/app.js',
              2020-12-05 17:04:23	stdout	  requireStack: [
              2020-12-05 17:04:23	stdout	  code: 'MODULE_NOT_FOUND',
              2020-12-05 17:04:23	stdout	    at Module.require (internal/modules/cjs/loader.js:1025:19) {
              2020-12-05 17:04:23	stdout	    at Function.Module._load (internal/modules/cjs/loader.js:878:14)
              2020-12-05 17:04:23	stdout	    at Module.load (internal/modules/cjs/loader.js:985:32)
              2020-12-05 17:04:23	stdout	    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
              2020-12-05 17:04:23	stdout	    at Module._compile (internal/modules/cjs/loader.js:1137:30)
              2020-12-05 17:04:23	stdout	    at Object.<anonymous> (/opt/magic_mirror/js/app.js:12:22)
              2020-12-05 17:04:23	stdout	    at require (internal/modules/cjs/helpers.js:72:18)
              2020-12-05 17:04:23	stdout	    at Function.Module._load (internal/modules/cjs/loader.js:841:27)
              2020-12-05 17:04:23	stdout	    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
              2020-12-05 17:04:23	stdout	- /opt/magic_mirror/serveronly/index.js
              2020-12-05 17:04:23	stdout	- /opt/magic_mirror/js/app.js
              2020-12-05 17:04:23	stdout	Require stack:
              2020-12-05 17:04:23	stdout	Error: Cannot find module '/opt/magic_mirror/js/../modules/default/defaultmodules.js'
              2020-12-05 17:04:23	stdout	  ^
              2020-12-05 17:04:23	stdout	  throw err;
              2020-12-05 17:04:23	stdout	internal/modules/cjs/loader.js:968
              • oscarbO Offline
                oscarb
                @kusselin said in Synology Docker Tutorial?:
                Error: Cannot find module ‘/opt/magic_mirror/js/…/modules/default/defaultmodules.js’
                Maybe this will help someone else running into the same issue. I was unable to start Magic Mirror in Docker on my Synology NAS (using the karsten13/magicmirror image because v.2.15.0 is not in the bastilimbach one) and I got the same error as above.
                Turned out to be some permission issue I was able to solve by adding two more environment variables to the docker container:
                USER_ID: 1024
                GROUP_ID: 100
                This will run the docker container as the admin user on your NAS. If you wish to run it as some other user (which is preferable) you need to find the right user/group id (SSH into the NAS and then sudo cat /etc/passwd I believe).
                • O Offline
                  odolmach3 @oscarb
                  @oscarb said in Synology Docker Tutorial?:
                  USER_ID: 1024
                  GROUP_ID: 100
                  Hi, im not able to get the newest Karsten13 2.25 version running on the Synology (the 2.15 bastilimbach runs fine). The files in the mounts were created but the container stops after a few seconds. Do you have any tips?
                  S karsten13K wishmaster270W 3 Replies Last reply Reply Quote 0
                    sdetweil @odolmach3
                    @odolmach3 @karsten13
                    • karsten13K Offline
                      karsten13 @odolmach3
                      @odolmach3
                      we need the logs of the container
                      • wishmaster270W Offline
                        wishmaster270 Module Developer @odolmach3
                        @odolmach3
                        just tried to run the latest Image of karsten13 on my Synology.
                        You need to make sure you add “npm run server” as “command” during the creating of the container settings.
                        • O Offline
                          odolmach3 @wishmaster270
                          @wishmaster270 said in Synology Docker Tutorial?:
                          npm run server
                          Thank you, that does the Trick!
                          • T Offline
                            techeros
                            Hi everyone so I was having a lot of issues getting MagicMirror installed.
                            Do not bother trying to install bastilimbach, it will install but you wont be able to get the calendar working.
                            Instead follow these steps on your Synology. I made it simple incase you are not used to working with putty etc etc
                            Download and install Putty
                            setup the connection to poin to your IP address and port 22
                            Once you connect, type your admin user and pass
                            1. Uninstall MagicMirror
                              Run these commands to completely remove the existing MagicMirror setup:
                            Stop and Remove the Container
                            bash
                            sudo docker stop magicmirror
                            sudo docker rm magicmirror
                            Remove the Image
                            bash
                            sudo docker rmi karsten13/magicmirror:latest
                            Delete Configuration Files
                            (Optional, if you want a clean start):
                            sudo rm -rf /volume1/docker/magicmirror
                            1. Install MagicMirror
                              Follow these steps to reinstall MagicMirror:
                            Create Necessary Directories
                            Copy code
                            mkdir -p /volume1/docker/magicmirror/{config,modules,css}
                            sudo chown -R 1000:1000 /volume1/docker/magicmirror
                            Pull the MagicMirror Image
                            sudo docker pull karsten13/magicmirror:latest
                            Run the MagicMirror Container
                            sudo docker run -d
                            –name magicmirror
                            –publish 8036:8080
                            –restart unless-stopped
                            -e TZ=America/Chicago
                            –volume /volume1/docker/magicmirror/config:/opt/magic_mirror/config
                            –volume /volume1/docker/magicmirror/modules:/opt/magic_mirror/modules
                            –volume /volume1/docker/magicmirror/css:/opt/magic_mirror/css
                            1. Verify the Installation
                              Check that the container is running:
                            sudo docker ps
                            Look for magicmirror in the list.
                            The STATUS column should say Up.
                            Open MagicMirror in your browser:
                            http://<Your_NAS_IP>:8036
                            Replace <Your_NAS_IP> with your Synology NAS’s IP address in your web browser
                              wishmaster270 Module Developer @techeros
                              @techeros Sorry. But you can use the container manager gui in the Web interface for most of the job. No need to pull or remove any images on the shell manually.
                              T S 2 Replies Last reply Reply Quote 0
                              • T Offline
                                techeros @wishmaster270
                                @wishmaster270
                                Sure, If you could so kindly point me to the documentation, Id love to. Im just getting started with Containers on my synology and have been fighting tooth and nail to get it installed.
                                If I select the image kristen13 and install non of the directories are created, nothing works.
                                If You use the manual instructions i posted, it works (for me). I have a lot to learn here so , if im way off-base i’m all ears.
                                Thanks for chiming in
                                T
                                  sdetweil @wishmaster270
                                  @wishmaster270 my 416j+ doesn’t officially support docker, so there is no ui.
