    My first Magic Mirror (Italy)
    19 Posts 5 Posters 9.2k Views 3 Watching
      A Former User
      Hi Guys
      Im Antonio from Milan Italy, and this is the beginning of my project.
      • LCD --> 24" Samsung Syncmaster T240
      • Mirror --> Pilkington MirroView ( https://www.brigla-shop.de/ )
      • Raspberry Pi 3 B+
      • Frame --> Wood self made.
      More picture coming soon…
      FINISHED update
        A Former User
        Added wiring
          A Former User
          Modules configured, clean and simple, just what I need, ALEXA coming soon:
          The video on bottom left is LIVE YouTube channel of EURONEEWS Italy
            A Former User
            Testing temperature, heatsink is needed considering summer temperatures
              A Former User
              Testing vertical layout, look better right?
              • B
                bhepler Module Developer
                You’re definitely off to a good start! I like the FLIR tool. I’m jealous. I don’t know why I would need one, but I want one now.
                I notice that you took off the metal backing to your monitor. Did you have any concerns with that? I have to take the one off the mirror I’m building now because it kind of fell off during the bezel removal process. I haven’t done that before and I’m nervous I’ll short something.
                  A Former User @bhepler
                  @bhepler Yes I removed the shield to make it slimmer.
                  All the boards are 1cm above the LCD surface, I used some plastic spacers and I put an Electrical insulation paper above them.
                  I use the Flir thermocamera for testing the Broadcast Cameras that I sell, many cameraman complains about heat coming from cameras.
                  • B
                    bhepler Module Developer @Guest
                    @qbox83 - Aha! I have a thin sheet of acrylic I can use as an insulation layer. I can then reposition the two boards of the monitor and position the Pi where I need it. Thanks!
                    • V
                      vinp Module Developer
                      complimenti !
                        A Former User
                        Almost done, tomorrow I will post all the pictures step by step
                          A Former User @vinp
                          @vinp grazie :-)
                            A Former User
                            2_1544439429634_IMG_5364.jpg 1_1544439429634_IMG_5363.jpg 0_1544439429634_IMG_5362.jpg
                            Cr4z33C 1 Reply Last reply Reply Quote 1
                            • Cr4z33C
                              Cr4z33 @Guest
                              @qbox83 said in My first Magic Mirror (Italy):
                              Hey I am Italian too and in need to find a solid frame solution for my 55" MagicMirror project.
                              Alluminium frames are a pain in the a** as no online national company builds them so big (not to mention local companies that don’t want to deal with that kind of requests…) so big so I went back thinking at wooden solutions.
                              Can you please tell me where can I buy that special sawing kit?
                              I like it alot and your project is coming out really well! :thumbs_up_medium-light_skin_tone:
                              • G
                                Giuse
                                Hi Antonio,
                                Sono uno sviluppatore italiano e da circa 6 mesi sto implementando la mia soluzione MIRROR 2.0 ampliata all’ambito italiano.
                                Saresti interessato a collaborare in quest’impresa?
                                Attualmente sto cercando di implementare il modulo legato alle api dei trasporti pubblici, un modulo per i comandi vocali con Alexa e un modulo per interfacciarsi con i veicoli Tesla.
                                Fammi sapere!!
                                Ciao!
                                Giuseppe
                                • G
                                  Giuse
                                  Ho dimenticato di inserire un’email di contatto…
                                  Giuse.scibetta@gmail.com
                                  Un saluto
                                  Giuseppe
                                    A Former User
                                    @Cr4z33 lo trovi da Leroy Merlin
                                    https://www.leroymerlin.it/catalogo/tagliacornici-dexter-550-mm-35861224-p
                                    • Cr4z33C
                                      Cr4z33 @Guest
                                      @qbox83 OK thanks. :thumbs_up_medium-light_skin_tone:
                                        A Former User
                                        2_1544951150798_IMG_5383.jpg 1_1544951150798_IMG_5382.jpg 0_1544951150798_IMG_5380.jpg
                                        FINISH.
                                        I have to say that Acrylic sheet isn’t the best choice since it scratch too easily and it’s hard to clean without ruin it.
                                        I will move to DIELETTRIC MIRROR
                                          A Former User
                                          ragazzi comprate gli specchi qui:
                                          spedito mi fanno online perun 54cm x 34cm cca 68€ il MirroView della Pilkington
