    [MMM-AlexaOnOff] Simple Mirror Control from External Home Assistant (Alexa/Google Home/HASS.io)
    81 Posts 13 Posters 75.8k Views 16 Watching
    • NiggichN Offline
      Niggich
      @shbatm Can you help us?
      • SubLim3S Offline
        SubLim3
        I am running MM version 2.7.1 with the latest MMM-AlexaOnOff module. Below is my config.js details for this module. I get no errors when restarting MM and had no problem with Alexa discovering the devices listed in the module. I get confirmation feedback from Alexa when saying “Turn Magic Mirror Off”, but nothing happens. This used to work on an older build of MM but I wanted to start from scratch with the latest version and this has been the only Mod not working correctly. Any help is appreciated. Thank you.
                                module: 'MMM-AlexaOnOff',
        //						classes: 'default everyone',
                                        devices: [{
                                                on: {
                                                        notification: "REMOTE_ACTION",
                                                        payload: { action:'MONITORON' }
                                                off: {
                                                        payload: { action:'MONITOROFF' }
                                                name: "Magic Mirror Modules",
                                                on: {
                                                        payload: { action:'SHOWALL' }
                                                off: {
                                                        payload: { action:'HIDEALL' }
                                                name: "Magic Mirror Maps",
                                                on: {
                                                        payload: {action: "SHOW", module: "module_8_MMM-GoogleMapsTraffic"}
                                                off: {
                                                        payload: {action: "HIDE", module: "module_8_MMM-GoogleMapsTraffic"}
                                                name: "Magic Mirror Reboot",
                                                on: {
                                                        payload: { action:'REBOOT' }
                                                off: {
                                                        payload: { action:'SHUTDOWN' }
                                                name: "Magic Mirror Update",
                                                on: {
                                                        payload: { action:'UPDATE' }
                                                off: {
                                                        payload: { action:'RESTART' }
        • SubLim3S Offline
          SubLim3
          If the REMOTE_ACTION of MONITOROFF works from the remote UI then the notifications are sent and received and executed properly. Does anyone have any recommendations as to how I can test if the Notifications sent from my Alexa device to the module is received? Just trying to hash through this one. Any help is appreciated. Thank you.
            sdetweil @SubLim3
            @SubLim3 open the developers window, ctrl-shift-i, then select the console tab across the top.
            U can add text to search the console in the filter field.
            You should see all the notification events
            • StoffbeuteluweS Offline
              Stoffbeuteluwe Project Sponsor
              for me the test device is working (Office lamp or fan) but can’t find my modules
              SubLim3S 1 Reply Last reply Reply Quote 0
              • SubLim3S Offline
                SubLim3 @Stoffbeuteluwe
                @Stoffbeuteluwe Yeah, I have been reading that the 3rd Gen Alexa devices are not locating the modules. You might try discovery through the app or web browser http://alexa.amazon.com.
                  Stoffbeuteluwe Project Sponsor @SubLim3
                  @SubLim3 i tried the app but doesn’t work…no device found
                    Stoffbeuteluwe Project Sponsor @MoreLinux
                    @MoreLinux I have MM running on Mac I think you have a RPI …maybe this can be my problem
                      Stoffbeuteluwe Project Sponsor @Stoffbeuteluwe
                      @Stoffbeuteluwe is there anybody with a working module MMM-AlexaOnOff on Mac?
                      test device is working …but no other device
                        @Stoffbeuteluwe anybody an idea?
                        • SubLim3S Offline
                          SubLim3
                          So IF I understand this log correctly, my mirror is receiving the Notification from my Alexa Device but the AlexaOnOff module is not operating correctly. Any suggestions?
                          module.js:154 MMM-WatchDog received a module notification: REMOTE_ACTION from sender: MMM-AlexaOnOff
                          module.js:154 MMM-Screencast received a module notification: REMOTE_ACTION from sender: MMM-AlexaOnOff
                          module.js:154 MMM-GoogleMapsTraffic received a module notification: REMOTE_ACTION from sender: MMM-AlexaOnOff
                          MMM-Remote-Control.js:43 Uncaught TypeError: console.log is not a function
                              at Class.notificationReceived (MMM-Remote-Control.js:43)
                              at sendNotification (main.js:95)
                              at Object.sendNotification (main.js:502)
                              at Class.sendNotification (module.js:368)
                              at config.devices.forEach.d (MMM-AlexaOnOff.js:47)
                              at Array.forEach (<anonymous>)
                              at Class.socketNotificationReceived (MMM-AlexaOnOff.js:37)
                              at module.js:246
                              at r.<anonymous> (socketclient.js:25)
                              at r.emit (index.js:83)
                            sdetweil @SubLim3
                            @SubLim3 edit the MMM-Remote-Control.js, and change all
                            console.log
                            To
                            Log.log
                            • SubLim3S Offline
                              SubLim3 @sdetweil
                              @sdetweil Is this something that happened because I updated MMM-Remote-Control and MMM-AlexaOnOff does not have an update? If so, would it be better to update AlexaOnOff to have console.log instead of log.log? That being said, I could not find Log.log in AlexaOnOff.js anyways.
                              Are there other modules that will stop working if I change MMM_Remote_Control to Log.log? I saw it in there a couple of times and changed it. This did resolve the issue but I need to see if there are other Modules throwing red flags now.
                              Thank you for the Help! Hopefully MMM-AlexaOnOff gets an update to help everyone else with 3rd Gen Alexa devices get discovered.
                                sdetweil @SubLim3
                                @SubLim3 you are supposed to change console.log TO Log.log
                                So currently u will not find it.
                                Log.log is supposed to be used in the module.js file
                                • SubLim3S Offline
                                  SubLim3 @sdetweil
                                  @sdetweil Correct. There were 2 instances in the MMM-Remote-Control.js where I changed console.log to Log.log and this did resolve my issue. I was more curious to know if this was an issue with AlexaOnOff not having an update or if it was due to Remote-Control updating to a newer build.
                                    sdetweil @SubLim3
                                    @SubLim3 that is a bug in remote control.
                                    Don’t know how/when it might have got there
                                    • SubLim3S Offline
                                      SubLim3 @sdetweil
                                      @sdetweil I did find this line commented out near the top of the MMM-Remote-Control.js which may be where they are working to resolve this.
                                      // Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                                        js989
                                        Hi - I’m struggling with this module too. I have it installed with the dependencies. I can see that the ports are opened and listening. Alexa cannot find the devices. I’ve tried the examples too which have not been discovered yet either.
                                        I have an Echo dot gen 3 in the house, on the same network as the mirror. I’ve tried searching for the device from the echo and the web portal - neither has worked. Any tips?
                                          sbrundage85 @js989
                                          @js989 Same situation here. Have not been able to figure it out. I found this resource which I believe may be a possible problem but have not been able to work through it. https://github.com/n8henrie/fauxmo/issues/38
                                            sdetweil
                                            looking at this app, I think alexa v2+ devices have removed the builtin support for wemo devices which this depends on.
                                            so, you would have to install the belkin wemo skill… which requires actual devices
                                            • 4 / 5
