    MMM-Hue-Lights - new module for your Philips Hue lights!
    87 Posts 20 Posters 73.0k Views 19 Watching
    • michael5rM Offline
      michael5r Module Developer @Christian
      @christian said in MMM-Hue-Lights - new module for your Philips Hue lights!:
      I installed the module today with my Deconz gateway (not Hue).
      Everything works fine but I´m not able to use my defined groups.
      Lights are working great but the Hue bridge uses rooms and not groups, I think thats my problem.
      The Deconz gateway uses only lights and groups.
      The module MMM-Hue works great with the Deconz gateway but it´s basic. The new module looks much better.
      Is there a way to fix this problem?
      Regards,
      Christian
      Sure - open up the mmm-hue-lights.js file and go to line 670.
      You’ll see a comment saying for the groups, let's immediately filter out anything that doesn't have a type of 'Room' and a code block that looks like this:
      Object.keys(data.groups).forEach(function(key) {
          var itemType = data.groups[key].type.toLowerCase();
          if (itemType !== 'room') {
              delete data.groups[key];
      If you delete or uncomment that code block, it will no longer filter out anything that isn’t a room.
      • C Offline
        Christian @michael5r
        @michael5r
        Ok, thank you for the fast reply. That’s working for me.
        Regards,
        Christian
        • C Offline
          Christian
          is there a way to get lights or groups sorted by name?
          Regards,
          Christian
          michael5rM 1 Reply Last reply Reply Quote 0
            @christian Not currently - I’m just displaying them in the order that the API spits them out.
            • C Offline
              @michael5r Ah, ok. But it would be a nice feature for the future.
                @christian Sure - post it as an issue/feature request in the Github repo for this package and I’ll find some time to build it!
                  dhoggan
                  I’ve recently installed this module and setup pretty painless. I am, however, having some issues in customising the display. As it’s likely me and not the module I thought here might be a better place than Github to ask.
                  The first issue is that, despite setting the position to be middle_center it adamantly displays justified to the left. If I set it as bottom_center, bottom_right or a variety of other positions it displays as expected; but always to the left if middle_center selected.
                  The second issue is that I can’t seem to get grid mode working. I’ve modified custom.css as advised, but it it just displays as a single column. I’ve even tried a full reboot of the RPi, but no difference.
                  The third is more of a question as I can’t find out how to do this. One of the display examples has the left column with room groups and the right with individual lights. Can anyone point in the direction as to how to do this?
                  Also - and I haven’t tried this yet - but has anyone tried this with two hubs?
                  For completeness, the config.js looks like this:
                                       module: "mmm-hue-lights",
                                       position: "middle_center",
                                              bridgeIp: "w.x.y.x",
                                              user: "12345678901234567890",
                                              displayType: "grid",
                                              displayMode: "groups",
                                              displayFilter: ['all'],
                                              hideFilter: ['Annex'],
                                              updateInterval: "5000"
                  Thanks,
                  Dave
                    dhoggan
                    Just to add that I have managed to work out why the multi-column grid wasn’t working - it was down to me adding the suggested lines between the default { } entries. Adding the lines at the very end of the file and I have columns at last! Just in case anyone else ever has the same issue the custom.css file looks like:
                    body {
                    .mmm-hue-lights .grid {
                    width: auto;
                    display: flex;
                    flex-flow: row wrap;
                    margin: -10px;
                    max-width: none;
                    justify-content: center;
                    .mmm-hue-lights .grid .hue {
                    width: calc(25% - 20px);
                    margin: 10px;
                    display: block;
                    Still puzzling over how the example had rooms in one column and lights in another - if anyone knows I’d be grateful of the help.
                    Thanks,
                    Dave
                      Smotx
                      very great module. Thanks for job.
                      It’s not possible to just see ‘your Rooms’, same as android Hue official app ?
                      Official app :
                      alt text
                      MagicMirror module :
                      alt text
                        Smotx
                        I don’t understand why settings 'displaymode: “groups” does not work :(
                        Setting ‘groups’ work only in mmm-hue-lights?js file, on config file does not work.
                          michael5r Module Developer @dhoggan
                          @dhoggan said in MMM-Hue-Lights - new module for your Philips Hue lights!:
                          The position has nothing to do with the internal alignment of the module - you need to add:
                          alignment: 'center',
                          to your config for the content to be centered.
                          Ahh … I guess I should have been more specific in the description of the examples. There’s no way to do what you describe above - in the screenshots I just wanted to show what both the lights and groups settings looked like, so I took 2 screenshots and placed them next to each other.
                            michael5r Module Developer @Smotx
                            @Smotx said in MMM-Hue-Lights - new module for your Philips Hue lights!:
                            Sure - in the config, set this:
                            displayMode: 'groups',
                            and then it will only show your Rooms.
                              What do you mean it doesn’t work? That’s what I do on my mirror:
                                Smotx @michael5r
                                @michael5r
                                If i set
                                displayMode: ‘groups’,
                                in config file, MM show ‘lights’,
                                to view Groups, I have to parameter on mmm-hue-lights.js.
                                I don’t know why.
                                  @michael5r
                                  If i set
                                  I don’t know why.
                                  Please paste in your entire config for this module - you can XXX out the sensitive info. Thanks!
                                  • tidus5T Offline
                                    tidus5
                                    Amazing job !!
                                    did you plan to make your module tactile ready :-p
                                      Smotx @michael5r
                                      @michael5r
                                      module: “mmm-hue-lights”,
                                      position: “lower_third”, // pick whichever position you want
                                      bridgeIp: “192.168.1.156”,
                                      user: “xxxxxxxxx”,
                                      displayType: “grid”,
                                      displaymode: “groups”,
                                      hideFilter: [“Bloom”, “V3”, “SDB”],
                                      // … and whatever else configuration options you want to use
                                        Smotx
                                        Why if i set
                                        var config = {
                                        	address: "0.0.0.0",
                                        (To open my MM from another computer)
                                        I have error on this module :
                                        Hue api erroe:error ; read ECONNREST
                                        hue api error: null
                                        Thx
                                        • N Offline
                                          numb3rs
                                          I just reinstalled magic mirror on the pi. I installed the mmm-hue-lights module. I tried the default config, and my old config and neither seem to work. The module just sits there with ‘Loading…’
                                          Anybody have ideas?
                                          I did open debug logs and see the module load.
                                          ‘Starting module: mmm-hue-lights, version 1.3.2’ with no errors.
                                          Inserting GET and POST with the user id works fine in the api nginx webpage.
                                          I just noticed: Someone on GitHub put a bug report in this as well with the same issue.
                                            JohnBachini
                                            have you tried restarting the hue hub ?
                                            • 2 / 5
