    Show two weather and forecast modules on the same screen
    9 Posts 4 Posters 6.4k Views 5 Watching
    • F Offline
      frog
      As I want to see two different locations, I tried to run the currentWeather and weatherForecast modules twice in the config.js, but I don’t get the second one. I guess I’m not doing it right.
      Can anyone give me advice on how to do this?
      Regards
        bhepler Module Developer @frog
        @frog I just whipped one up and it wasn’t a problem. A couple things to check:
        • Make sure that you’re configuring the entire module twice.
        • Make sure that you put each instance of the module in a different location (top_left, bottom_left, etc.)
          Here’s an example with the calendar module:
              module: 'calendar',
              header: 'US Holidays',
              fetchInterval: 3600000,
              position: 'top_left',
                    fade: false,
                    calendars: [ {
                          symbol: 'calendar-check-o ',
                          url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics',
              module: 'calendar',
              header: 'Movie Releases',
              position: 'bottom_left',
                    fade: false,
                    calendars: [ {
                          symbol: 'imdb',
                          url: 'https://www.google.com/calendar/ical/pfutdblf1gi8jmfsvroh76f6jg%40group.calendar.google.com/public/basic.ics'
        • F Offline
          frog
          I tried just duplicating the module in config.js, but it didn’t work. Maybe it’s different for the weather modules. I’ll try again.
            @frog Don’t forget to put each copy of the module in a different location!
            • F Offline
              frog @bhepler
              @bhepler My bad, just re-entered the info in config.js and it works! thanks.
              • ? Offline
                A Former User
                What’s the movie module?
                • F Offline
                  frog @Guest
                  @wjdw87 it’s not a module, it’s a calendar. Address is in the config above
                  • ? Offline
                    A Former User
                    Much obliged, the wife sends a e-kiss (she is the movie hound).
                    Thanks!
                    • C Offline
                      canadrian
                      I see a rectangle character in front of the movie title, what can be? Thank you.
