    Troubleshooting MagicMirror
    19 Posts 5 Posters 8.0k Views 4 Watching
    • O
      OthTheGentel
      Hi guys,
      First of all, i'm new in this forum and having a beginning level on this project that I would customize it on my own.
      - First, the installation step doesn't finish correctly using the version
      Debian Stretch with Raspberry Pi Desktop (Kernel version 4.9), i got the error unable to install dependencies :
      Check current Node installation ...
      Node currently installed. Checking version number.
      Minimum Node version: v5.1.0
      Installed Node version: v8.11.1
      No Node.js upgrade necessary.
      Cloning MagicMirror ...
      Cloning into 'MagicMirror'...
      remote: Enumerating objects: 282, done.
      remote: Counting objects: 100% (282/282), done.
      remote: Compressing objects: 100% (251/251), done.
      remote: Total 282 (delta 34), reused 127 (delta 21), pack-reused 0
      Receiving objects: 100% (282/282), 385.56 KiB | 0 bytes/s, done.
      Resolving deltas: 100% (34/34), done.
      Cloning MagicMirror Done!
      Installing dependencies ...
      bash: line 112: npm: command not found
      Can I get some help from u guys?
      Thank you all
      D 1 Reply Last reply
      • D
        dazza120 @OthTheGentel
        @oththegentel delete the Magic Mirror Folder and download it again I had similar on my pi and it installed the dependence’s after that
        O 1 Reply Last reply
        • O
          OthTheGentel @dazza120
          @dazza120 thank you for your response.
          I renamed the folder and tried to install it again same error.
          Actually, i just downloaded the latest version of node and trying to install it but it takes a lot of time (waiting for headers (connection failed IP 173.209.xx.xx:80))
          Did you had the same thing? Can i just stop interrupt and go with the manual install instead of automatic??
          D B 3 Replies Last reply
          • D
            @oththegentel delete the folder and do the manual method I’m not sure if pm2 start mm work doing it that method, ie when you reboot it I did put the pm2 script in a thread on the site that worked for me, so use the manual method then reboot and see if the mirror comes back online if not look for pm2 restart
            If PM2 gives you trouble use https://forum.magicmirror.builders/topic/8987/pm2-error/13
            • D
              @oththegentel your pi up to date? Get all updates for the pi and try again
              • B
                bhepler Module Developer @OthTheGentel
                @oththegentel - You can install over top of a busted installation. Any attempts to install dependencies that you already have in place will automatically be intercepted and you’ll see a message saying that there’s nothing to install.
                It sure sounds like Node didn’t install correctly. The connection issue is probably on their end (I’m assuming your local network isn’t in the 173.209.xxx.xxx range). This is most likely temporary and once someone notices, they’ll get it back up & running. Keep trying!
                • O
                  @dazza120 Perfect thanks a lot man it’s working now.
                  So the next step, i copied the file /home/pi/MagicMirror/config/config.js.sample to /home/pi/MagicMirror/config/config.js
                  Do I have to modify the script in config.js or go to inside each folder in modules and customize them?
                  • O
                    OthTheGentel @bhepler
                    @bhepler Thanks for your help, it’s working now. I deleted the folder and installed it with the manual method :thumbs_up:
                    • O
                      OthTheGentel
                      Do I have to modify the script in config.js or go inside each folder in modules and customize them?
                      Mykle1M 1 Reply Last reply
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @OthTheGentel
                        @oththegentel said in Troubleshooting MagicMirror:
                        You should only make changes to your config.js when adding or removing the modules you want to display. It is not recommended that you modify the module files.
                        • O
                          OthTheGentel
                          @Mykle1 Thank you for your answer.
                          • Mykle1M
                            @oththegentel
                            You’re welcome, mate.
                            You might want to read this simple guide if you are unsure about adding modules to your config.js file.
                            https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                            • O
                              OthTheGentel
                              Is there any way to get an overview when I’m editing the config.js file
                              I tried a web access to pi’s ip address and port from another computer on the same network but it’s not working even if i specified the ip address of pi in address section and allowed all ip addresses in ipwhitelist section!!
                              • Mykle1M
                                @oththegentel
                                This is not working for you?
                                var config = {
                                	address: "localhost",
                                	port: 8080,
                                	ipWhitelist: [],
                                • O
                                  OthTheGentel @Mykle1
                                  @mykle1 unfortunately not.
                                  I put the wlan0 ip address of my pi instead of localhost and it’s not working neither.
                                  • Mykle1M
                                    @oththegentel
                                    Long shot:
                                    Try address: "0.0.0.0",
                                    • O
                                      @mykle1 Nope even locally
                                      I’ll scan all my ports and check if 8080 is already used
                                      D idoodlerI 2 Replies Last reply
                                      • D
                                        @oththegentel enable VNC and patch in using that, I’m doing changes on my phone using that method it’s not the best given the screen size normally I do adjustments on the Mac when I can be bothered to boot it up, last minute changes are done on the phone.
                                        • idoodlerI
                                          idoodler Module Developer @OthTheGentel
                                          @oththegentel It sounds like your MagicMirror instance is not running.
                                          How did you start MagicMirror, do you have pm2 installed?
