    MMM-voice ugly hdmi banner
    Scheduled Pinned Locked Moved Feature Requests
    42 Posts 3 Posters 26.0k Views 3 Watching
      dazza120 @sdetweil
      @sdetweil im leaving it with the ; in the command line?
        sdetweil @dazza120
        @dazza120 the example doesn’t have ;
        on_event_start /home/{userid}/MagicMirror/modules/MMM-SleepWake/external_motion started
          dazza120 @sdetweil
          @sdetweil no it this is what its like i hope this is correct?
          # Command to be executed when an event starts. (default: none)
          # An event starts at first motion detected after a period of no motion defined $
          ; on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion sta$
          # Command to be executed when an event ends after a period of no motion
          # (default: none). The period of no motion is defined by option event_gap.
          ; on_event_end value /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion$
            sdetweil
            ok, that ; is a comment in the motion conf file, just like #… have to remove it
            note that the on event end has an extra token there that neds to be removed
            on_event_end value
              dazza120 @sdetweil
              @sdetweil yes it is do i have to remove the # aswell?
                sdetweil @dazza120
                @dazza120 no, there is no # on those two lines
                  dazza120 @sdetweil
                  @sdetweil no on the two lines above it
                    sdetweil @dazza120
                    @dazza120 no, those are comments to explain what these lines do
                      dazza120 @sdetweil
                      @sdetweil ok cool so this is how i have it now
                      # An event starts at first motion detected after a period of no motion defined by event_gap
                       on_event_start /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion started
                       on_event_end /home/pi/MagicMirror/modules/MMM-SleepWake/external_motion ended
                        sdetweil @dazza120
                        @dazza120 looks good
                          dazza120 @sdetweil
                          @sdetweil thanks ive done this command chmod +x external_motion but i don’t see an outcome it just re turns to pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake
                          whole commandline below
                          pi@raspberrypi:~/MagicMirror/modules/MMM-SleepWake $ chmod +x external_motion
                            sdetweil @dazza120
                            @dazza120 right. That makes my script executable, so motion can execute it
                            Now u will see files appear in the MMM-SleepWake/motion folder
                            When the motion module detects motion, and when it ends.
                            My module uses those files
                            S 1 Reply Last reply Reply Quote 2
                              @sdetweil u start the motion tool with sudo motion &
                              And u can see it’s actions in /var/log/motion/motion.log
                              The tail command will show you the last few lines (default 20) of a file
                              D 2 Replies Last reply Reply Quote 2
                                dazza120 @sdetweil
                                @sdetweil i’ll have a look tomorrow, thanks very much for your help much appreciated for your help
                                  dazza120 @sdetweil
                                  @sdetweil not sure its supposed to look like this
                                  pi@raspberrypi:~ $ sudo motion &
                                  [1] 28276
                                  pi@raspberrypi:~ $ [0:motion] [ALR] [ALL] conf_load: could not open configfile /usr/local/etc/motion/motion.conf: No such file or directory
                                  [0:motion] [CRT] [ALL] conf_load: No config file to process, using default values
                                  [0:motion] [NTC] [ALL] motion_startup: Using default log level (NTC) (6)
                                  [0:motion] [NTC] [ALL] motion_startup: Logging to syslog
                                  [0:motion] [NTC] [ALL] motion_startup: Motion 4.2.1+git20181209-7bd179c Started
                                  [0:motion] [NTC] [ALL] motion_startup: Using default log type (ALL)
                                  [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (NTC)
                                  [0:motion] [NTC] [ENC] ffmpeg_global_init: ffmpeg libavcodec version 57.64.101 libavformat version 57.56.101
                                  [0:motion] [NTC] [ALL] translate_init: Language: English
                                  [0:motion] [NTC] [ALL] motion_start_thread: Camera ID: 0 Camera Name: (null) Device: /dev/video0
                                  [0:motion] [NTC] [ALL] main: Waiting for threads to finish, pid: 28281
                                  [1:ml1] [NTC] [ALL] motion_init: Camera 0 started: motion detection Enabled
                                  [1:ml1] [NTC] [VID] vid_start: Opening V4L2 device
                                  [1:ml1] [NTC] [VID] v4l2_device_open: Using videodevice /dev/video0 and input -1
                                  [1:ml1] [NTC] [VID] v4l2_device_capability: - VIDEO_CAPTURE
                                  [1:ml1] [NTC] [VID] v4l2_device_capability: - READWRITE
                                  [1:ml1] [NTC] [VID] v4l2_device_capability: - STREAMING
                                  [1:ml1] [NTC] [VID] v4l2_input_select: Name = "ov534"- CAMERA
                                  [1:ml1] [NTC] [VID] v4l2_norm_select: Device does not support specifying PAL/NTSC norm
                                  [1:ml1] [NTC] [VID] v4l2_pixfmt_select: Configuration palette index 17 (YU12) for 640x480 doesn't work.
                                    mdhenriksen @dazza120
                                    @dazza120 Hey Dazza. Post it in the code-block you can use in the editor. Otherwise it’s hard to read your code/output.
                                      dazza120 @mdhenriksen
                                      @mdhenriksen not sure why it came out like that but i am doing it via vnc on my phone lol thank you that should be sorted now
                                        sdetweil @dazza120
                                        @dazza120 Hm… mine says
                                        [-1191364720:motion] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motion/motion.conf
                                          dazza120 @sdetweil
                                          @sdetweil hi for some reason I have no motion.conf file in there, but I was getting tones of video clips stored in /home/Pi folder, can you tell me the best remove command for motion project as I’ll start again from scratch and looking at one of the files in the home/Pi folder it said
                                          Install complete! The default configuration file, motion-dist.conf, has been
                                          installed to /usr/local/etc/motion. You need to rename/copy it to motion.conf
                                          for Motion to find it. More configuration examples as well as init scripts
                                          can be found in /usr/local/share/motion/examples.
                                            sdetweil @dazza120
                                            @dazza120 weird… if u installed with
                                            apt-get install motion
                                            then the command is
                                            apt-get --purge remove motion
                                            • 2 / 3
