    Installing on a Pi Zero
    175 Posts 33 Posters 258.6k Views 33 Watching
      Dimasua
      @andyc7687 Thank you for your work and sharing with the community!
      I would like to try it with a Raspberry Pi3A+. Will it work?
        sdetweil @Dimasua
        @Dimasua use my installer script, listed as alternative install method , see
          Dimasua @sdetweil
          @sdetweil Another question, how I can restart the mirror from the command line? Didn’t find that information.
            sdetweil @Dimasua
            @Dimasua if u said yes to pm2,
            pm2 start 0
            If it does not start on boot, the run the fixuppm2 script from my site,
            If not pm2, then npm start from the MagicMirror folder
              stanvv
              I’ve used quite some of these manuals before, most without succes cause after a few weeks they all seem to crash/freeze screen. Finally I have a setup that’s working:
              • install raspian lite
              • use this script to install MM: https://github.com/pureartisan/magic-mirror-raspbian-lite
              • update npm with npm install -g electron --unsafe-perm=true --allow-root
              • increase swap
              sudo dphys-swapfile swapoff
              sudo nano /etc/dphys-swapfile
              CONF_SWAPSIZE=1024
              sudo dphys-swapfile setup
              sudo dphys-swapfile swapon
              sudo reboot
              • adjust /boot/config.txt with the following settings for overclock:
              arm_freq=1085
              gpu_freq=530
              over_voltage=8
              sdram_freq=500
              over_voltage_sdram=1
              • I also monitor the behaviour of the RPI’s performance in Home Assistant (in case it would crash, I have an indicator what went wrong) with: https://github.com/Sennevds/system_sensors
              So far it -finally- works like a charm!
              S ebolisaE 2 Replies Last reply Reply Quote 0
                sdetweil @stanvv
                @stanvv shoulda just used my script
                • ebolisaE Offline
                  ebolisa @stanvv
                  @stanvv hi, that install was done on a P0, right?
                    sdetweil @ebolisa
                    @ebolisa just use my script
                    Mykle1M ebolisaE 2 Replies Last reply Reply Quote 0
                      @sdetweil said in Installing on a Pi Zero:
                      just use my script
                      Amen to that.
                      • ebolisaE Offline
                        ebolisa @sdetweil
                        @sdetweil but which one exacly? I had MM running on P4 but the heat produced by the processor, the screen and its electronics, has pushed me to try out MM on a P0. With that, I should resolve the heat issue.
                        So, after reading several outdated procedures and after investing hours (as you know, P0 is as slow as hell) I’m back to square one.
                        Which steps should I take from scratch?
                        Which SO should I start with?
                        Which install batch should I install?
                        @stanvv’s procedure worked till I had to reboot, then the X server stopped responding :angry_face:
                          sdetweil @ebolisa
                          @ebolisa what does it say?
                          to install do this
                          to update do this
                          u want to install, so u do the 1st
                          make sure to remove the MagicMirror folder, cause the script is starting from the beginning
                          ebolisaE 1 Reply Last reply Reply Quote 0
                          • ebolisaE Offline
                            ebolisa @sdetweil
                            @sdetweil ok. Done the following with no avail.
                            Removed MagicMirror folder
                            Ran the install script. No errors. It did an autoreboot but no go.
                            Reviewed the install_log… no errors.
                            Did notice, however, the script created 3 folders:
                            MagicMirror
                            magic-mirror
                            magic-mirror-app
                            At reboot, the X server intent to start but incounters some errors and shuts down with the message: Server terminated successfully (0). Closing log file.
                            Where do I go from here?
                            TIA
                            EDIT:
                            Here’s the Xorg log:
                            [    64.036]
                            X.Org X Server 1.20.4
                            X Protocol Version 11, Revision 0
                            [    64.101] Build Operating System: Linux 5.4.0-54-generic armv8l Raspbian
                            [    64.123] Current Operating System: Linux magicmirror 5.10.11+ #1399 Thu Jan        28 12:02:28 GMT 2021 armv6l
                            [    64.123] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.e        nable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1280 bcm2708_fb        .fbheight=1024 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:7C:38:09 vc_mem.mem        _base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 r        oot=PARTUUID=a27be534-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootw        ait
                            [    64.220] Build Date: 15 January 2021  02:03:57PM
                            [    64.243] xorg-server 2:1.20.4-1+rpt2+deb10u3 (https://www.debian.org/support        )
                            [    64.265] Current version of pixman: 0.36.0
                            [    64.311]    Before reporting problems, check http://wiki.x.org
                                    to make sure that you have the latest version.
                            [    64.314] Markers: (--) probed, (**) from config file, (==) default setting,
                                    (++) from command line, (!!) notice, (II) informational,
                                    (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
                            [    64.415] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Feb 15 18:44:41 202        1
                            [    64.455] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
                            [    64.471] (==) No Layout section.  Using the first Screen section.
                            [    64.471] (==) No screen section available. Using defaults.
                            [    64.471] (**) |-->Screen "Default Screen Section" (0)
                            [    64.471] (**) |   |-->Monitor "<default monitor>"
                            [    64.494] (==) No monitor specified for screen "Default Screen Section".
                                    Using a default monitor configuration.
                            [    64.495] (==) Automatically adding devices
                            [    64.496] (==) Automatically enabling devices
                            [    64.496] (==) Automatically adding GPU devices
                            [    64.503] (==) Max clients allowed: 256, resource mask: 0x1fffff
                            [    64.517] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
                            [    64.517]    Entry deleted from font path.
                            [    64.517] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
                            [    64.518] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
                            [    64.518]    Entry deleted from font path.
                            [    64.518] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
                            [    64.518] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
                            [    64.518] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
                            [    64.519]    Entry deleted from font path.
                            [    64.519] (==) FontPath set to:
                                    /usr/share/fonts/X11/misc,
                                    built-ins
                            [    64.519] (==) ModulePath set to "/usr/lib/xorg/modules"
                            [    64.519] (II) The server relies on udev to provide the list of input devices        .
                                    If no devices become available, reconfigure udev or disable AutoAddDevic        es.
                            [    64.519] (II) Loader magic: 0x1fdf80
                            [    64.519] (II) Module ABI versions:
                            [    64.519]    X.Org ANSI C Emulation: 0.4
                            [    64.519]    X.Org Video Driver: 24.0
                            [    64.522]    X.Org XInput driver : 24.1
                            [    64.522]    X.Org Server Extension : 10.0
                            [    64.538] (--) using VT number 2
                            [    64.538] (II) systemd-logind: logind integration requires -keeptty and -keep        tty was not provided, disabling logind integration
                            [    64.542] (II) no primary bus or device found
                            [    64.545] (II) LoadModule: "glx"
                            [    64.556] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
                            [    64.656] (II) Module glx: vendor="X.Org Foundation"
                            [    64.657]    compiled for 1.20.4, module version = 1.0.0
                            [    64.657]    ABI class: X.Org Server Extension, version 10.0
                            [    64.657] (==) Matched modesetting as autoconfigured driver 0
                            [    64.657] (==) Matched fbdev as autoconfigured driver 1
                            [    64.657] (==) Assigned the driver to the xf86ConfigLayout
                            [    64.657] (II) LoadModule: "modesetting"
                            [    64.664] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
                            [    64.674] (II) Module modesetting: vendor="X.Org Foundation"
                            [    64.675]    compiled for 1.20.4, module version = 1.20.4
                            [    64.675]    Module class: X.Org Video Driver
                            [    64.675]    ABI class: X.Org Video Driver, version 24.0
                            [    64.675] (II) LoadModule: "fbdev"
                            [    64.682] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
                            [    64.689] (II) Module fbdev: vendor="X.Org Foundation"
                            [    64.690]    compiled for 1.20.3, module version = 0.5.0
                            [    64.690]    Module class: X.Org Video Driver
                            [    64.690]    ABI class: X.Org Video Driver, version 24.0
                            [    64.693] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
                            [    64.693] (II) FBDEV: driver for framebuffer: fbdev
                            [    64.719] (WW) Falling back to old probe method for modesetting
                            [    64.719] (EE) open /dev/dri/card0: No such file or directory
                            [    64.720] (WW) Falling back to old probe method for fbdev
                            [    64.720] (II) Loading sub module "fbdevhw"
                            [    64.720] (II) LoadModule: "fbdevhw"
                            [    64.721] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
                            [    64.729] (II) Module fbdevhw: vendor="X.Org Foundation"
                            [    64.729]    compiled for 1.20.4, module version = 0.0.2
                            [    64.730]    ABI class: X.Org Video Driver, version 24.0
                            [    64.734] (II) FBDEV(0): using default device
                            [    64.734] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
                            [    64.739] (II) FBDEV(0): Creating default Display subsection in Screen sectio        n
                                    "Default Screen Section" for depth/fbbpp 24/32
                            [    64.739] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
                            [    64.739] (==) FBDEV(0): RGB weight 888
                            [    64.743] (==) FBDEV(0): Default visual is TrueColor
                            [    64.762] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
                            [    64.763] (II) FBDEV(0): hardware: BCM2708 FB (video memory: 5120kB)
                            [    64.763] (DB) xf86MergeOutputClassOptions unsupported bus type 0
                            [    64.763] (II) FBDEV(0): checking modes against framebuffer device...
                            [    64.763] (II) FBDEV(0): checking modes against monitor...
                            [    64.764] (II) FBDEV(0): Virtual size is 1280x1024 (pitch 1280)
                            [    64.764] (**) FBDEV(0):  Built-in mode "current"
                            [    64.764] (==) FBDEV(0): DPI set to (96, 96)
                            [    64.764] (II) Loading sub module "fb"
                            [    64.764] (II) LoadModule: "fb"
                            [    64.765] (II) Loading /usr/lib/xorg/modules/libfb.so
                            [    64.787] (II) Module fb: vendor="X.Org Foundation"
                            [    64.787]    compiled for 1.20.4, module version = 1.0.0
                            [    64.787]    ABI class: X.Org ANSI C Emulation, version 0.4
                            [    64.787] (**) FBDEV(0): using shadow framebuffer
                            [    64.787] (II) Loading sub module "shadow"
                            [    64.787] (II) LoadModule: "shadow"
                            [    64.788] (II) Loading /usr/lib/xorg/modules/libshadow.so
                            [    64.796] (II) Module shadow: vendor="X.Org Foundation"
                            [    64.796]    compiled for 1.20.4, module version = 1.1.0
                            [    64.801]    ABI class: X.Org ANSI C Emulation, version 0.4
                            [    64.801] (II) UnloadModule: "modesetting"
                            [    64.801] (II) Unloading modesetting
                            [    64.838] (==) FBDEV(0): Backing store enabled
                            [    64.845] (==) FBDEV(0): DPMS enabled
                            [    64.847] (II) Initializing extension Generic Event Extension
                            [    64.852] (II) Initializing extension SHAPE
                            [    64.865] (II) Initializing extension MIT-SHM
                            [    64.877] (II) Initializing extension XInputExtension
                            [    64.888] (II) Initializing extension XTEST
                            [    64.897] (II) Initializing extension BIG-REQUESTS
                            [    64.905] (II) Initializing extension SYNC
                            [    64.913] (II) Initializing extension XKEYBOARD
                            [    64.921] (II) Initializing extension XC-MISC
                            [    64.930] (II) Initializing extension SECURITY
                            [    64.937] (II) Initializing extension XFIXES
                            [    64.947] (II) Initializing extension RENDER
                            [    64.955] (II) Initializing extension RANDR
                            [    64.974] (II) Initializing extension COMPOSITE
                            [    64.981] (II) Initializing extension DAMAGE
                            [    64.992] (II) Initializing extension MIT-SCREEN-SAVER
                            [    65.000] (II) Initializing extension DOUBLE-BUFFER
                            [    65.007] (II) Initializing extension RECORD
                            [    65.016] (II) Initializing extension DPMS
                            [    65.025] (II) Initializing extension Present
                            [    65.032] (II) Initializing extension DRI3
                            [    65.035] (II) Initializing extension X-Resource
                            [    65.042] (II) Initializing extension XVideo
                            [    65.053] (II) Initializing extension XVideo-MotionCompensation
                            [    65.054] (II) Initializing extension SELinux
                            [    65.054] (II) SELinux: Disabled on system
                            [    65.058] (II) Initializing extension GLX
                            [    65.065] (II) AIGLX: Screen 0 is not DRI2 capable
                            [    68.618] (II) IGLX: Loaded and initialized swrast
                            [    68.620] (II) GLX: Initialized DRISWRAST GL provider for screen 0
                            [    68.621] (II) Initializing extension XFree86-VidModeExtension
                            [    68.628] (II) Initializing extension XFree86-DGA
                            [    68.637] (II) Initializing extension XFree86-DRI
                            [    68.641] (II) Initializing extension DRI2
                            [   118.828] (II) Server terminated successfully (0). Closing log file.
                              sdetweil @ebolisa
                              @ebolisa i would rebuild the sd card and start again
                              • ebolisaE Offline
                                ebolisa @sdetweil
                                @sdetweil I agree but which OS should I use? The lite one?
                                  sdetweil @ebolisa
                                  @ebolisa full desktop
                                  • ebolisaE Offline
                                    ebolisa @sdetweil
                                    @sdetweil Thank you! Finally got it going. I had to change the SD card.
                                    Now I can finally replace my P4 with the P0. The P4, along with the display, are causing heat related problems so, P0 to the rescue.
                                    Just FYI, I cannot hide the cursor and sudo apt-get install unclutter didn’t help.
                                      sdetweil @ebolisa
                                      @ebolisa in css/main.css body should have cursor:none
                                      you are running chromium-browser, not electron, but should have been the same
                                        sdetweil @ebolisa
                                        @ebolisa pi0 doesnt have a lot of power, so beware running too much…
                                        check swap space usage
                                        free -m
                                        to see if it needs to be made bigger
                                        • ebolisaE Offline
                                          ebolisa @sdetweil
                                          @sdetweil Yes, I set swap to 1024. It’s slow but it works.
                                          Thanks again!!
                                            RushHour99
                                            @sdetweil , I went through a fresh SD card install for a Pi Zero W. raspbian and then the raspberry.sh script via your github page. I believe everything completed without error.
                                            However when Magic Mirror launches on reboot, I get a blank page indicating:
                                            This site can’t be reached
                                            localhost refused to connect
                                            Any idea what to do to troubleshoot?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 8 / 9
