    Can’t find a calendar that works
    calendar
    14 Posts 4 Posters 6.4k Views 4 Watching
      scoller
      I been trying to find calendars that fit me and then copy paste the url but it doesn’t show up under calendar. I dont know what type of calendar to use. PLEASE help.
        MadScientist
        Google calendar? In your Google account you should find somewhere a calender link in this format https://calendar.google.com/calendar/ical/.../private-...../basic.icsthat works for sure. I am using it on my mirror. Nextcloud/Owncloud also works if you want to run your calendar locally.
          scoller @MadScientist
          @madscientist thanks I will try that
            @madscientist My url is taking me to the sign in page/log in page even though im logged in when I copy the url
              mdhenriksen @scoller
              @scoller You are not using the right URL then. Could you post your config here so we can see?
                scoller @mdhenriksen
                @mdhenriksen sure
                  scoller
                  here is the code for the calendar:
                  symbol: “calendar-check”,
                  url: “https://calendar.google.com/calen”
                    scoller
                    This post is deleted!
                      scoller @scoller
                      @scoller i edited the url so it don’t work because I don’t want everyone in my google acount. Hope you still can help me @mdhenriksen
                      • lavolp3L Offline
                        lavolp3 Module Developer @scoller
                        @scoller It would have been better to delete the middle part.
                        The tyoe of ending is important. Does the url end in a basic.ics?
                        Also can you please go into the console type in
                        pm2 logs
                        and give us the output that is referring to the calendar module?
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
                          scoller @lavolp3
                          @lavolp3 the url did not end with .ical it ended with calendar.m
                          • lavolp3L Offline
                            @scoller I think only .ics calendars work but not sure.
                            You can also use an ics calendar from google and try that.
                            • Go into your google calendar webpage.
                            • Click on the three dots on one of the calendars in the left bar (the one with your name preferably) and then click on options.
                            • Scroll down and find your “private address in ical format”.
                            Use that address in your config.
                              MadScientist
                              I was just about to post the exact same as @lavolp3. That should work for sure.
                                scoller @lavolp3
                                @lavolp3 ok what am i looking for?
