    ipwhitelist - a lot of issues... can't connect remotely ..
    4 Posts 3 Posters 1.8k Views 2 Watching
    • B
      Big11
      Some days now, i try to get my MM running on a Raspberry (Zero, B3A+) but without Access
      two main issues occurs…
      i can’t access remotly …
      whatever i tried in “config.js”
      this is what i tried
      var config = {
      address: “localhost”, // Address to listen on, can be:
      // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
      // - “”, “0.0.0.0”, “::” to listen on any interface
      // Default, when address config is left out, is “localhost”
      port: 8080,
      ipwhitelist: [],
      //ipWhitelist: [“::fff:0.0.0.0/1”, “::fff:0.8.0.0/1”, “::fff:128.0.0.0/2”, “::fff:192.0.0.0/3”, “::fff:224.0.0.0/4”, “127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.2.54”],
      //ipWhitelist: [“::ffff:192.168.2.1/120”, “127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
      for Explanation my Home LAN is addressed with 192.168.2.x…
      i have installed it with PM2
      if i start it locally with
      startx (cause “chromium-browser -Kiosk http://localhost:8080” gives an GTK-Error) and after that
      DISPLAY=:0 chromium-browser -Kiosk http://localhost:8080" it starts but give me an Warn Message that Address “localhost” is already in use …
      any Ideas…
      The last entrys for “ipwhitelist” i found were form one year ago…
      basicliy i want to start it jast locally on my Pi …
      • P
        Plati
        @big11 said in ipwhitelist - a lot of issues... can't connect remotely ..:
        Try change address: “localhost” to “0.0.0.0”
        B 1 Reply Last reply
        • B
          bhepler Module Developer
          And please use the Markdown features of the board when pasting code or logs.
          • B
            Big11 @Plati
            @plati
            got it … thank you…
            but the ipwhitelist Parameter are not very handsome
            so i did a
            ipwhitelist: [],
            and that works…
            further i will look for the correct Syntax to grant Access for Special addresses outside my LAN…
