    has anyone used any of the charting tools, like chartjs?
    18 Posts 5 Posters 6.9k Views 5 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @sdetweil
      @sdetweil Well well I was googling “chartjs” about the minute you wrote this down today! Ha! Great.
      I’d like to use it to make some amendments to MMM-rain-forecast and maybe get in my own graph.
      Have you seen MMM-chart, a MM cahrt template, which also seems to have examples of applications like yours.
      I haven’t taken a close look into any of it but I’ll do soon.
      Cheers and good luck!
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        sdetweil @lavolp3
        @lavolp3 said in has anyone used any of the charting tools, like chartjs?:
        MMM-chart,
        thanks… my data does not come back in JSON… but as CSV. with a unix milliseconds timestamp.
        one data set is a float value (could be truncated to int), one is an int.
          ok, well, this was user error…
          while I had an array for time based points, ONE element in the array was JUST a single value.
          this caused the charting tool to act weird…
          fixing the one data point resolved the issue…
          now, I want to change the color of the fill area under certain conditions (low reservoir, or constant running water) to alert about trouble to be resolved…looks like that is some custom extension i have to write…
            sdetweil
            here are some pics of the two charts
            two charts upper right
            two
            two charts closer view
            two closer
            one chart
            one chart
            lavolp3L 1 Reply Last reply Reply Quote 2
            • lavolp3L Offline
              @sdetweil Looking good! How did you realize it? MMM-Chart? Chartjs and your own module?
                sdetweil @lavolp3
                @lavolp3 using chartjs and my own module. my data is not in JSON format required by MMM-Charts
                here is the chartjs code
                i have an structure, with arrays of points (by the sensor value), javascript Date, and value.
                there are also arrays that contain the axis labels.
                make div for chart
                	var c = document.createElement("div");
                	c.style.width=self.config.width+"px";
                  	c.style.height=self.config.height+"px";
                	if(!self.config.stacked)
                	   c.style.display='inline-block';
                	self.wrapper.appendChild(c);
                        canvas= document.createElement("canvas");
                 	canvas.id="myChart"+this_pin;
                        c.appendChild(canvas);
                for(var pin_index=0;
                      pin_index < self.config.Pins.length;  (how do you do less than in markup?, space after < )
                      pin_index++)
                var this_pin=self.config.Pins[pin_index];
                       self.charts[pin_index] = new Chart(canvas, {
                              type: 'line',
                              showLine: true,
                              data: {
                                datasets: [
                		    xAxisID: 'dates',
                                    data: self.data[this_pin],
                                    fill:true,
                                    borderColor: '#2196f3',
                   		    backgroundColor: '#2196f3',
                              options:	 {
                			legend: { display: false},
                			tooltips: {
                			    enabled: false,
                			    displayColors: false
                			responsive: false,
                			elements: {
                			    point: { radius: 0 },
                			    line: {
                        		        tension: 0, // disables bezier curves
                                scales: {
                                  xAxes: [{
                                    type: 'time',
                			distribution: 'linear',
                                    scaleLabel: {
                                        display: true,
                                        labelString: self.config.labels[pin_index]+" - last "+self.config.dayrange+" days",
                			fontColor: 'white'
                			gridLines: {
                				display: false,
                				zeroLineColor: '#ffcc33'
                  		        time: {
                      		              unit: 'minute'
                			bounds: 'data',
                                    ticks: {
                			display: false ,
                			maxRotation: 90,
                			source: 'data',
                			maxTicksLimit: self.data[this_pin].length,                    },
                                  yAxes: [{
                                        display: true,
                                        scaleLabel: {
                                            display: true,
                                            labelString: self.config.yaxis_legend[pin_index],
                			    fontColor: 'white'
                			gridLines: {
                			   display: true,
                			   color: "#FFFFFF",
                			   zeroLineColor: '#ffcc33',
                			   fontColor: 'white',
                                           scaleFontColor: 'white',
                                    ticks: {
                			beginAtZero: true,
                			source: 'data',
                                        min: 0,
                			fontColor: 'white'
                lavolp3L 1 Reply Last reply Reply Quote 1
                • lavolp3L Offline
                  @sdetweil Thanks for sharing!!
                  I’ll try that out with the rain-forecast module
                    sdetweil @lavolp3
                    @lavolp3 i have over 4000 measurements in each chart. (3 days, once a minute)
                    still pretty reasonable performance.
                    update once every 5 minutes, or when come back from sleeping (no updates while MM is asleep).
                      I have updated the code now to improve performance…
                      • reduce number of data points, by decimation (using 1 point of every 5) to get to 800 points. See info once every 5th minutes, vs once a minute
                      • build 800 point data from in memory CSV (api sends back csv data) by looking from NOW (end) til previous (backwards) which reduces the number of lines of data processed from 14000 to 4000 (configurable number of days for chart)
                      • create a color gradient table start-end: color, start-end:color2… to draw multiple colors on chart, as part of the data selection in 1 and 2 above… this make the processor O(1) (single pass), instead of O(4)
                      performance is much improved…
                      prior, 4000 points, elapsed time for 2 charts, 39 seconds. now 3.5 seconds (odroid). pi crashed with 4000 points at 4 minutes elapsed… now just about 4.5 seconds
                        I have no idea what you just said but I upvoted your post anyway. :-)
