    Magic mirror first try (France, ~Lille)
    50 Posts 16 Posters 46.4k Views 14 Watching
      MilkShake
      @mmourcia said in Magic mirror first try (France, ~Lille):
      @MilkShake
      Why is the display_power involved in this?
      It’s not. This is just my conf and i did not sanitize it
      Ok :)
      When you write “Conf on doorbird in http visit”, is that the HTPPS(S) calls part of the Doorbird config?
      Yes it is
      Perfect. Where did you find the documentation for the URLs?
      I take it that I need a carillon.wav file in the MMM-Sounds/sounds directory or change the wav part to one of the default wav files like buzz.wav?
      Yes you’re right
      ok, so I can use the buzz.wav until it works.
      The call “http://IP_MM:8080/remote?action=SHOW&module=module_XX_MMM-iFrame-Ping” is that correct? Does it need the XX part?
      It is in fact the index of the module in your conf. You must guess it
      Guess it? Index of the module, is that the modules position within config.js?
        MilkShake @mmourcia
        @MilkShake
        I think it is me missing some information? Is the MMM-Remote-Control involved in any way API wise?
        Does it function the way, that when someone pushes the button on the doorbird, the doorbird makes a http call to the Mirror for the notification, and to enable the MMM-iFrame-Ping module? For how long is the iFrame module visible after someone pushes the button?
        Thanks dude!
          MilkShake @mmourcia
          http://IP_MM:8080/remote?action=NOTIFICATION&notification=PLAY_SOUND&payload=%7B%22sound%22%3A%22carillon.wav%22%2C%22delay%22%3A100%7D
          I think there is an error in the URL. Funny thing is, when I look at your URL is states:
          http://IP_MM:8080/remote?action=NOTIFICATION¬ification=PLAY_SOUND&payload=%7B%22sound%22%3A%22carillon.wav%22%2C%22delay%22%3A100%7D
          When i quote you it states the correct thing:
          NOTIFICATION & notification (without the spaces)
            mmourcia @MilkShake
            @MilkShake
            Yes, I lt you find answers by yourself ;)
            Try some different conf and i’m sure you’ll find the one that you need !
            Regards
              MilkShake
              Yeah, I’m not so sure. I can’t get it to work :)
              • L Offline
                lodam
                @mmourcia , bravo pour votre installation !
                J’ai débuté hier et ai bcp encore à découvrir mais votre exemple m’encourage
                J’ai enfin pu connecter mon agenda apple et ça m’a pris qq heures… :)
                bonne journée
                damien
                  mmourcia @lodam
                  @lodam
                  Tant mieux si cela vous aide !
                    MilkShake @MilkShake
                    Could you give me a hint to find that number?
                      mmourcia @MilkShake
                      @MilkShake
                      Maybe you could use MODULE_ACTION of remote module.
                      => http(s)://ip:8080/remote?action=MODULE_DATA
                      That will return all informations about your modules including their names.
                        MilkShake
                        Thanks man. I think I’ll keep the feed open for the camera and use the MMM-Sounds for notification when someone pushes the button. That is, if I can get it to work :)
                        But a nice way to get the module data, thanks!
                        • 3 / 3
