    Compliments config
    7 Posts 4 Posters 2.7k Views 4 Watching
      dgregory19
      How do you change the default compliments. Where are they. I don’t see them under compliments module. They must be somewhere if they are showing up when MM is running.
        Mykle1 Project Sponsor Module Developer @dgregory19
        @dgregory19
        They are in the config.js file. You can change them there or use a remote file. The README file for compliments has all the instructions
          dgregory19 @Mykle1
          @mykle1 Found my problem. Thanks for the help. Read your “absolute-beginners” topics. Huge help!
            @dgregory19
            Ahhh cool. :thumbsup:
              motdog
              I went out and found https://gist.github.com/ryck/e28a69665b8839f6e9a7acd6b4acc97d (which is awesome)
              I modified and removed what I didn’t want, but I left the weather stuff in even though I haven’t configured the default weather module.
              I then created https://github.com/motdog/compliments/blob/master/compliments.json
              I went into compliments.js and at remote file removed null and added that link followed by a comma.
              It didn’t run when I restarted my mirror. Do I need to change anything on main config.
              Module.register("compliments", {
              	// Module config defaults.
              	defaults: {
              		compliments: {
              			anytime: [
              				"Hey there sexy!"
              			morning: [
              				"Good morning, handsome!",
              				"Enjoy your day!",
              				"How was your sleep?"
              			afternoon: [
              				"Hello, beauty!",
              				"You look sexy!",
              				"Looking good today!"
              			evening: [
              				"Wow, you look hot!",
              				"You look nice!",
              				"Hi, sexy!"
              		updateInterval: 30000,
              		remoteFile: https://github.com/motdog/compliments/blob/master/compliments.json,
              		fadeSpeed: 4000,
              		morningStartTime: 3,
              		morningEndTime: 12,
              		afternoonStartTime: 12,
              		afternoonEndTime: 17
              Thanks for the help
                sdetweil @motdog
                @motdog that is not config, that looks like the source for compliments.js, and only a little bit of the source
                  motdog @sdetweil
                  @sdetweil ok I am so confused. I took an existing list of compliments and saved/edited it. I then saved it as a .json file (or so I thought) . I went to the default modules folder and changed remote folder from null to that web address.
                  I thought that was the way to go about it. Never created anything in github before. so Im grasping at straws
