    raspberry-pi alternatives
    39 Posts 13 Posters 34.3k Views 14 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer
      Or go with another Linux distro… I installed it on a computer and installed the mirror on it… worked pretty good and MUCH faster :)
      • lolobyteL Offline
        lolobyte @tajno
        @tajno
        do a cron job to restart your raspi every night!
          amanzimdwini @cowboysdude
          @cowboysdude
          • any SHORT intro on how to put a MM onto an old laptop with Ubuntu running on it?
            I have it on two Pis (2 and 3); managed to get it onto a Win10 box - Ubuntu is next :)
            cowboysdude Module Developer @amanzimdwini
            @amanzimdwini Installing MM is easy on Unbuntu.
            I downloaded it and unpacked it into MagicMirror folder then in a terminal window:
            npm install
            npm start
            Starts right up no issues :)
            Pretty much everything works just as it did on a Pi except it’s a lot faster :)
            A Mykle1M 2 Replies Last reply Reply Quote 1
              @cowboysdude It was nearly that easy… on LTS 16.04 on an ancient Dell:
              sudo npm install (failed)
              sudo apt install nodejs-legacy
              sudo npm install (succeeded)
              npm start
              -> Please create a config.js file
              Thanks for the help!
              Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 1
                Mykle1 Project Sponsor Module Developer @cowboysdude
                @cowboysdude said in raspberry-pi alternatives:
                So you’re running it on a Windows machine? I ask because I am too, only without being able to use the sudo command in Windows, some dependencies installations won’t work. i.e. MMM-voice. I really want to make a laptop MMM-NFL machine (with MMM-voice) for my son-in-law but that is the problem I am running into.
                So, have you used MMM-voice on anything other than a Raspberry Pi?
                  Mykle1 Project Sponsor Module Developer @amanzimdwini
                  @amanzimdwini said in raspberry-pi alternatives:
                  npm start
                  I may try this. I’ve got MM running on an old Compaq laptop. As you can see from my post above, I can’t install the dependencies for MMM-voice because sudo isn’t recognized by WIndows and is required by the dependency installer. However, if I do as you did and make it an uBuntu machine, that might make life easier for me.
                  Anyway, I’ve got nothing to lose by trying, except a little time
                    cowboysdude Module Developer @Mykle1
                    @Mykle1 said in raspberry-pi alternatives:
                    I would format the laptop and install Unbuntu and run MM on that… I have a mini-itx with a 120G SD running Unbuntu and my 32" mirror… works well and you have the terminal window to install just as you would on a Pi… works great! :)
                    You can do in Windows10 but it takes more work… In Windows10 there is Bash on Unbuntu on Windows you just have to turn it on :)
                    I just Unbuntu. I did order an IR frame yesterday and under Windows it would be a 6 points of touch but under Linux it’s one… but still I’m happy with that :)
                      It’s funny, because uBuntu is where this all started for me (See my story in Show Your MIrror) so I shouldn’t have much trouble backtracking to that
                      cowboysdudeC A 2 Replies Last reply Reply Quote 1
                        @Mykle1 Which is REALLY funny because it was where I started too! :)
                        • 3 / 4
