    raspberry-pi alternatives
    39 Posts 13 Posters 41.6k Views 14 Watching
    • A
      alexyak @Guest
      @wjdw87 of course it wouldn’t run Raspbian because it’s built specifically for RPI. I’d stay with Windows.
        A Former User @alexyak
        @alexyak sorry, i was not clear. No Linux Distros will install. . they also have android out of the box version and you can change over.
        The problem is their jerry rigged bios.
        Their android or windows packages at specific to the boxes, no installing of USB/other for they are not built for the boxes
        Further the windows is only 32 bit, and the android does have 64 bit, admittedly
        • cowboysdudeC
          Or go with another Linux distro… I installed it on a computer and installed the mirror on it… worked pretty good and MUCH faster :)
          • L
            lolobyte @tajno
            @tajno
            do a cron job to restart your raspi every night!
            • A
              amanzimdwini @cowboysdude
              @cowboysdude
              • any SHORT intro on how to put a MM onto an old laptop with Ubuntu running on it?
                I have it on two Pis (2 and 3); managed to get it onto a Win10 box - Ubuntu is next :)
              • cowboysdudeC
                cowboysdude Module Developer @amanzimdwini
                @amanzimdwini Installing MM is easy on Unbuntu.
                I downloaded it and unpacked it into MagicMirror folder then in a terminal window:
                npm install
                npm start
                Starts right up no issues :)
                Pretty much everything works just as it did on a Pi except it’s a lot faster :)
                A Mykle1M 2 Replies Last reply Reply Quote 1
                • A
                  @cowboysdude It was nearly that easy… on LTS 16.04 on an ancient Dell:
                  sudo npm install (failed)
                  sudo apt install nodejs-legacy
                  sudo npm install (succeeded)
                  npm start
                  -> Please create a config.js file
                  Thanks for the help!
                  Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 1
                  • Mykle1M
                    @cowboysdude said in raspberry-pi alternatives:
                    So you’re running it on a Windows machine? I ask because I am too, only without being able to use the sudo command in Windows, some dependencies installations won’t work. i.e. MMM-voice. I really want to make a laptop MMM-NFL machine (with MMM-voice) for my son-in-law but that is the problem I am running into.
                    So, have you used MMM-voice on anything other than a Raspberry Pi?
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @amanzimdwini
                      @amanzimdwini said in raspberry-pi alternatives:
                      npm start
                      I may try this. I’ve got MM running on an old Compaq laptop. As you can see from my post above, I can’t install the dependencies for MMM-voice because sudo isn’t recognized by WIndows and is required by the dependency installer. However, if I do as you did and make it an uBuntu machine, that might make life easier for me.
                      Anyway, I’ve got nothing to lose by trying, except a little time
                      • cowboysdudeC
                        @Mykle1 said in raspberry-pi alternatives:
                        I would format the laptop and install Unbuntu and run MM on that… I have a mini-itx with a 120G SD running Unbuntu and my 32" mirror… works well and you have the terminal window to install just as you would on a Pi… works great! :)
                        You can do in Windows10 but it takes more work… In Windows10 there is Bash on Unbuntu on Windows you just have to turn it on :)
                        I just Unbuntu. I did order an IR frame yesterday and under Windows it would be a 6 points of touch but under Linux it’s one… but still I’m happy with that :)
                        • Mykle1M
                          It’s funny, because uBuntu is where this all started for me (See my story in Show Your MIrror) so I shouldn’t have much trouble backtracking to that
                          cowboysdudeC A 2 Replies Last reply Reply Quote 1
                          • cowboysdudeC
                            @Mykle1 Which is REALLY funny because it was where I started too! :)
                            • Mykle1M
                              Which is REALLY REALLY funny because that means there is hope for me ;-)
                              • cowboysdudeC
                                npm start
                                Well in doing this so much sometimes forget to add little extra instructions…sorry!
                                Glad you got it working but it does work well!
                                • cowboysdudeC
                                  The fact that you refuse to give up means there is MUCH hope for you!! I think you’re doing quite well!!! Two months ago I wouldn’t even think to write a module… now I am working on them all the time… improving… tweaking… making new ones… I don’t release all of them but I make them :)
                                  • johnnyboyJ
                                    johnnyboy @alexyak
                                    • W
                                      wizz
                                      Just wondering if it is possible to run the MM on this Banana Pi or on this ASUS Tinker Board and if any one tried that with good or bad results?
                                      • Y
                                        yawns Moderator @wizz
                                        @wizz said in raspberry-pi alternatives:
                                        If there is a nodejs version around, the MM will run. Not out of the box, but it will
                                        • W
                                          wizz
                                          Ok than i have to check it is any Nodejs for any of them as i got this two just lying around and collecting dust :)
                                          • A
                                            amanzimdwini @Mykle1
                                            @Mykle1 I have it on my working laptop (ie Win10) - slight pain, since I have to launch MM & it runs in a console in the background, so I regularly worry what that is :) I dumped it onto an old laptop (which actually works with Ubuntu!) & that headache is gone… Now I just glance over into the corner & know what I am working on (i LOVE Wunderlist). So it does work on Win10 and Ubuntu.
                                            Good luck
