    MMM-Astrology MagicMirror Crash
    6 Posts 3 Posters 2.2k Views 3 Watching
    • D
      dgregory19
      After doing git and adding config my MagicMirror will not start and goes to black screen and I can’t exit out. I have to power down Pi to start over. Here is a picture of what I get. Since it locks me out I have to video tape the screen and then capture the picture. 0_1549593291301_SmartSelectImage_2019-02-07-20-52-38.png
      justjim1220J Mykle1M 2 Replies Last reply
      • justjim1220J
        justjim1220 Module Developer @dgregory19
        @dgregory19
        you may possibly have a syntax error
        Try: npm run config:check
        “Life’s Too Short To Dance With Ugly People”
        Jim Hallock - 1995
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @dgregory19
          @dgregory19
          In the MMM-Astrology folder is a node_helper.js file. The very first character on the very first line (line 1) is an * character. You can put a backslash character in front of that * so that line (line 1) looks like this:
          /* Magic Mirror
          That will allow the module to run. I just tested it.
          I’ll ask the author to fix the repo.
          Reply Quote 1
          • Mykle1M
            I fixed the issue and sent the author a pull request. I’m sure he’ll update the module in no time.
            Edit: The author has merged the pull request so you can do a git pull in the MMM-Astrology directory
            D 1 Reply Last reply
            Reply Quote 2
            • D
              dgregory19 @Mykle1
              @mykle1 Thats the funny part. I did run the config:check and it found no errors. Thanks for checking into this. I’ll take a stab at it tomorrow.
              Mykle1M 1 Reply Last reply
              • Mykle1M
                @dgregory19 said in MMM-Astrology MagicMirror Crash:
                That’s because the error wasn’t in the config.js file, as mentioned above. So now you don’t have to make the edit yourself. Simply run git pull in the MMM-Astrology directory then run your mirror
                Reply Quote 1
