    another question... regarding TV's as MM monitors.
    24 Posts 4 Posters 11.0k Views 4 Watching
    • justjim1220J Offline
      justjim1220 Module Developer
      I am setting up my mirror using a 42" tv
      My issue is that the TV cuts off the MM display around all 4 edges
      Anyone know how to fix this?
      I have tried changing resolution and display size and all that.
      I was hoping someone may have an idea of how it could be done using the MM code… :thinking_face: :thinking_face: :thinking_face:
      “Life’s Too Short To Dance With Ugly People”
      Jim Hallock - 1995
      S Mykle1M 2 Replies Last reply Reply Quote 0
        Seann Module Developer @justjim1220
        @justjim1220 Seems to me like it would be your tv settings, maybe autosize the picture or change the aspect ratio. If not try changing the resolution from the computer your using to display
          Mykle1 Project Sponsor Module Developer @justjim1220
          @justjim1220
          You’re not talking about the body margins, are you?
          justjim1220J 1 Reply Last reply Reply Quote 0
            justjim1220 Module Developer @Mykle1
            @mykle1
            Well, I did play with them a bit, but didn’t really get anywhere
            using custom.css, of course!
            Jim Hallock - 1995
              @justjim1220
              I’m not understanding what you mean by “the TV cuts off the MM display around all 4 edges”. The MM display is outside the edges of the monitor?
              justjim1220J 2 Replies Last reply Reply Quote 0
                @mykle1
                yep
                Jim Hallock - 1995
                  @mykle1
                  I will take a couple pics…
                  Jim Hallock - 1995
                    @justjim1220
                    It sounds like a “zoom in” is being deployed. Try this while MM is running:
                    Zoom Out = Control and - (That’s a dash/minus sign)
                    Default Display Size = Control and 0 (That’s a zero)
                    This should survive restart and reboot.
                    EDIT
                    Just thought of something else. If you played with margins in css already, you may not have cleared those changes. Negative margins would do the same thing
                    S justjim1220J 2 Replies Last reply Reply Quote 0
                      @justjim1220
                      Never mind about the zoom in and out. I just tested both. They both stay within the margins of the display so investigate the css further
                        sdetweil @Mykle1
                        @mykle1 on one of my tvs this is called overscan in the tv display settings
                        Mykle1M justjim1220J 2 Replies Last reply Reply Quote 0
                          Ahhh, ok, I did not know this, never having used a tv with MM. Thanks for the info
                            @mykle1
                            yeah, I don’t have any negative margins set
                            Jim Hallock - 1995
                              @justjim1220
                              Ok, was just touching upon things to try to help
                                justjim1220 Module Developer @sdetweil
                                I don’t see any overscan in my settings…
                                Jim Hallock - 1995
                                  @mykle1
                                  Yeah, I understand.
                                  Just giving feedback is all! :winking_face:
                                  Jim Hallock - 1995
                                    @mykle1
                                    Believe me, I looked to make sure!
                                    Jim Hallock - 1995
                                      @justjim1220
                                      Just out of curiosity, what does you css body look like?
                                        sdetweil
                                        my roku tv has zoom, stretch, normal, auto for picture in glass… I use auto or normal…
                                          @mykle1
                                          body {
                                          	margin: 20px;
                                          	position: absolute;
                                          	height: calc(100% - 40px);
                                          	width: calc(100% - 40px);
                                          	background: #000;
                                          	color: #aaa;
                                          	font-family: Englebert;
                                          	font-weight: 400;
                                          	font-size: 2em;
                                          	line-height: 1.5em;
                                          	-webkit-font-smoothing: antialiased;
                                          Jim Hallock - 1995
                                            sdetweil
                                            for testing, use one of the fullscreen styles… gets rid of the border etc…
