    MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
    89 Posts 35 Posters 135.0k Views 38 Watching
    • N Offline
      Newtothis @AgP42
      @AgP42 No worries! Thanks for the reply :)
      • U Offline
        ueffchen
        Hi
        the module loads initially after updating config.js or rebooting the MM, but it doesn’t refresh the iframe.
        Is there anything in the settings that I should do different?
        Thanks, ueffchen
        		module: 'MMM-SmartWebDisplay',
        		position: 'top_right',	// This can be any of the regions.
        			logDebug: false, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
        			height:"330px", //hauteur du cadre en pixel ou %
        			width:"330px", //largeur
                       		updateInterval: 30, //in min. Set it to 0 for no refresh (for videos)
                        	NextURLInterval: 30, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                        	displayStateInfos: false,	//to display if the module is on autoloop, or stop.
                        	displayLastUpdate: false, //to display the last update of the URL
        			displayLastUpdateFormat: 'ddd - HH:mm:ss', //format of the date and time to display
                        	url: ["https://gadgets.buienradar.nl/gadget/zoommap/?lat=51.29724&lng=6.84929&overname=2&zoom=11&naam=ratingen&size=2b&voor=1"],
        			scrolling: "no" // allow scrolling or not. html 4 only
        A A 2 Replies Last reply Reply Quote 0
          Alain @ueffchen
          @ueffchen I have the exact same problem. However, for some reason, when I turn the “displayLastUpdate:” to “true”, it begins updating at the interval set in “updateInterval”. Turn it back to “false”, and it stops updating.
          Not ideal, since it displays a line of information I don’t want to see; but it does refresh.
          If someone could help, I would appreciate it too!
          Thank you
          Alain
            AgP42 Project Sponsor Module Developer @ueffchen
            @ueffchen said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
            Hi
            Thanks, ueffchen
            Hi @ueffchen,
            when I test the url on iFrame tester (here : iFrame), I don’t need any refresh, the radar is live display without any refresh.
            Isn’t it the same on the mirror ?
            Otherwise on the config, as you have only 1 URL, this param "NextURLInterval: 30, " has to be set to 0 (but it cannot be the reason of non-refresh…)
            And as you set the "updateInterval: 30, ", then here you request a refresh every 30 MINUTES, was it the refresh you wanted ?
            Bye,
            AgP
              AgP42 Project Sponsor Module Developer @Alain
              @Alain said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
              Thank you
              Alain
              Hello @Alain ,
              yes strange behavior indeed !
              Could you please share your full config to check what could be wrong ?
              Thanks,
              AgP
              • P Offline
                Phil__
                This post is deleted!
                  brotherbrown831
                  I have seen a few examples of people displaying Action-tiles URLs in the MM. The action-tiles team does not allow username and passwords to be passed in the URL, the user must login to Action-tiles and then can navigate directly to the URL. Is there a solution to this requirement within SmartWebDisplay?
                  A B 2 Replies Last reply Reply Quote 0
                    AgP42 Project Sponsor Module Developer @brotherbrown831
                    @brotherbrown831
                    sorry but I don’t understand what you want to do, do you want to use a URL with a name and password on it ?
                    Or do you want to use a pop up to log in and then access a URL ?
                    You say “the action-tiles team”, what it this ? Do you have any documentation ?
                    Thanks for a bit more detail ;-)
                      AgP42 Project Sponsor Module Developer @Newtothis
                      @Newtothis @rafaelcota
                      You asked the compatibility with the module MMM-TelegramBot, and I finally took the time today to integrate it.
                      It is in “beta” so far, I must now write the documentation (really less fun that writing code :smiling_face_with_halo: )
                      The code is here : https://github.com/AgP42/MMM-SmartWebDisplay/tree/beta, if you could test and let me know your feedback it will be very appreciated !!
                      The commands are (still time to change them if you don’t like thoses ones…) :
                      /swd_next
                      /swd_prev
                      /swd_play
                      /swd_pause
                      /swd_stop
                      /swd_url (then the url you want to display on your MagicMirror)
                      for example “/swd_url http://magicmirror.builders/”
                      for the URL I didn’t give the possibility to send a list, but could be improved.
                      Thanks for your feedback !
                        Hello,
                        I finalize the version, it is now available for everyone !
                        To update (as every module) :
                        cd ~/MagicMirror/modules/MMM-SmartWebDisplay
                        git pull
                        Enjoy ;-)
                          Alain @AgP42
                          @AgP42 Hi - sorry for not replying sooner.
                          Full config file as follows:
                          /* Magic Mirror Config Sample
                           * MIT Licensed.
                          var config = {
                          address: "0.0.0.0", // Address to listen on, can be:
                          port: 8080,
                          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "192.168.0.43", "192.168.0.46"], // Set [] to allow all IP addresses
                          language: "en",
                          timeFormat: 24,
                          units: "metric",
                          module: "alert",
                          module: "updatenotification",
                          position: "top_bar"
                          module: "clock",
                          position: "top_left"
                          header: "US Holidays",
                          position: "bottom_right",
                          symbol: "calendar-check",
                          url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics" }
                          module: "compliments",
                          position: "middle_center"
                          module: "currentweather",
                          locationID: "4172173",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                          appid: "xxx"
                          module: "weatherforecast",
                          position: "bottom_left",
                          header: "Weather Forecast",
                          appid: "xxx"
                          module: "newsfeed",
                          position: "bottom_bar",
                          feeds: [
                          title: "New York Times",
                          showSourceTitle: true,
                          showPublishDate: true,
                          broadcastNewsFeeds: true,
                          broadcastNewsUpdates: true
                                module: "MMM-Remote-Control",
                          // position: "top_right",
                                  // uncomment the following line to show the URL of the remote control on the mirror
                                  // you can hide this module afterwards from the remote control itself
                                      apiKey: "xxx"
                          module: "MMM-SmartWebDisplay",
                          position: "top_right", // This can be any of the regions.
                          logDebug: true, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
                          height:"300px", //hauteur du cadre en pixel ou %
                          width:"525px", //largeur
                                          updateInterval: 1, //in min. Set it to 0 for no refresh (for videos)
                                          NextURLInterval: 0, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                                          displayLastUpdate: true, //to display the last update of the URL
                          displayLastUpdateFormat: 'HH:mm:ss', //format of the date and time to display
                                          url: ["https://xxx/public/magic1.html"], //source of the URL to be displayed
                          module: "MMM-PIR-Sensor",
                          sensorPin: 22,
                          powerSavingNotification: false,
                          powerSavingDelay: 100
                                  module: "MMM-Astronauts",
                                  position: "bottom_center",
                          useHeader: false,                // true if you want a header
                          header: "",                      // Change in config file. useHeader must be true
                          maxWidth: "300px",
                          animationSpeed: 3000,            // fade speed
                          A S 2 Replies Last reply Reply Quote 0
                            Hi @Alain,
                            first please remove all your apikey on your post before :winking_face:
                            I see that you also use the MMM-PIR-sensor module, with a delay of 100s, this is probably the root cause of the strange behavior that you saw.
                            Let me explains you my analysis :
                            Here is how this sensor work (Source) :
                            PIR
                            The delay of detection or non-detection as to be set directly on the sensor !
                            So your sensor will sent to the module “MMM-PIR-Sensor” 2 possible states “HIGH” (presence) or “LOW” (no presence).
                            Each time the MMM-PIR-Sensor will receive a modification of the sensor status, it will sent immediately (to everyone, so to MMM-SmartWebDisplay too) a notification saying “USER_PRESENCE=true” or false.
                            Developer Notes (MMM-PIR-Sensor)
                            This module broadcasts a USER_PRESENCE notification with the payload beeing true or false you can use it to pause or disable your module.
                            The “powerSavingDelay” is applied after this notification is sent to everyone.
                            And my module “MMM-SmartWebDisplay” use this notification to stop and restart the update timer.
                            So by setting 100s of delay on the MMM-PIR-Sensor module, it probably totally mix up all the update timer management of my module. :loudly_crying_face:
                            A small example :
                            • Nobody in front of the mirror for long time, so Mirror is off
                            • you arrives close to the Mirror, that activate the PIR sensor, the Mirror wakes up and MMM-SmartWebDisplay also wakes up, update the html page to display and set a new refresh in 1 min (because you configure it with 1min)
                            • your sensor doesn’t detects you anymore : during 100s, so 1min40s your Mirror will stay ON without any notification (because you desactivate “powerSavingNotification”), but MMM-SmartWebDisplay (and all other modules) received the notification “USER_PRESENCE=false”, so MMM-SmartWebDisplay stops the update of the html page.
                            • if your sensor detects you again during this 100s, then you should see the update of the html (directly when the sensor will send the info to the Mirror) --> Do you confirm this ?
                            So for me your problem is on the adjustment of your PIR sensor and the value you set for this module configuration. You can follow this very good page to adjust correctly your sensor : PIR sensor
                            Personally I adjust the detection delay on the sensor itself and I just set 10s of “powerSavingDelay” after a notification (powerSavingNotification: true).
                            I hope my explaination was clear enough !
                            Good luck and let me know if you still face issues,
                            Bye
                            AgP42
                            SergeS 1 Reply Last reply Reply Quote 2
                              BD0G @brotherbrown831
                              @brotherbrown831
                              Sure. What one does is create an actiontiles panel that they want displayed. Then copy the URL that points directly at the panel. This URL must use the http:// prefix in the address and cannot start with just panel.actiontiles.com/
                              Then turn the refresh setting within the config.js settings to 0
                              (for no refresh)
                              The first time that MMM-SmartWebDisplay loads the page/actiontiles panel one will be prompted to log on. Use your credentials to log on. They will be saved by the browser that is running your MagicMirror instance.
                              Then in the future MMM-SmartWebDisplay will just display the panel itself without the need to log on each time. So there is no need to pass the username and password “within” the URL address. There is a caveat. If you panel contains camera feeds (live Video or Still Image) your camera tile within the panel “may” need logon details like username and password to display. These will not work as username and password cannot be “passed” within the
                              URL string and be processed.
                              Just create a panel without the camera streams to be displayed.
                              • T Offline
                                ttarzan
                                Hello everyone, I have 2 instances of the module MMM-SmartWebDisplay running. This works well.
                                I also use MMM-Pages to rotate contents of the screen. I would also like to rotate one instance of the module MMM-SmartWebDisplay against one with another module. But how do I address it if I have 2 instances? Both instances have the same module name and are only different in size, position and content.
                                • C Offline
                                  chassain 0
                                  hello,
                                  Rename the folder MMM-SmartWebDisplay2…then the MMM-SmartWebDisplay2.js and inside Module.register(“MMM-SmartWebDisplay2” like this
                                  and call MMM-SmartWebDisplay on page 1 and MMM-SmartWebDisplay2 on page 2
                                    sdetweil @Alain
                                    @Alain in the future, please use the markup wrapper for config or code entries…
                                    paste the text, select it, and hit the </> button
                                    • T Offline
                                      ttarzan @chassain 0
                                      @chassain-0 Thanks, that works. You have to change the name of the module in the js file to “MMM-SmartWebDisplay2”. But I noticed that after each change of the modules the URL is reloaded, although I set updateInterval to 0. So the background is briefly white, which I don’t like. So I leave that with the rotation. Thanks for the help anyway.
                                      • SergeS Offline
                                        Serge @AgP42
                                        @AgP42 said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                                        Hi @Alain,
                                        Bye
                                        AgP42
                                        Exactly the same behavior that my mirror shows.
                                        I have a PIR sensor and i am using https://github.com/paviro/MMM-PIR-Sensor
                                        I have 60 sec powersaving delay for display turning-off, but user presence is translated as soon as the is detected by sensor. This cause some inconsistencies.
                                        Is it possible to add time delay in config.js file in order to make more easier integration of PIR modules and SWD module?
                                        Also, it would be good to have the ability to switch-off the Presence notification dependency.
                                        Sometime I just want to run youtube (say classic music) even when the display is turned off (as a background music)
                                        Such command/config will let do that.
                                        • SergeS Offline
                                          Serge
                                          Also, as an idea for the function “continuous play”. Function will allow module to pause current video when the screen turned off by PIR and continue to play it again when screen turned on by PIR.
                                          Now video starts from the beginning each time the module getting an user presence notification.
                                            AgP42 Project Sponsor Module Developer @Serge
                                            Hello everyone and happy new year !
                                            @Serge said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                                            It would have been better to change the behavior of the PIR module, but it is also possible to change it on the SWD module and yes it also can be possible to totally deactivate it to let the youtube music run in background.
                                            I will try to find some time this week to add those modifications.
                                            I already answer this several time and it is even written on the documentation, the module itself don’t have access to the video, so it is not possible to play/pause the video itself. To do so I should have implemented the youtube API (and all other video api !). The play/pause function is about the url rotation and not about the video playing itself. And this is something I unfortunately cannot change… sorry !
                                            SergeS 1 Reply Last reply Reply Quote 1
                                            • 3 / 5
