    MMM-SmartWebDisplay : display web contents (including YouTube) on your MM
    89 Posts 35 Posters 128.1k Views 38 Watching
      Doudy @AgP42
      @AgP42 “But no, the module itself don’t have an input for any “logical” behavior.”
      Damage
      :crying_face:
      • BKeyportB Offline
        BKeyport Module Developer
        Is there any way to kill the refresh animation (Fade in/out)? I generally hate animation on everything. It’s annoying. Just refresh.
        EDIT: I’ve given up on the module due to finding a better solution, no need to host a webpage to set up what I needed, and no fading in/out…
        • C Offline
          costascontis @BKeyport
          @BKeyport said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
          can you share the better solution?
          • BKeyportB Offline
            Sure, I’m using MMM-HTMLSnippet now.
            • F Offline
              fillilutten
              If I send a HTTP request via MMM-Remote-Control with an direct url to an .gif. Would work and play?
              • TazDevT Offline
                TazDev @peterh
                @peterh said in MMM-SmartWebDisplay : display web contents (including YouTube) on your MM:
                50%
                remove the space before the percent sign: 50% vs 50 %
                • L Offline
                  lmhmm
                  Hello,
                  Sorry if this has been covered before but I’ve just tried several css parameters to try to scroll the webpage down by 100-400 px. Lots of things moved the actual iframe around the mirror to certain degrees but the actual web page inside was not affected no matter what I did.
                  If anyone can advise the correct css ?under iframe? To use please?
                  I had high hopes for margin height but either - or + nothing changes …
                  Dooohhh any help appreciated sick of manually scrolling web page to position. When I do it stays there and only see the bit I want refreshing great.
                  Thanks,
                  Lorraine
                    BigSky
                    Can anyone advise how I might be able to grant microphone access for a webpage being displayed via this module? The page is here: https://unitydemos.frostweepgames.com/assetstore/microphone-webgl/ and they’ve provided a button to request permission but it’s not working on the pi. I’m trying to use this page as a test to determine if a simple Unity project compiled for webGL with audio input / output can be displayed as a magic mirror module. Thanks in advance for any suggestions!
                      alex2
                      has anyone tried using this module with an axis camera? I have two cameras I want to rotate on my display. all i get is the message saying “update requested at…”
                      • 5 / 5
