    PM2 does not start the Magic Mirror
    pm2errorenoent
    15 Posts 5 Posters 18.7k Views 4 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @DarioCas
      @dariocas So the error message was created on startup of the mirror? And the mirror did not start?
      Can you start the mirror without pm2?
      cd ~/MagicMirror
      npm start dev
      Can you post the complete log of the process?
      Can you post what is inside the file that was created for the pm2 process?
      Still not enough information to help, sorry.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        DarioCas @lavolp3
        @lavolp3 The Mirror does start if i start it manually.
        this is the whole error log:
        Error: ENOENT: no such file or directory, open 'package.json'
            at Object.fs.openSync (fs.js:646:18)
            at Object.fs.readFileSync (fs.js:551:33)
            at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:15:32)
            at Module._compile (module.js:652:30)
            at Object.Module._extensions..js (module.js:663:10)
            at Module.load (module.js:565:32)
            at tryModuleLoad (module.js:505:12)
            at Function.Module._load (module.js:497:3)
            at Module.require (module.js:596:17)
            at require (internal/module.js:11:18)
        and this is the log out:
        > magicmirror@2.6.0 start /home/pi/MagicMirror
        > sh run-start.sh
        Starting MagicMirror: v2.6.0
        Loading config ...
        Loading module helpers ...
        All module helpers loaded.
        Server started ...
        Starting module: newsfeed
        Launching application.
        Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
        Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
        Shutting down server...
        Stopping module helper: updatenotification
        Stopping module helper: calendar
        Stopping module helper: newsfeed
        These are the logs of pm2.
        The Mirror does not start if i start it from pm2.
        thanks for helping! :)
        1 Reply Last reply Reply Quote -1
        • K Offline
          Klinge
          I have the same problem.
          I installed a fresh MM with pm2. The MM started. But after a reboot the MM does not start automatically.
          Unfortunately I have no idea.
          It would be grateful, if someone could help me.
          Thank you in advance
          • lavolp3L Offline
            I would suggest to both of you to follow the complete guide setting up pm2 and the autostart again. It doesn’t take long.
            Besides that, what does
            pm2 status
            give you after reboot?
            • K Offline
              Klinge
              pm2 status is
              pi@raspberrypi:~ $ pm2 status
              │ Name        │ id │ mode  │ status │ ↺      │ cpu │ memory
              │ MagicMirror │ 0  │ 2.6.0 │ fork   │ online │ 799 │ 0%     │ 16.8 MB   │
               Use `pm2 show <id|name>` to get more details about an app
              and in pm2 log I get this every two seconds
              pi@raspberrypi:~/.pm2 $ tail -f pm2.log
              2019-02-15T15:36:47: PM2 log: App [MagicMirror:0] online
              2019-02-15T15:36:48: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
              I tried the complete guide with creating an .sh-File and so on. But unfortenately with the same effect.
              lavolp3L 1 Reply Last reply Reply Quote 1
              • lavolp3L Offline
                lavolp3 Module Developer @Klinge
                @klinge can you first do
                pm2 stop all
                and then
                cd ~/MagicMirror
                npm start dev
                Maybe you can see what happens there.
                It seems that pm2 is running the magicmirror start script but MagicMirror won’t start
                  DarioCas @lavolp3
                  @lavolp3 starting it manually does work. but with PM2 not.
                  • K Offline
                    Klinge
                    Thank you for your help.
                    But suddenly a miracle happened.
                    Tomorrow morning I switched on my monitor and the MM runs. And I did not do anything. And I really haven´t a intelligent reason.
                    Now, when I reboot the Raspberry, the MM starts automatically.
                    Thank you for your time.
                    Mykle1M lavolp3L 2 Replies Last reply Reply Quote 2
                      Mykle1 Project Sponsor Module Developer @Klinge
                      @klinge said in PM2 does not start the Magic Mirror:
                      MMM-TimeMachine? ;-)
                      I’m glad you got it working correctly. :thumbsup:
                      • lavolp3L Offline
                        @klinge Yeah I hacked into your RasPi from here and fixed it … I will have done it next Thursday when I will have had some time.
                        Better change your password from standard “raspberry”.
                        yaaaawwwn
