    Errors and not restart
    4 Posts 2 Posters 1.2k Views 2 Watching
    • V Offline
      vonarstonehelm
      So I finally got it working the way I wanted with a few workarounds, however now it is throwing errors after a while and will disappear.
      Here are the errors from pm2 logs:
      /home/pi/.pm2/logs/mm-error.log last 15 lines:
      0|mm       | [20219:0213/125456.250611:ERROR:gles2_cmd_decoder.cc(10129)] [.DisplayCompositor-0x5a1c900]RENDER WARNING: texture bound to texture unit 0 is not renderable. It maybe non-power-of-2 and have incompatible texture filtering.
      0|mm       | [20219:0213/125456.297244:ERROR:gles2_cmd_decoder.cc(18288)] [.DisplayCompositor-0x5a1c900]GL ERROR :GL_INVALID_OPERATION : glCreateAndConsumeTextureCHROMIUM: invalid mailbox name
      0|mm       | [20219:0213/125456.297506:ERROR:gles2_cmd_decoder.cc(10129)] [.DisplayCompositor-0x5a1c900]RENDER WARNING: texture bound to texture unit 0 is not renderable. It maybe non-power-of-2 and have incompatible texture filtering.
      0|mm       | [20219:0213/125456.298002:ERROR:gles2_cmd_decoder.cc(18288)] [.DisplayCompositor-0x5a1c900]GL ERROR :GL_INVALID_OPERATION : glCreateAndConsumeTextureCHROMIUM: invalid mailbox name
      0|mm       | [20219:0213/125456.298138:ERROR:gles2_cmd_decoder.cc(10129)] [.DisplayCompositor-0x5a1c900]RENDER WARNING: texture bound to texture unit 0 is not renderable. It maybe non-power-of-2 and have incompatible texture filtering.
      0|mm       | [20219:0213/125456.298485:ERROR:gles2_cmd_decoder.cc(18288)] [.DisplayCompositor-0x5a1c900]GL ERROR :GL_INVALID_OPERATION : glCreateAndConsumeTextureCHROMIUM: invalid mailbox name
      0|mm       | [20219:0213/125456.298619:ERROR:gles2_cmd_decoder.cc(18288)] [.DisplayCompositor-0x5a1c900]GL ERROR :GL_INVALID_OPERATION : glCreateAndConsumeTextureCHROMIUM: invalid mailbox name
      0|mm       | [20219:0213/125456.298699:ERROR:gles2_cmd_decoder.cc(18288)] [.DisplayCompositor-0x5a1c900]GL ERROR :GL_INVALID_OPERATION : glCreateAndConsumeTextureCHROMIUM: invalid mailbox name
      0|mm       | [20219:0213/125456.298815:ERROR:gles2_cmd_decoder.cc(10129)] [.DisplayCompositor-0x5a1c900]RENDER WARNING: texture bound to texture unit 1 is not renderable. It maybe non-power-of-2 and have incompatible texture filtering.
      0|mm       | [20219:0213/125456.298880:ERROR:gles2_cmd_decoder.cc(10129)] [.DisplayCompositor-0x5a1c900]RENDER WARNING: texture bound to texture unit 2 is not renderable. It maybe non-power-of-2 and have incompatible texture filtering.
      0|mm       | [20219:0213/125456.298958:ERROR:gles2_cmd_decoder.cc(10129)] [.DisplayCompositor-0x5a1c900]RENDER WARNING: texture bound to texture unit 3 is not renderable. It maybe non-power-of-2 and have incompatible texture filtering.
      0|mm       | fatal: unable to access 'https://github.com/JonathanAndersonPE/MMM-inspirobot/': SSL connection timeout
      0|mm       |
      0|mm       | fatal: unable to access 'https://github.com/MichMich/MagicMirror.git/': SSL connection timeout
      Edit: Here is more from the mm-errors.log:
      libGL error: MESA-LOADER: failed to retrieve device information
      ATTENTION: default value of option force_s3tc_enable overridden by environment.
      fatal: unable to access 'https://github.com/alberttwong/MMM-iFrame.git/': gnutls_handshake() failed: The TLS connection was non-properly terminated.
      Any ideas? Suggestions? This started after using iFrame module, so I wonder if that is causing it.
        Mykle1 Project Sponsor Module Developer @vonarstonehelm
        @vonarstonehelm said in Errors and not restart:
        Have you removed the iFrame module to see if that is the cause?
        V 2 Replies Last reply Reply Quote 0
        • V Offline
          vonarstonehelm @Mykle1
          @mykle1 No, however I did go in and changed the pi over to legacy non-GL drivers, and so far it has been stable for almost 5 hours now. If it crashes again tonight then I will go ahead and comment out the iframe module and see if that is in fact the root cause.
          • V Offline
            @mykle1 So at some point my MM did go black again. I commented out my iframe module and then restarted it and now it has been stable for 6+ hours with no issues. This leads me to think it is something with iframe.
            //              module: 'MMM-iFrame',
            //              position: 'bottom_center',      // This can be any of the regions.
            //              config: {
            //                      // See 'Configuration options' for more information.
            //                              url: ["http://192.168.1.132:81/livestream.htm?cam=Cam1"],  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
            //                              updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
            //                              width: "1280", // width of iframe
            //                              height: "720", // height of iframe
            //                              frameWidth: "640" // width of embedded iframe, height is beeing calculated by aspect ratio of iframe
            I am not sure what else could be causing it, or else I would try to do some more troubleshooting myself.
