    MM2 my first try
    21 Posts 8 Posters 10.0k Views 7 Watching
      seramik
      hi guys
      i just bought my rpi 3B+
      it seems ok for me with raspbian, it worked
      so i launch the automatic install
      then :
      installing dependencies…
      bash: ligne112: npm: commande introuvable
      unable to install dependencies!
      so any advices ? what i’ve done wrong ?
      • G Offline
        ganget @seramik
        @seramik a good question with way too less info to give a good answer. maybe this install guide can help you further!
          seramik
          @ganget said in MM2 my first try:
          thanks for the tutorial
          actually, my problem is on the magicmirror² installation, the step 1 dont run properly
          but i will try again from the start
            Mykle1 Project Sponsor Module Developer @seramik
            @seramik
            This is just a shot in the dark but are node and npm up to date? Older versions of node and npm often cause this.
              seramik
              for the tutorial, it is an very old version, now the first setup is quicker and the ver of MM is very old ( not even mm²)
              so dont advices those kind of thinks …
              i’ve retry for the star and it mades the same trouble
              node version is V8.11.1
              minimum ver required is V5
              i dont know for npm, how to know ?
                @seramik
                node -v
                Edit: npm -v
                  seramik
                  fine, i’ve done correct upgrade and manual install
                  mm² is running
                  i saw him then i stop it with alt key and quit option
                  i’m trying to setup the config.js file
                  and i wonder how i can restart the mm² programm again
                    seramik
                    ok i’ve found that in term , in the correct directory, i write " npm start" and it start
                    i try to understand the config file, i just copied the sample file by changing his name
                    now i will try to change the city for the weather
                      secdude
                      had the same issue with a brand spankin new installation of raspian noobs full and apt-get update/upgrade/dist-upgrade done. freshly set up. the install oneliner failed. only manual setup worked. using a rpi3. maybe there’s a broken dependency somewhere?
                        seramik
                        enought for tonight, i’ve got the weather in my town
                        not so bad for a first day and i dont speak of the weather
                          seramik
                          it seems good, better than i used to think
                          but i 've got a few problem with forecast weather module
                          i cant see the predicted amount of rain.
                          i set up the option by true and it dont changes anythinks
                          second problem :
                          i set up “colored” in true but
                          instead of having max and min temperature
                          i’ve got max and gap :
                          max temp is in red and gap is in blue
                          that sucks
                          any ideas ?
                          • G Offline
                            ganget @seramik
                            @seramik You can find the problem inside the modules by using the Developer tools. Acces this by using the shortcut ctrl + shift + i. When you have the developer tools open you can inspect elements and figure out errors by reading the console log and or relevant code for the element. There is so much more information there though :winking_face:
                            This really important tool will help you so much with fixing problems inside your MagicMirror. What also will help you is this forum and knowledge you gather. Good luck with figuring out your 2 problems! If you have more questions do ask!
                              seramik
                              true, no rain prediction, cauz of type of account on meteo site, i read it
                              for temp max and temp min, it seems to be an actual trouble,
                              TY for the tips, i’ve already found the proper section, where i 'll have to ask my question
                              • alainchiassonA Offline
                                alainchiasson
                                I helped a friend do a setup, we used :
                                • The latest RPi 3 B+
                                • Rasperian Stretch with Desktop and recommended software ( from https://www.raspberrypi.org/downloads/raspbian/)
                                • Software update prior to installation
                                The initial script failed on dependancies and depracated packages. Just could not get it to work.
                                Today I followed the instructions on :
                                • The RPi 3 B
                                • Rasperian Stretch with Desktop ( from https://www.raspberrypi.org/downloads/raspbian/ )
                                • no update
                                While I did get warnings, everything worked like a charm ( well - more or less - I forgot to copy the config.)
                                I know from another package ( https://octoprint.org/ - The OctoPi ) that some work needed to be done to support the RPi 3 B+ (Newer CPU ? Drivers ? Chipsets? - no really sure). Could this be the issue?
                                I will borrow his RPi 3 B+ and try again next week if no one else has comparables.
                                  bhepler Module Developer @alainchiasson
                                  @alainchiasson said in MM2 my first try:
                                  The installation script hasn’t been updated to handle some of the changes in the latest version of Raspbian. I would ignore it and follow the steps for a manual installation.
                                    showbizkid
                                    https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror This helped me.
                                      Mark Fleming
                                      I too had the same problem with my attempt at installing the MM program. I found this on
                                      https://www.w3schools.com/nodejs/nodejs_raspberrypi.asp. i used it as a long shot as i was running out of things to try. it worked and i now have MM up and running. I am using the AIY project file as install on raspberry pi 2.
                                        seramik
                                        so second try : i decided to restart from the beginning
                                        i tried the manual installation
                                        first i install the node .js, no trouble, intall seems OK
                                        but when i began " npm install && npm start", troubles appear :
                                        pi@raspberrypi:~/MagicMirror $ npm install && npm start
                                        npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
                                        electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                                        node ./download-chromedriver.js
                                        successfully dowloaded and extracted!
                                        electron@2.0.16 postinstall /home/pi/MagicMirror/node_modules/electron
                                        node install.js
                                        Downloading SHASUMS256.txt
                                        [============================================>] 100.0% of 5.39 kB (5.39 kB/s)
                                        magicmirror@2.6.0 install /home/pi/MagicMirror
                                        cd vendor && npm install
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                                        added 82 packages from 57 contributors and audited 220 packages in 15.75s
                                        found 4 low severity vulnerabilities
                                        run npm audit fix to fix them, or npm audit for details
                                        magicmirror@2.6.0 postinstall /home/pi/MagicMirror
                                        sh installers/postinstall/postinstall.sh && npm run install-fonts
                                        MagicMirror installation successful!
                                        magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
                                        cd fonts && npm install
                                        added 1 package from 1 contributor and audited 1 package in 8.517s
                                        found 0 vulnerabilities
                                        npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
                                        npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
                                        added 930 packages from 1367 contributors and audited 2433 packages in 210.933s
                                        found 23 vulnerabilities (8 low, 14 moderate, 1 high)
                                        magicmirror@2.6.0 start /home/pi/MagicMirror
                                        sh run-start.sh
                                        Starting MagicMirror: v2.6.0
                                        Loading config …
                                        WARNING! Could not find config file. Please create one. Starting with default configuration.
                                        Loading module helpers …
                                        Initializing new module helper …
                                        No helper found for module: helloworld.
                                        All module helpers loaded.
                                        Starting server on port 8080 …
                                        Server started …
                                        Sockets connected & modules started …
                                        Launching application.
                                        Shutting down server…
                                        Stopping module helper: updatenotification
                                        so, as resquest, i run npm audit for fixthis
                                        pi@raspberrypi:~/MagicMirror $ npm audit fix
                                        jshint@2.10.1
                                        added 4 packages from 4 contributors, removed 7 packages and updated 13 packages in 44.656s
                                        fixed 13 of 23 vulnerabilities in 2433 scanned packages
                                        2 vulnerabilities required manual review and could not be updated
                                        1 package update for 8 vulns involved breaking changes
                                        (use npm audit fix --force to install breaking changes; or refer to npm audit for steps to fix these manually)
                                        and i still have thoses 2 warnings who seems bad
                                          bhepler Module Developer @seramik
                                          @seramik - Warnings are just that: warnings. I usually ignore them and concentrate on errors. Errors will prevent your mirror from working.
                                          This, OTOH, is important:
                                          To fix this, you need to copy the included sample configuration file to its final destination. This will become your working configuration file and what you will edit as you add modules.
                                          cd ~/MagicMirror/config
                                          cp config.js.sample config.js
                                          So now when you want to change the behavior of your mirror, you will edit the config.js file.
                                            seramik
                                            it is OK for the config file, i’ve got the old one
