    MagicMirror screen goes black
    27 Posts 8 Posters 11.5k Views 7 Watching
      DavyC
      Hi all,
      my magic mirror uses following modules : newsfeed, MMM-DarkSkyForecast, MMM-ethereum, MMM-GoogleMapsTraffic, MMM-LICE
      Following issue is occuring after a “while”. This can be 1 day, 1,5 day, more, less…
      The screen becomes black. Only thing I can do is ALT-TAB, try to open a command prompt and press CTRL-C to exit the mirror.
      In the beginning I thought the Mirror went into sleep, but now I found out there’s a JS stack trace.
      **==== JS stack trace =========================================
      Security context: 0x3913fa4d <String[21]: http://localhost:8080>
      2: emit [events.js:193] [bytecode=0x3664d749 offset=200](this=0x6d485461 ,type=0x4b2dd285 <String[14]: document-start>)
      7: l [https://maps.googleapis.com/maps-api-v3/api/js/35/10a/intl/nl_ALL/map.js:94] [bytecode=0x5511e735 offset=4533](this=0x3ae07be9 ,a=0x4ba1f751 ,b=0x3ae4fb91 ,c=0x4ba1f…**
      I have no idea on what to search to find more help on this.
      It looks like an issue in the Google maps ?
      Any idea what can be wrong please ?
      Best regards and thanks in advance,
      Davy
      J Cr4z33C 2 Replies Last reply Reply Quote 0
        j.e.f.f Project Sponsor Module Developer @DavyC
        @davyc I think your suspicion about Google Maps might be correct. I would start by disabling the MMM-GoogleMapsTraffic for a few days to see if the issue goes away.
        Then we ca start digging in to the module to see what might be causing the issue.
        If the problem doesn’t go away, then repeat disabling with the other modules one at a time until you have a working setup. The last one that you disabled is the culprit, and we can start troubleshooting from there.
        • H Offline
          Hallonpaj
          Sorry to hijack the thread but I have the same problem. I’ve run a log and it seems that MMM-NowplayingSpotify causes the error. Do I have to disable the Spotify or can it be solved?
          0|mm  | Starting MagicMirror: v2.6.0
          0|mm  | Loading config ...
          0|mm  | Loading module helpers ...
          0|mm  | No helper found for module: MMM-pages.
          0|mm  | No helper found for module: clock.
          0|mm  | Initializing new module helper ...
          0|mm  | Module helper loaded: calendar
          0|mm  | No helper found for module: currentweather.
          0|mm  | No helper found for module: weatherforecast.
          0|mm  | Module helper loaded: MMM-News
          0|mm  | Module helper loaded: MMM-NowPlayingOnSpotify
          0|mm  | Module helper loaded: MMM-ResRobot
          0|mm  | All module helpers loaded.
          0|mm  | Starting server on port 8080 ...
          0|mm  | Server started ...
          0|mm  | Connecting socket for: calendar
          0|mm  | Starting node helper for: calendar
          0|mm  | Connecting socket for: MMM-News
          0|mm  | Connecting socket for: MMM-NowPlayingOnSpotify
          0|mm  | Connecting socket for: MMM-ResRobot
          0|mm  | Starting node_helper for module: MMM-ResRobot
          0|mm  | Sockets connected & modules started ...
          0|mm  | Create new calendar fetcher for url: http://calendar.manutd.com/Manchester_United.ics - Interval: 300000
          0|mm  | [NEWS] Initialized.
          0|mm  | node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {"updateInterval":300000,"animationSpeed":2000,"fade":true,"fadePoint":0.25,"apiBase":"https://api.resrobot.se/v2/departureBoard?format=json&passlist=0","apiKey":","routes":],"skipMinutes":3,"maximumEntries":6,"truncateAfter":5,"iconTable":{"B":"fa fa-bus","S":"fa fa-subway","J":"fa fa-train","U":"fa fa-subway","F":"fa fa-ship"}}
          0|mm  | Fetching new departure data for module: MMM-ResRobot
          0|mm  | Refreshed access token because it has expired. Expired at: 16:37:45 now is: 16:37:46
          0|mm  | [NEWS] Articles are aggregated :  85
          0|mm  | Reusing 61 cached departure(s) for module: MMM-ResRobot
          0|mm  | Reusing 60 cached departure(s) for module: MMM-ResRobot
          0|mm  | [NEWS] Articles are aggregated :  82
          0|mm  | Reusing 59 cached departure(s) for module: MMM-ResRobot
          0|mm  | Reusing 58 cached departure(s) for module: MMM-ResRobot
          0|mm  | Reusing 57 cached departure(s) for module: MMM-ResRobot
          0|mm  | Reusing 56 cached departure(s) for module: MMM-ResRobot
          0|mm  | Reusing 55 cached departure(s) for module: MMM-ResRobot
          0|mm  | Can’t retrieve current song. Reason:
          0|mm  | { StatusCodeError: 502 - "\n<html><head>\n<meta http-equiv=\"content-type\" content=\"text/html;charset=utf-8\">\n<title>502 Server Error</title>\n</head>\n<body text=#000000 bgcolor=#ffffff>\n<h1>Error: Server Error</h1>\n<h2>The server encountered a temporary error and could not complete your request.<p>Please try again in 30 seconds.</h2>\n<h2></h2>\n</body></html>\n"
          0|mm  |     at new StatusCodeError (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request-promise-core/lib/errors.js:32:15)
          0|mm  |     at Request.plumbing.callback (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request-promise-core/lib/plumbing.js:104:33)
          0|mm  |     at Request.RP$callback [as _callback] (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request-promise-core/lib/plumbing.js:46:31)
          0|mm  |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request/request.js:185:22)
          0|mm  |     at emitTwo (events.js:126:13)
          0|mm  |     at Request.emit (events.js:214:7)
          0|mm  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request/request.js:1161:10)
          0|mm  |     at emitOne (events.js:116:13)
          0|mm  |     at Request.emit (events.js:211:7)
          0|mm  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request/request.js:1083:12)
          0|mm  |   name: 'StatusCodeError',
          0|mm  |   statusCode: 502,
          0|mm  |   message: '502 - "\\n<html><head>\\n<meta http-equiv=\\"content-type\\" content=\\"text/html;charset=utf-8\\">\\n<title>502 Server Error</title>\\n</head>\\n<body text=#000000 bgcolor=#ffffff>\\n<h1>Error: Server Error</h1>\\n<h2>The server encountered a temporary error and could not complete your request.<p>Please try again in 30 seconds.</h2>\\n<h2></h2>\\n</body></html>\\n"',
          0|mm  |   error: '\n<html><head>\n<meta http-equiv="content-type" content="text/html;charset=utf-8">\n<title>502 Server Error</title>\n</head>\n<body text=#000000 bgcolor=#ffffff>\n<h1>Error: Server Error</h1>\n<h2>The server encountered a temporary error and could not complete your request.<p>Please try again in 30 seconds.</h2>\n<h2></h2>\n</body></html>\n',
          0|mm  |   options:
          0|mm  |    { url: 'https://api.spotify.com/v1/me/player',
          0|mm  |      headers:
          0|mm  |       { Authorization: 'Bearer BQC9NPxBSbMaHF906yTElArejAa2yXsBIC9PfDletpZNubc70vdIuFu2pqQnxrtOPXu_9Hzkthx5HvahcSZ2Z8uxE2CiKpX5J7a78R4I-qkAtVYzFlvaB2OMCl18ZFte_Q_GEPMgbbkQ30TxEyu3IfiGkOyI' },
          0|mm  |      json: true,
          0|mm  |      method: 'GET',
          0|mm  |      callback: [Function: RP$callback],
          0|mm  |      transform: undefined,
          0|mm  |      simple: true,
          0|mm  |      resolveWithFullResponse: false,
          0|mm  |      transform2xxOnly: false },
          0|mm  |   response:
          0|mm  |    IncomingMessage {
          0|mm  |      _readableState:
          0|mm  |       ReadableState {
          0|mm  |         objectMode: false,
          0|mm  |         highWaterMark: 16384,
          0|mm  |         buffer: [Object],
          0|mm  |         length: 0,
          0|mm  |         pipes: null,
          0|mm  |         pipesCount: 0,
          0|mm  |         flowing: true,
          0|mm  |         ended: true,
          0|mm  |         endEmitted: true,
          0|mm  |         reading: false,
          0|mm  |         sync: true,
          0|mm  |         needReadable: false,
          0|mm  |         emittedReadable: false,
          0|mm  |         readableListening: false,
          0|mm  |         resumeScheduled: false,
          0|mm  |         destroyed: false,
          0|mm  |         defaultEncoding: 'utf8',
          0|mm  |         awaitDrain: 0,
          0|mm  |         readingMore: false,
          0|mm  |         decoder: null,
          0|mm  |         encoding: null },
          0|mm  |      readable: false,
          0|mm  |      domain: null,
          0|mm  |      _events:
          0|mm  |       { end: [Array],
          0|mm  |         close: [Array],
          0|mm  |         data: [Function],
          0|mm  |         error: [Function] },
          0|mm  |      _eventsCount: 4,
          0|mm  |      _maxListeners: undefined,
          0|mm  |      socket:
          0|mm  |       TLSSocket {
          0|mm  |         _tlsOptions: [Object],
          0|mm  |         _secureEstablished: true,
          0|mm  |         _securePending: false,
          0|mm  |         _newSessionPending: false,
          0|mm  |         _controlReleased: true,
          0|mm  |         _SNICallback: null,
          0|mm  |         servername: null,
          0|mm  |         npnProtocol: false,
          0|mm  |         alpnProtocol: false,
          0|mm  |         authorized: true,
          0|mm  |         authorizationError: null,
          0|mm  |         encrypted: true,
          0|mm  |         _events: [Object],
          0|mm  |         _eventsCount: 9,
          0|mm  |         connecting: false,
          0|mm  |         _hadError: false,
          0|mm  |         _handle: null,
          0|mm  |         _parent: null,
          0|mm  |         _host: 'api.spotify.com',
          0|mm  |         _readableState: [Object],
          0|mm  |         _writableState: [Object],
          0|mm  |         writable: false,
          0|mm  |         allowHalfOpen: false,
          0|mm  |         _bytesDispatched: 278,
          0|mm  |         _sockname: null,
          0|mm  |         _pendingData: null,
          0|mm  |         _pendingEncoding: '',
          0|mm  |         server: undefined,
          0|mm  |         _server: null,
          0|mm  |         ssl: null,
          0|mm  |         _requestCert: true,
          0|mm  |         _rejectUnauthorized: true,
          0|mm  |         parser: null,
          0|mm  |         _httpMessage: [Object],
          0|mm  |         read: [Function],
          0|mm  |         _consuming: true,
          0|mm  |         _idleNext: null,
          0|mm  |         _idlePrev: null,
          0|mm  |         _idleTimeout: -1,
          0|mm  |         [Symbol(asyncId)]: 81615,
          0|mm  |         [Symbol(bytesRead)]: 523 },
          0|mm  |      connection:
          0|mm  |       TLSSocket {
          0|mm  |         ssl: null,
          0|mm  |      httpVersionMajor: 1,
          0|mm  |      httpVersionMinor: 1,
          0|mm  |      httpVersion: '1.1',
          0|mm  |      complete: true,
          0|mm  |      headers:
          0|mm  |       { 'content-type': 'text/html; charset=UTF-8',
          0|mm  |         'referrer-policy': 'no-referrer',
          0|mm  |         'content-length': '332',
          0|mm  |         date: 'Sat, 16 Feb 2019 16:16:01 GMT',
          0|mm  |         'alt-svc': 'clear',
          0|mm  |         connection: 'close' },
          0|mm  |      rawHeaders:
          0|mm  |       [ 'Content-Type',
          0|mm  |         'text/html; charset=UTF-8',
          0|mm  |         'Referrer-Policy',
          0|mm  |         'no-referrer',
          0|mm  |         'Content-Length',
          0|mm  |         '332',
          0|mm  |         'Date',
          0|mm  |         'Sat, 16 Feb 2019 16:16:01 GMT',
          0|mm  |         'Alt-Svc',
          0|mm  |         'clear',
          0|mm  |         'Connection',
          0|mm  |         'close' ],
          0|mm  |      trailers: {},
          0|mm  |      rawTrailers: [],
          0|mm  |      upgrade: false,
          0|mm  |      url: '',
          0|mm  |      method: null,
          0|mm  |      statusMessage: 'Bad Gateway',
          0|mm  |      client:
          0|mm  |       TLSSocket {
          0|mm  |         ssl: null,
          0|mm  |      _dumped: false,
          0|mm  |      req:
          0|mm  |       ClientRequest {
          0|mm  |         _eventsCount: 5,
          0|mm  |         output: [],
          0|mm  |         outputEncodings: [],
          0|mm  |         outputCallbacks: [],
          0|mm  |         outputSize: 0,
          0|mm  |         writable: true,
          0|mm  |         _last: true,
          0|mm  |         upgrading: false,
          0|mm  |         chunkedEncoding: false,
          0|mm  |         shouldKeepAlive: false,
          0|mm  |         useChunkedEncodingByDefault: false,
          0|mm  |         sendDate: false,
          0|mm  |         _removedConnection: false,
          0|mm  |         _removedContLen: false,
          0|mm  |         _removedTE: false,
          0|mm  |         _contentLength: 0,
          0|mm  |         _hasBody: true,
          0|mm  |         _trailer: '',
          0|mm  |         finished: true,
          0|mm  |         _headerSent: true,
          0|mm  |         socket: [Object],
          0|mm  |         connection: [Object],
          0|mm  |         _header: 'GET /v1/me/player HTTP/1.1\r\nAuthorization: Bearer BQC9NPxBSbMaHF906yTElArejAa2yXsBIC9PfDletpZNubc70vdIuFu2pqQnxrtOPXu_9Hzkthx5HvahcSZ2Z8uxE2CiKpX5J7a78R4I-qkAtVYzFlvaB2OMCl18ZFte_Q_GEPMgbbkQ30TxEyu3IfiGkOyI\r\nhost: api.spotify.com\r\naccept: application/json\r\nConnection: close\r\n\r\n',
          0|mm  |         _onPendingData: [Function: noopPendingOutput],
          0|mm  |         agent: [Object],
          0|mm  |         socketPath: undefined,
          0|mm  |         timeout: undefined,
          0|mm  |         path: '/v1/me/player',
          0|mm  |         _ended: true,
          0|mm  |         res: [Circular],
          0|mm  |         aborted: undefined,
          0|mm  |         timeoutCb: null,
          0|mm  |         upgradeOrConnect: false,
          0|mm  |         maxHeadersCount: null,
          0|mm  |         [Symbol(outHeadersKey)]: [Object] },
          0|mm  |      request:
          0|mm  |       Request {
          0|mm  |         headers: [Object],
          0|mm  |         readable: true,
          0|mm  |         explicitMethod: true,
          0|mm  |         _qs: [Object],
          0|mm  |         _auth: [Object],
          0|mm  |         _oauth: [Object],
          0|mm  |         _multipart: [Object],
          0|mm  |         _redirect: [Object],
          0|mm  |         _tunnel: [Object],
          0|mm  |         _rp_resolve: [Function],
          0|mm  |         _rp_reject: [Function],
          0|mm  |         _rp_promise: [Object],
          0|mm  |         _rp_callbackOrig: undefined,
          0|mm  |         callback: [Function],
          0|mm  |         _rp_options: [Object],
          0|mm  |         setHeader: [Function],
          0|mm  |         hasHeader: [Function],
          0|mm  |         getHeader: [Function],
          0|mm  |         removeHeader: [Function],
          0|mm  |         localAddress: undefined,
          0|mm  |         pool: {},
          0|mm  |         dests: [],
          0|mm  |         __isRequestRequest: true,
          0|mm  |         _callback: [Function: RP$callback],
          0|mm  |         uri: [Object],
          0|mm  |         proxy: null,
          0|mm  |         tunnel: true,
          0|mm  |         setHost: true,
          0|mm  |         originalCookieHeader: undefined,
          0|mm  |         _disableCookies: true,
          0|mm  |         _jar: undefined,
          0|mm  |         port: 443,
          0|mm  |         host: 'api.spotify.com',
          0|mm  |         _json: true,
          0|mm  |         httpModule: [Object],
          0|mm  |         agentClass: [Object],
          0|mm  |         _started: true,
          0|mm  |         href: 'https://api.spotify.com/v1/me/player',
          0|mm  |         req: [Object],
          0|mm  |         ntick: true,
          0|mm  |         response: [Circular],
          0|mm  |         originalHost: 'api.spotify.com',
          0|mm  |         originalHostHeaderName: 'host',
          0|mm  |         responseContent: [Circular],
          0|mm  |         _destdata: true,
          0|mm  |         _callbackCalled: true },
          0|mm  |      toJSON: [Function: responseToJSON],
          0|mm  |      caseless: Caseless { dict: [Object] },
          0|mm  |      body: '\n<html><head>\n<meta http-equiv="content-type" content="text/html;charset=utf-8">\n<title>502 Server Error</title>\n</head>\n<body text=#000000 bgcolor=#ffffff>\n<h1>Error: Server Error</h1>\n<h2>The server encountered a temporary error and could not complete your request.<p>Please try again in 30 seconds.</h2>\n<h2></h2>\n</body></html>\n' } }
          0|mm  | Reusing 54 cached departure(s) for module: MMM-ResRobot
          0|mm  | [NEWS] Articles are aggregated :  83
          0|mm  | Reusing 53 cached departure(s) for module: MMM-ResRobot
          0|mm  | Reusing 52 cached departure(s) for module: MMM-ResRobot
          0|mm  | Reusing 51 cached departure(s) for module: MMM-ResRobot
          0|mm  | Reusing 50 cached departure(s) for module: MMM-ResRobot
          0|mm  | Reusing 49 cached departure(s) for module: MMM-ResRobot
          0|mm  | Reusing 48 cached departure(s) for module: MMM-ResRobot
          0|mm  | Reusing 47 cached departure(s) for module: MMM-ResRobot
          0|mm  | Reusing 46 cached departure(s) for module: MMM-ResRobot
          • bheplerB Offline
            bhepler Module Developer @Hallonpaj
            @hallonpaj said in MagicMirror screen goes black:
            I don’t think so. It looks like there’s a temporary problem with Spotify. Since the problem is on their end, it most likely will be resolved soon.
            From your logs:
            message: ‘502 - “\n\n\n502 Server Error\n\n\n
            Error: Server Error
            \n
            \n
            \n\n”’,
            H S 2 Replies Last reply Reply Quote 0
            • H Offline
              Hallonpaj @bhepler
              @bhepler Alright! Thanks for answering :)
                sdetweil @bhepler
                @bhepler said in MagicMirror screen goes black:
                but the module could be changed to handle that error and not crash
                  DavyC
                  Will try to do that soon. I do not have a lot of time to test, so there will be some delay :-)
                  • Cr4z33C Offline
                    Cr4z33 @DavyC
                    @davyc yes please fix it as I am getting the same issue (actually since today only although I got it running perfectly for weeks… :thinking_face: )
                      stuartiannaylor
                      https://github.com/MichMich/MMM-WatchDog
                      Isn’t this supposed to cover such occasions as that and restart the server.
                      I only have a Pi-Zero so far so have never tested the effect with the normal Electron setup just Chromium standalone kiosk style.
                      So I don’t actually no if or what the mechanism to restart the browser (Electron) is.
                      If it doesn’t refresh via MMM-WatchDog you can always use xdotools to send keys to an Xwindow and all you need to do is a ‘ctrl+F5’ which is a refresh and drops the cache so all is effectively loaded as new.
                      sudo apt-get install xdotool
                      Then with ~/MagicMirror/run-start.sh add a line and nano xdotool.sh and chmod a+x xdotool.sh
                      if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                      	export DISPLAY=:0 # Set by default display
                      fi
                      sh xdotool.sh &
                      electron js/electron.js $1
                      With xdotool.sh being something like this
                      export DISPLAY=:0
                      export XAUTHORITY=~/.Xauthority
                      sleep 10
                      xdotool search --onlyvisible --class "chromium" key ctrl+F5  -v 2>&1 | logger &
                      Dunno what the Electron class is but really its just Chromium in a wrapper so expecting that actually that will work.
                      If not you will just have to do a bit of testing to find the class or PID of electron http://manpages.ubuntu.com/manpages/trusty/man1/xdotool.1.html
                        stuartiannaylor
                        Replied again cursed by that akismi bot troll thing.
                        PS still setting it up but just monitor your logs.
                        Create a shell script with something like
                         tail -fn0 logfile | \
                        while read line ; do
                                echo "$line" | grep "pattern"
                                if [ $? = 0 ]
                                then
                                        ... do something ...
                                fi
                        done
                        Maybe with a --retry to the tail command, or use -F instead of -f
                        Tack it onto your electron log and do the above xdotool.
                          stuartiannaylor
                          I gave you some bum steers on export XAUTHORITY=~/.Xauthority but prob was when I was using lightdm but for it to work omit that line.
                          I have 2 monitors running well 1 really as the Chromium one isn’t really doing anything as all is working fine.
                          xdotool.sh ended up just being
                          fi
                          chrome-log.sh is just
                          #Grep is a bit confusing as \| ie OR not AND so you get the following of Or + inline there is the other string
                          #grep -q '8080\|ERROR' would return true if either exist (OR)
                          ( tail -f -n0 ~/.config/chromium/chrome_debug.log & ) | grep -q '8080.*ERROR\|ERROR.*8080'
                          sh xdotool.sh
                          Main one for me is the PM2 one that waits for MagicMirror to say all is finished and point your browser
                          ( tail -f -n0 ~/.pm2/logs/MagicMirror-out.log & ) | grep -q 'Ready to go! Please point your browser to:'
                          sh xdotool.sh
                          Better explanation can be found on https://github.com/StuartIanNaylor/MagicMirror-Install-Guide-Raspberry-0-to-3/tree/master/Magic Monitor
                            motdog
                            i have a black screen too. Just got dark sky working. was finally happy and while rebooting after installing another module it goes to black. I thought it was my pi (3b) so I tried my other pi 3b+ and just black. I noticed earlier what looked like a draining battery icon but have no clue what that could mean. I do have a cursor on my black screen. alt tab shows Electon but I cant do anything from there. Help
                              sdetweil @motdog
                              @motdog run
                              npm start dev
                              Select the console tab, and scroll back to find any errors, red text.
                              Usually black screen is syntax error in module.js
                                motdog @sdetweil
                                @sdetweil I can’t get to terminal. All I have is black screen with pointer on it. I’m sure it was when I copied a config
                                  sdetweil @motdog
                                  @motdog ctrl-shift-i
                                    motdog
                                    Thanks I’ll try in the morning. If I can somehow get to config.js I’ll undo what I did. Appreciate all of your help!
                                      sdetweil @motdog
                                      @motdog always make sure u have an alternative way into the system. Like ssh from your PC.
                                        motdog @sdetweil
                                        @sdetweil I use VNC viewer pretty much all of the time to access this and nothing happens. I do see the green light occasionally flash on the pi when I try with the keyboard hooked up to it & my tv.
                                        • Cr4z33C Offline
                                          Cr4z33 @DavyC
                                          This post is deleted!
                                            motdog
                                            So I am still getting this about every 3-5 days. I have now playing on spotify and am wondering if that is the issue. Dark Sky is my weather app but the issue I had with the number of requests is not an issue any more. Curious as to why this happens. At the same time I can see the screen via my remote module
