    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 114.5k Views 3 Watching
      sdetweil @bdream
      @bdream you can do node serveronly , instead of npm start…
      for pm2, edit installers/mm.sh and change npm start to node serveronly
      then pm2 restart 0
      others have had success at running UI on p0 as well…
      make sure u change config/config.js to allow other machines to connect
      to allow all
      address: “”,
      and
      ipWhitelist: [],
        bdream
        Í’m back now and started to work further on my Pi0 with MM installation.
        I tried to get UI desktop running by installing lightdm.
        Then reconfigured Boot option to start Desktopn and Auotologin.
        After reboot, wich looks good, PI starts an give Debian logon screen.
        How to autologon?
        After I put in my credentials pi and raspberry I stuck in login-loop.
        cheers, bdream
          bdream
          Any idea what to do?
          Maybe Pi0 is not the Hardware MM will run good. Especialy in regards to upcoming updates :dizzy_face:
          But this small device will give more oportunities for nice looking projects based on MM :grinning_face_with_smiling_eyes:
          cheers, bdream
            sdetweil @bdream
            @bdream others have made it work… you may have to reinstall the base raspian image to get the graphical desktop running properly…
            I don’t have one of these pi0 devices to test with
              bdream
              @sdetweil many thanks for your guidance.
              I thaught Pi0 must get installed without GUI :worried_face: my fault.
              I will start again and see what happen.
              I’ll let you know if success yur script!
              cheers, bdream
                sdetweil @bdream
                @bdream U can run it in serveronly mode
                Have to edit the installers/mm.sh
                Or run_start.sh to do
                node serveronly
                The use browser from some other system
                  bdream
                  @sdetweil Raspbian Buster with desktop image already written to the sc-card.
                  will see the time I have to work on it next time.
                  Stuff arount serveronly and using other browser is to far from me at the moment :unamused_face:
                  cheers, bdream
                    sdetweil @bdream
                    @bdream ok… there is only one MM install… but two ways to run it… so, no problem
                      bdream
                      @sdetweil many thanks!!
                      cheers, bdream
                        bdream
                        @sdetweil may I come back to you :smiling_face_with_halo:
                        I run new installation from scratch on my Rpi0.
                        Raspian Buster with desktop
                        updated and upgraded and so on
                        run your script
                         bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                        Node.js installation Done! version=v10.15.2
                        npm WARN npm npm does not support Node.js v10.15.2
                        npm WARN npm You should probably upgrade to a newer version of node as we
                        npm WARN npm can't make any promises that npm will work with this version.
                        npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
                        npm WARN npm You can find the latest version at https://nodejs.org/
                        /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                        /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                        + npm@6.12.0
                        added 430 packages from 839 contributors in 328.327s
                        npm installation Done! version=V6.12.0
                        Cloning MagicMirror Done!
                        Installing dependencies ...
                        > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                        > node ./download-chromedriver.js
                        successfully dowloaded and extracted!
                        > electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
                        > node install.js
                        Downloading tmp-3996-1-SHASUMS256.txt-3.0.13
                        [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
                        > magicmirror@2.9.0 install /home/pi/MagicMirror
                        > cd vendor && npm install
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        added 82 packages from 57 contributors and audited 220 packages in 139.709s
                        found 5 vulnerabilities (4 low, 1 high)
                          run `npm audit fix` to fix them, or `npm audit` for details
                        > magicmirror@2.9.0 postinstall /home/pi/MagicMirror
                        > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                        We'll remove from the repository the css/custom.css
                        This script apply git update-index --skip-worktree css/custom.css
                        rm 'css/custom.css'
                        MagicMirror installation successful!
                        > magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
                        > cd fonts && npm install
                        added 1 package from 1 contributor and audited 1 package in 29.697s
                        found 0 vulnerabilities
                        npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                        npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                        added 1051 packages from 1314 contributors and audited 3475 packages in 1848.766s
                        found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                        Dependencies installation Done!
                        setting up initial config.js
                        Check plymouth installation ...
                        Splashscreen: Checking themes directory.
                        Splashscreen: Create theme directory if not exists.
                        Splashscreen: Theme copied successfully.
                        Splashscreen: Changed theme to MagicMirror successfully.
                        Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                        install and setup pm2
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/pm2/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
                        [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                        [PM2] PM2 Successfully daemonized
                        [PM2][WARN] Applications MagicMirror not running, starting...
                        [PM2] App [MagicMirror] launched (1 instances)
                        │ id │ name                    │ version │ mode    │ pid      │ uptime │ ↺    │ status   │ cpu      │ mem      │ user     │ watching │
                        │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 4228     │ 3s     │ 0    │ online   │ 0%       │ 2.4mb    │ pi       │ enabled  │
                        [PM2] Saving current process list...
                        [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                        Do you want to disable the screen saver? (y/N)?y
                        We're ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
                        pi@RasPiZeroW:~ $ cd MagicMirror/
                        pi@RasPiZeroW:~/MagicMirror $ DISPLAY=:0 npm start
                        > magicmirror@2.9.0 start /home/pi/MagicMirror
                        > sh run-start.sh
                        additional
                        pi@RasPiZeroW:~/MagicMirror $ npm audit fix
                        + helmet@3.21.1
                        + lodash@4.17.15
                        added 8 packages from 7 contributors, removed 5 packages and updated 22 packages in 808.897s
                        fixed 28 of 28 vulnerabilities in 3475 scanned packages
                        MM is not coming on the screen
                        I did:
                        pi@RasPiZeroW:~/MagicMirror $  pm2 ls
                        │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 20451    │ 64s    │ 520  │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
                        pi@RasPiZeroW:~/MagicMirror $  pm2 restart mm
                        Use --update-env to update environment variables
                        [PM2][ERROR] Process mm not found
                        pi@RasPiZeroW:~/MagicMirror $  cd installers/
                        pi@RasPiZeroW:~/MagicMirror/installers $  nano mm.sh
                        pi@RasPiZeroW:~/MagicMirror/installers $ cd ..
                        pi@RasPiZeroW:~/MagicMirror $ pm2 restart 0
                        [PM2] Applying action restartProcessId on app [0](ids: 0)
                        [PM2][ERROR] Process 0 not found
                        pi@RasPiZeroW:~/MagicMirror/installers $ pm2 start mm.sh
                        [PM2] Starting /home/pi/MagicMirror/installers/mm.sh in fork_mode (1 instance)
                        [PM2] Done.
                        │ 0  │ MagicMirror             │ 2.9.0   │ fork    │ 16261    │ 61s    │ 4340 │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
                        │ 1  │ mm                      │ 2.9.0   │ fork    │ 16293    │ 1s     │ 0    │ online   │ 0%       │ 2.5mb    │ pi       │ disabled │
                        [PM2][ERROR] Script already launched, add -f option to force re-execution
                        Can you please give me a hint what my failer in thinking is?
                        What is missing and what wxactly do I need to do?
                        Many thanks! :grinning_face:
                        cheers, bdream
                          sdetweil @bdream
                          @bdream ok, a few things…
                          1. i need to fix the words at the end of install, cause if you said yes to pm2, then don’t do npm start
                          2. then u went and did a manual add of another thing for pm2…
                          so,
                           pm2 stop mm
                           pm2 delete mm
                          then
                          pm2  stop MagicMirror
                          then lets try manually
                          cd ~/MagicMirror
                          npm start
                          you should see the messages from the mirror running
                          please advise
                            bdream
                            Thias is you have to work on:
                            @sdetweil said in YAPi0 Installer Stretch Lite:
                            I do
                            pi@RasPiZeroW:~ $  pm2 stop mm
                            not necasarry
                            pm2 delete mm
                            pi@RasPiZeroW:~ $ pm2  stop MagicMirror
                            [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0)
                            [PM2] [MagicMirror](0) ✓
                            │ id │ name               │ mode     │ ↺    │ status   │ cpu      │ memory   │
                            │ 0  │ MagicMirror        │ fork     │ 223  │ stopped  │ 0%       │ 0b       │
                            pi@RasPiZeroW:~/MagicMirror $ npm start
                            > sh run-start.sh
                            nothing happen
                            cheers, bdream
                              sdetweil @bdream
                              @bdream weird… now have same problem on two systems…
                              try this
                              cd ~/MagicMirror
                              node serveronly
                              the connection url will be shown
                              then connect to that url from a browser on another system
                                sdetweil
                                another thing to try is
                                cd ~/MagicMirror
                                export DISPLAY=:0
                                node node_modules/.bin/electron
                                electron should come up on the screen
                                  bdream
                                  no, it dosn’t
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream did serveronly mode work?
                                      sdetweil @bdream
                                      @bdream ok, one more thing to try
                                      cd ~/MagicMirror/node_modules
                                      mv electron electron.save
                                      cd ..
                                      npm install electron@latest
                                      I am running 6.0.12 on one of my systems
                                      then try npm start
                                        bdream
                                        pi@RasPiZeroW:~/MagicMirror $ npm install electron@latest
                                        > electron@6.0.12 postinstall /home/pi/MagicMirror/node_modules/electron
                                        > node install.js
                                        Downloading tmp-1548-0-electron-v6.0.12-linux-armv6l.zip
                                        Error: GET https://github.com/electron/electron/releases/download/v6.0.12/electr                   on-v6.0.12-linux-armv6l.zip returned 404
                                        /home/pi/MagicMirror/node_modules/electron/install.js:53
                                          throw err
                                        Error: Failed to find Electron v6.0.12 for linux-armv6l at https://github.com/el                   ectron/electron/releases/download/v6.0.12/electron-v6.0.12-linux-armv6l.zip
                                            at Request.<anonymous> (/home/pi/MagicMirror/node_modules/nugget/index.js:16                   9:61)
                                            at Request.emit (events.js:189:13)
                                            at Request.onRequestResponse (/home/pi/MagicMirror/node_modules/request/requ                   est.js:1066:10)
                                            at ClientRequest.emit (events.js:189:13)
                                            at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:556:21                   )
                                            at HTTPParser.parserOnHeadersComplete (_http_common.js:109:17)
                                            at TLSSocket.socketOnData (_http_client.js:442:20)
                                            at TLSSocket.emit (events.js:189:13)
                                            at addChunk (_stream_readable.js:284:12)
                                            at readableAddChunk (_stream_readable.js:265:11)
                                        npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is i                   nstalled. You must install peer dependencies yourself.
                                        npm ERR! code ELIFECYCLE
                                        npm ERR! errno 1
                                        npm ERR! electron@6.0.12 postinstall: `node install.js`
                                        npm ERR! Exit status 1
                                        npm ERR!
                                        npm ERR! Failed at the electron@6.0.12 postinstall script.
                                        npm ERR! This is probably not a problem with npm. There is likely additional log                   ging output above.
                                        npm ERR!     /home/pi/.npm/_logs/2019-10-18T13_30_31_697Z-debug.log
                                        I would like to attach the log, but it’s missing :pouting_face:
                                        > sh run-start.sh
                                        run-start.sh: 7: run-start.sh: electron: not found
                                        npm ERR! syscall spawn
                                        npm ERR! file sh
                                        npm ERR! errno ENOENT
                                        npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
                                        npm ERR! spawn ENOENT
                                        npm ERR!
                                        npm ERR! Failed at the magicmirror@2.9.0 start script.
                                        npm ERR!     /home/pi/.npm/_logs/2019-10-18T14_07_43_211Z-debug.log
                                        cheers, bdream
                                          bdream
                                          @sdetweil how interesting.
                                          If I reboot the RPi0 I see MagicMirror booting too. After a while of black screen I get usal Pi Desktop.
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream sorry, forgot about arm6l
                                            Do
                                            npm install --arch=arm7l electron@latest
                                            • 6
                                            • 4 / 6
