    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 114.5k Views 3 Watching
      bdream @bdream
      @bdream excuse my typos!
      cheers, bdream
        sdetweil @bdream
        @bdream said in YAPi0 Installer Stretch Lite:
        I need your script, not any Updates and Upgrades of raspbian System, and the last Chat entries?
        Can I run it on Rpi1 also?
        yes, any pi version, plus odroid, jetson nano, ubuntu, macOS, Sierra-Catalina (all i have tested on)
        And you would prefer Streich instead of Buster?
        the bug is caused by a newer version of glibc (2.28), and buster has that, while stretch has 2.27
        so, i think (will test myself later), with stretch, you would not need to use chrome browser
          bdream
          Great Sam!
          I have next week some time and will try with Pi0 and Pi1 both ways:
          1. Buster and additions
          2. Strech
            let you know results.
          For now I will close this threat as solved
          :smiling_face_with_open_mouth_closed_eyes: :grinning_face: :smiling_face_with_open_mouth: :smiling_face_with_open_mouth_smiling_eyes: :hugging_face: :hugging_face: :hugging_face:
          cheers, bdream
            sdetweil @bdream
            @bdream good or bad news, I can create the problem on stretch on my pi0 w
            so, more work to do figure out the problem…
              bdream
              @sdetweil said in YAPi0 Installer Stretch Lite:
              You got your Pi0W :clapping_hands: have fun with this little thing :winking_face:
              …so no need to get strech installed instead of buster?
              cheers, bdream
                bdream
                chromium-browser -kiosk -start_maximized http://localhost:8080
                just added -noerrdialogs getting rid of any messages from the browser.
                chromium-browser -noerrdialogs -kiosk -start_maximized http://localhost:8080
                cheers, bdream
                  sdetweil @bdream
                  @bdream would u be willing to look at some new options for your environment? see this topic
                  https://forum.magicmirror.builders/topic/11433/proposed-new-processing-and-config-for-pi0-armv6-and-serveronly-mode
                    bdream
                    @sdetweil Hi Sam, u ask me to exchange my run-start.sh with your mentioned input?
                    and do a reboot?
                    cheers, bdream
                      sdetweil @bdream
                      @bdream really do you think it is a good idea?
                      if u want to try it
                      3 changes
                      1. replace file (save old one)
                      2 chmod +x run-start.sh
                      3. edit package,json
                          change
                                "start": "sh run-start.sh",
                           to
                                "start": "./run-start.sh",
                      for install we would move electron to the optional section, so install will finish ok
                        	"optionalDependencies": {
                      	  "electron": "^3.0.13"
                      wait!!!
                      have to edit 3 lines of new file to fix because of forum
                      		exec 3< < (node serveronly)   # remove space before (
                             		done < &3      # remove space before &
                             		exec 3< &-	# remove space before &
                      you should not have to reboot…
                      just
                      pm2 restart 0
                        bdream
                        At the moment I work on a RPi1!
                        I’m just on the way installing Pi0 again. shall I wait until tomorror execuiting u installation script?
                        will be off now until tomorrow morniong.
                        cheers, bdream
                          sdetweil @bdream
                          @bdream wait… for pi1 what is output of uname -m
                            bdream
                            uname -m
                            pi@RPi1:~/MagicMirror $ uname -m
                            armv6l
                            cheers, bdream
                              sdetweil @bdream
                              @bdream thank you… so it would work there the same as pi0.
                                bdream
                                that is good.
                                I will run your script and will have tomorrow a Pi0 also running again
                                And it’s great working on old Pi also, even it’s so slow starting.
                                But if it’s running, it’s fine.
                                cheers, bdream
                                  sdetweil @bdream
                                  the install script will fail because of the electron problem
                                    bdream
                                    it will run and I have to update the run-start.sh again and package.json
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream correct…
                                        bdream
                                        so lets run and let me know if you need any to test
                                        It works as designed I would say :grinning_face:
                                        @sdetweil good job! :thumbs_up:
                                        cheers, bdream
                                        • 6
                                        • 6 / 6
