    What kind of monitor would you recommend?
    5 Posts 2 Posters 2.7k Views 2 Watching
    • F
      Force_United
      Hi! what kind of monitor should i use?
      Can i use this monitors??
      Link: https://www.komplett.no/product/903229/datautstyr/skjermer/skjermer/philips-215-led-223v5lhsb2#
      Link: https://www.komplett.no/product/812620/datautstyr/skjermer/skjermer/benq-215-led-gl2250hm#
      Best regards.
      ★¯_(Force_United)_/¯★
      • F
        Force_United
        @Mykle1
        @MichMich
        • J
          j.e.f.f Project Sponsor Module Developer
          Any monitor will work. But for best results, you want one that is bright, thin, and has the connection for the cables flat, not sticking out at a right angle.
          If you need sound, make sure to get a monitor with integrated speakers, or use a TV.
          F 1 Reply Last reply
          • F
            Force_United @j.e.f.f
            @j-e-f-f
            Hi! But most of them write that one should preferably use OLED but picture will probably burn itself? So the best thing is to use led display?
            J 1 Reply Last reply
            • J
              j.e.f.f Project Sponsor Module Developer @Force_United
              @force_united like Plasma TVs, an OLED screen will technically decrease over time. But this is less of an issue than people realize. With plasma TVs you would need to run the TV for 75 years straight for it to burn out. OLED is similar in this respect. Also, if you use a script to turn off the TV overnight while tou’re Sleeping, or even better use a PIR sensor to wake the TV when you’re near, your OLED display will last your entire lifetime.
