    Add further npm dependencies to basic MM installation
    Scheduled Pinned Locked Moved Feature Requests
    4 Posts 3 Posters 1.5k Views 2 Watching
    • lavolp3L
      lavolp3 Module Developer
      Hi all,
      this goes esp. to @MichMich but of course like to discuss with all @Module-Developers
      If I understand correctly, for npm dependencies to be used by module fiels there are basically two options
      • use what is in the MagicMirror/vendor (like moment.js) folder
      • have it installed via npm install in a node_modules folder of the module and set a link in the module file.
      Now there are some npm dependencies that are used in more than one 3rd party module.
      E.g.
      • I am using chart.js in three different modules a.t.m.
      • I have seen google-translate-api being used several times.
      Can’t we include these to the general MM installation and have them present only once and net in every in every module’s subfolder?
      I understand that we might not want to blow up the basic MM installation but I also think there are some trends for usage of certain npm modules.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        A Former User @lavolp3
        @lavolp3
        I want to recommend ‘iconify’ instead font-awesome, it include fa and more than that nonetheless its not related with npm.
        https://iconify.design
        • MichMichM
          MichMich
          The problem is I don’t want to bloat the basic installation. (Looking back I prefer to not have any additional vendors at all).
          And how would we select which dependencies we include in MM and which dependencies we don’t?
          What would be a great feature, is to allow a module to specify the rpm modules it requires and let MM install them on startup if they are not currently available. :)
          lavolp3L 1 Reply Last reply Reply Quote 1
          • lavolp3L
            lavolp3 Module Developer @MichMich
            @michmich said in Add further npm dependencies to basic MM installation:
            Well that is obviously a case-by-case decision and therefore a bit tricky, I admit.
            But from these two I’m sure they are valuable to the MM environment.
            • A Google translation API (which tbh needs to be chosen carefully because one on npm is currently not working unfortunately)
            • A Charting tool.
            So why not use them? It’s “only” a few JS files.
            However, it’s your decision and I fully respect your point.
