    NOAA v3 using too many requests?
    28 Posts 4 Posters 13.2k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @Mykle1
      @motdog
      Post your NOAA config entry in a code block please. It should look like this.
                disabled: false,
                module: 'MMM-NOAA3',
                position: 'top_right',
                    provider: "darksky",
                    apiKey: "YOUR API KEY",
                    airKey: "YOUR AIR KEY", // IF you want Air Quality Index
                    css: "NOAA4",
                    userlat: "40.123456",
                    userlon: "-74.123456",
                    updateInterval: 30 * 60 * 1000,  // VERY IMPORTANT!
        motdog @Mykle1
        @Mykle1 from the NOAA3.js
        Module.register("MMM-NOAA3", {
            defaults: {
                animationSpeed: 0,
                initialLoadDelay: 8000,
                rotateInterval: 60 * 1000,
                apiKey: "",
                airKey: "",
                pws: "",
                css: "",
                frow: true,
        		nupdate: false,
        		userlat: "",
        		userlon: "",
          motdog @Mykle1
          @Mykle1 from my main config
          		position: 'bottom_left',
          			    apiKey: "xxxx",
          			    airKey: "xxxx",
          		        css: "NOAA4",
          			userlat: "38.751389",
          		        userlon: "-90.565948"
            motdog @dazza120
            @dazza120 interesting, Im now up to 600 requests and it locked up.
              Mykle1 Project Sponsor Module Developer @motdog
              @motdog
              Yikes! I’m out of ideas other than to see if this behavior exists when NOAA3 is the only module running. I’m not suggesting that you re-install MM but that is what I would do. Good luck.
                motdog @Mykle1
                @Mykle1 yeah its crazy. I don’t lock up often and I don’t know if it is a correlation. I may just try a different weather module to see if thats the solution
                  @motdog said in NOAA v3 using too many requests?:
                  Try one what uses the darksky api key that you have. If the same thing happens then the key is the problem. Keep me posted.
                    motdog @Mykle1
                    @Mykle1 will do. I have tried a different key. Weird thing is that the first few days has a small amount of requests then it spikes
