    MMM-Admin-Interface
    29 Posts 12 Posters 36.3k Views 12 Watching
    • L
      lolobyte @wrumble
      @wrumble
      Hi, same problem like on my system.
      log in with ssh to yur raspberry pi.
      cd ~/MagicMirror/
      npm install body-parser
      If you have an grunt error, then just install
      npm install grunt@(your version) --save-dev
      in my case it was ~0.4.0
      npm install grunt@~0.4.0 --save-dev
      make a
      sudo reboot
      after that and see if your MacicMirror works again without un commented
      { “module”: “MMM-Admin-Interface” },
      Be aware!
      the developer made a little mistake. He wrote…
      Usage
      Go to :8181/MMM-Admin-Interface/
      Edit away!
      You must use the port 8080
      Go to :8080/MMM-Admin-Interface/
      • I
        ItayXD
        it seems body-parser is not installed.
        Do you have node_modules dir inside MagicMirror/modules/MMM-Admin-Interface/?
        Do you have body-parser dir inside MagicMirror/modules/MMM-Admin-Interface/node_modules/?
        -----------EDIT-----------
        please run cd ~/Desktop/MagicMirror/modules/MMM-Admin-Interface && git pull && npm install --only=production
        • I
          ItayXD @lolobyte
          @lolobyte Thanks for your note on the port I’ll fix it.
          Do you have any idea why body-parser isn’t installed automatically? I thought it should be…
          • L
            lolobyte @ItayXD
            @ItayXD
            No, sorry.
            I’m only a small and unknown user.
            • I
              ItayXD
              Hi sorry I forgot to add install dependencies part to the readme.
              @wrumble please run cd ~/Desktop/MagicMirror/modules/MMM-Admin-Interface && git pull && npm install --only=production
              It should work
              • L
                lolobyte @ItayXD
                @ItayXD
                i do that step, but it doesn’t work.
                i mean the npm install in the Admin folder.
                Only after i install the missing files manually.
                • I
                  ItayXD
                  @lolobyte it seems my package.json is invalid will fix that
                  • I
                    ItayXD
                    Fixed, please try running git pull && npm install --only=production in the module directory
                      shashank @ItayXD
                      @ItayXD Hi, I installed the module works great, can you help me in creating module to hide and unhide each module on a touch screen.
                        broberg Project Sponsor @shashank
                        @shashank there is one already, mmm-navbar
                        • I
                          ItayXD
                          @shashank thank you. there is a great module called MMM-Remote-Control that does just that. I believe there is a module request forum, if you have any other requests
                          • W
                            wrumble
                            @ItayXD thanks for your help! I have the mirror running now but when i try to access the interface i get Cannot GET /MMM-Admin-Interface/ when i go to http://192.168.0.13:8080/MMM-Admin-Interface/ i have MMM-Remote-Control and when i access http://192.168.0.13:8080/remote.html it woks fine, any ideas why its not working? i dont get any errors in terminal
                            • I
                              ItayXD
                              @wrumble
                              can you post your config.js? you can send a link to pastebin. can you also run git status in the module directory and post the output?
                              it might also be useful if you post the output in the terminal when you start the MM (npm start).
                              • W
                                wrumble
                                im an idiot, it was still commented out in the config.js thanks for your help, it works great!
                                  shashank @broberg
                                  @broberg Thanks for suggesting the Nav bar, i installed the module working great
                                  • L
                                    lolobyte
                                    Hello, i made the MM2 update and now i can’t access the admin
                                    I can’t insert my ip from my laptop.
                                    I want to access MagicMirror from laptop with Admin-Interface, but it’s not possible now with this update.
                                    Where i have to insert my ip address in the white-list?
                                    How to insert a range?
                                    • I
                                      ItayXD
                                      Hi try putting your laptop’s up it the whitelist, it should probably by 192.168.X.X
                                        mochman Module Developer
                                        You might also have to add "::ffff:192.168.X.Y" as well. You could also just add "192.168.X.1/24 , ::ffff:192.168.X.1/24" to whitelist all of the IPs in your network (assuming you are using 192.168.X.1-254).
                                          rubenlaureys
                                          I love your module!
                                          I use it to modify my MagicMirror.
                                          But, is there a way to choose a module from a list, instead of entering the name myself?
                                          I want a dropdown list, just like the list of positions.
                                          Is this possible?
                                          Thank you.
                                          Have a great day,
                                          Ruben
                                          • I
                                            ItayXD @rubenlaureys
                                            @rubenlaureys
                                            I’m not sure what you mean, there should be a tab list with the modules names on the left like in this photo:
                                            is this not the case?
