    MMM-Admin-Interface
    29 Posts 12 Posters 36.7k Views 12 Watching
    • lolobyteL
      lolobyte @ItayXD
      @ItayXD
      i do that step, but it doesn’t work.
      i mean the npm install in the Admin folder.
      Only after i install the missing files manually.
      • I
        ItayXD
        @lolobyte it seems my package.json is invalid will fix that
        • I
          ItayXD
          Fixed, please try running git pull && npm install --only=production in the module directory
            shashank @ItayXD
            @ItayXD Hi, I installed the module works great, can you help me in creating module to hide and unhide each module on a touch screen.
            brobergB 1 Reply Last reply
            • brobergB
              broberg Project Sponsor @shashank
              @shashank there is one already, mmm-navbar
              • I
                ItayXD
                @shashank thank you. there is a great module called MMM-Remote-Control that does just that. I believe there is a module request forum, if you have any other requests
                • W
                  wrumble
                  @ItayXD thanks for your help! I have the mirror running now but when i try to access the interface i get Cannot GET /MMM-Admin-Interface/ when i go to http://192.168.0.13:8080/MMM-Admin-Interface/ i have MMM-Remote-Control and when i access http://192.168.0.13:8080/remote.html it woks fine, any ideas why its not working? i dont get any errors in terminal
                  • I
                    ItayXD
                    @wrumble
                    can you post your config.js? you can send a link to pastebin. can you also run git status in the module directory and post the output?
                    it might also be useful if you post the output in the terminal when you start the MM (npm start).
                    • W
                      wrumble
                      im an idiot, it was still commented out in the config.js thanks for your help, it works great!
                        shashank @broberg
                        @broberg Thanks for suggesting the Nav bar, i installed the module working great
                        • lolobyteL
                          lolobyte
                          Hello, i made the MM2 update and now i can’t access the admin
                          I can’t insert my ip from my laptop.
                          I want to access MagicMirror from laptop with Admin-Interface, but it’s not possible now with this update.
                          Where i have to insert my ip address in the white-list?
                          How to insert a range?
                          • I
                            ItayXD
                            Hi try putting your laptop’s up it the whitelist, it should probably by 192.168.X.X
                            • mochmanM
                              mochman Module Developer
                              You might also have to add "::ffff:192.168.X.Y" as well. You could also just add "192.168.X.1/24 , ::ffff:192.168.X.1/24" to whitelist all of the IPs in your network (assuming you are using 192.168.X.1-254).
                                rubenlaureys
                                I love your module!
                                I use it to modify my MagicMirror.
                                But, is there a way to choose a module from a list, instead of entering the name myself?
                                I want a dropdown list, just like the list of positions.
                                Is this possible?
                                Thank you.
                                Have a great day,
                                Ruben
                                I 1 Reply Last reply
                                • I
                                  ItayXD @rubenlaureys
                                  @rubenlaureys
                                  I’m not sure what you mean, there should be a tab list with the modules names on the left like in this photo:
                                  is this not the case?
                                    shimue
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @shimue
                                      @shimue search for ip whitelist on the forum, there plenty of threads
                                        shimue
                                        Reply Quote -3
                                        • Sandy2503S
                                          Sandy2503
                                          @shimue - na dann hast DU das hier ja auch in deiner config.js stehen:
                                          address:"0.0.0.0",
                                          und achte mal auf deinen Ton …
                                          Sandy2503
                                            rockcitiman
                                            Are you still developing this module? I followed all of the instructions but I get nothing.
                                            A 1 Reply Last reply
