    MMM-Admin-Interface
    29 Posts 12 Posters 36.3k Views 12 Watching
    • I
      ItayXD
      Hey everyone
      I created a new module, to be able to edit the MM configuration from the browser
      [card:ItayXD/MMM-Admin-Interface]
      Would appreciate any input, hope you’ll enjoy it!
      • L
        lolobyte
        Hey, that’s great.I like it.
        • W
          wrumble
          Hi, after i install and run i get a blank white screen, if i install it and run on my macbook i get the following:
          Error: Cannot find module ‘body-parser’
          at Module._resolveFilename (module.js:455:15)
          at Function.Module._resolveFilename (/Users/wayne.rumble/Desktop/MagicMirror/node_modules/electron-prebuilt/dist/Electron.app/Contents/Resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (module.js:403:25)
          at Module.require (module.js:483:17)
          at require (internal/module.js:20:19)
          at Object. (/Users/wayne.rumble/Desktop/MagicMirror/modules/MMM-Admin-Interface/node_helper.js:5:20)
          at Module._compile (module.js:556:32)
          at Object.Module._extensions…js (module.js:565:10)
          at Module.load (module.js:473:32)
          at tryModuleLoad (module.js:432:12)
          Whoops! There was an uncaught exception…
          { Error: Cannot find module ‘body-parser’
          at tryModuleLoad (module.js:432:12) code: ‘MODULE_NOT_FOUND’ }
          Launching application.
          Running on an RPI 3 model B, when i comment out:
          module: “MMM-Admin-Interface”,
          from my config it works fine. Am i missing something?
          • L
            lolobyte @wrumble
            @wrumble
            Hi, same problem like on my system.
            log in with ssh to yur raspberry pi.
            cd ~/MagicMirror/
            npm install body-parser
            If you have an grunt error, then just install
            npm install grunt@(your version) --save-dev
            in my case it was ~0.4.0
            npm install grunt@~0.4.0 --save-dev
            make a
            sudo reboot
            after that and see if your MacicMirror works again without un commented
            { “module”: “MMM-Admin-Interface” },
            Be aware!
            the developer made a little mistake. He wrote…
            Usage
            Go to :8181/MMM-Admin-Interface/
            Edit away!
            You must use the port 8080
            Go to :8080/MMM-Admin-Interface/
            • I
              ItayXD
              it seems body-parser is not installed.
              Do you have node_modules dir inside MagicMirror/modules/MMM-Admin-Interface/?
              Do you have body-parser dir inside MagicMirror/modules/MMM-Admin-Interface/node_modules/?
              -----------EDIT-----------
              please run cd ~/Desktop/MagicMirror/modules/MMM-Admin-Interface && git pull && npm install --only=production
              • I
                ItayXD @lolobyte
                @lolobyte Thanks for your note on the port I’ll fix it.
                Do you have any idea why body-parser isn’t installed automatically? I thought it should be…
                • L
                  lolobyte @ItayXD
                  @ItayXD
                  No, sorry.
                  I’m only a small and unknown user.
                  • I
                    ItayXD
                    Hi sorry I forgot to add install dependencies part to the readme.
                    @wrumble please run cd ~/Desktop/MagicMirror/modules/MMM-Admin-Interface && git pull && npm install --only=production
                    It should work
                    • L
                      lolobyte @ItayXD
                      @ItayXD
                      i do that step, but it doesn’t work.
                      i mean the npm install in the Admin folder.
                      Only after i install the missing files manually.
                      • I
                        ItayXD
                        @lolobyte it seems my package.json is invalid will fix that
                        • I
                          ItayXD
                          Fixed, please try running git pull && npm install --only=production in the module directory
                            shashank @ItayXD
                            @ItayXD Hi, I installed the module works great, can you help me in creating module to hide and unhide each module on a touch screen.
                              broberg Project Sponsor @shashank
                              @shashank there is one already, mmm-navbar
                              • I
                                ItayXD
                                @shashank thank you. there is a great module called MMM-Remote-Control that does just that. I believe there is a module request forum, if you have any other requests
                                • W
                                  wrumble
                                  @ItayXD thanks for your help! I have the mirror running now but when i try to access the interface i get Cannot GET /MMM-Admin-Interface/ when i go to http://192.168.0.13:8080/MMM-Admin-Interface/ i have MMM-Remote-Control and when i access http://192.168.0.13:8080/remote.html it woks fine, any ideas why its not working? i dont get any errors in terminal
                                  • I
                                    ItayXD
                                    @wrumble
                                    can you post your config.js? you can send a link to pastebin. can you also run git status in the module directory and post the output?
                                    it might also be useful if you post the output in the terminal when you start the MM (npm start).
                                    • W
                                      wrumble
                                      im an idiot, it was still commented out in the config.js thanks for your help, it works great!
                                        shashank @broberg
                                        @broberg Thanks for suggesting the Nav bar, i installed the module working great
                                        • L
                                          lolobyte
                                          Hello, i made the MM2 update and now i can’t access the admin
                                          I can’t insert my ip from my laptop.
                                          I want to access MagicMirror from laptop with Admin-Interface, but it’s not possible now with this update.
                                          Where i have to insert my ip address in the white-list?
                                          How to insert a range?
                                          • I
                                            ItayXD
                                            Hi try putting your laptop’s up it the whitelist, it should probably by 192.168.X.X
