    Family Info Board
    Scheduled Pinned Locked Moved Showcase
    40 Posts 19 Posters 58.9k Views 33 Watching
    • ooom416354O Offline
      ooom416354 @Wedee
      @Wedee wow this looks great! How did you add in the dates to remember as well as the chores, sticky notes, and grocery list?
      • W Offline
        Wedee @ooom416354
        @ooom416354
        Dates to Remember is a shared google calendar. Running 4 shared calendars one each for wife, kid and me, and then the Dates to remember calendar.
        The sticky notes, chores, grocery list are shared Wunderlist lists.
        With the Wunderlist apps on our phones we can add or checkoff items. Kid wants more Ramen Noodles he can add to the grocery list Etc.
        ooom416354O 1 Reply Last reply Reply Quote 0
          ooom416354 @Wedee
          @Wedee that’s awesome, I have to look into wunderlist. Is it possible to add the dates to remember calendar into the default us holidays calendar so that special dates show up in the same module?
          • W Offline
            Wedee @ooom416354
            @ooom416354
            Not sure if the generic US Holiday calendar can be added to, but you could create a new Dates to remember calendar and add the US holidays into it.
            Wunderlist is pretty easy to use both the actual app, and adding in the module. Just be sure that you name your shared lists differently than the default ones… Grocery’s for example gets created on everybody’s account at setup… You need to add things to the shared list if you want it to show up.
              bminer1
              This is a great idea and I am trying to duplicate it but I’m stuck at the Wunderlist.
              Is there a tutorial or walk through on requesting the API?
              I am new to all of this and been holding my own for the most part (noob).
              Thanks!
              • W Offline
                Wedee
                To get to the API spot use the shortcuts “Here” located in the config section…
                https://github.com/paviro/MMM-Wunderlist
                As to what you want to fill in use this topic for assistance…
                https://forum.magicmirror.builders/topic/388/wunderlist-acess-token
                  bminer1 @Wedee
                  @Wedee Thanks!
                  I can not find where the access token and client ID should go in the config.js file.
                  Any tips or pointers on where to put this information?
                          module: 'MMM-Wunderlist',
                          position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
                          header: 'Wunderlist', // This is optional
                  • W Offline
                    Wedee
                    It is added just below the config: {
                    Like this…
                            header: 'XXX', // This is optional
                                accessToken: 'xxxxxxx',
                    	    clientID: 'xxxxxxx',
                    	    lists: ["XXXX"],
                    	    fade: false,
                    	    interval: "120"
                      bminer1 @Wedee
                      @Wedee Thanks! Works perfect now!
                      • bheplerB Offline
                        bhepler Module Developer
                        So… how did Christmas go? I hope everyone was amazed!
                        • 1 / 4
