    Family Info Board
    Scheduled Pinned Locked Moved Showcase
    40 Posts 19 Posters 58.9k Views 33 Watching
    • brobergB Offline
      broberg Project Sponsor
      I like the styling, clean and sober! depending on screen size it can maybe be a bit cluttered?
      • W Offline
        Wedee
        Thanks, I was quite please with the feel.
        Yes I was concerned it was a bit cluttered but on a 29" monitor the sizing looks good, and the margins / padding seem pretty good. As its a Christmas gift for the wife and she has not seen it, I know that she will have input and want changes after Christmas. For now I have a functional board that does what I intended, and I am much better versed in making changes in css as well as installation and configuration of the modules. I imagine once she gets involved it will look very different the end of January.
        • ooom416354O Offline
          ooom416354 @Wedee
          @Wedee wow this looks great! How did you add in the dates to remember as well as the chores, sticky notes, and grocery list?
          • W Offline
            Wedee @ooom416354
            @ooom416354
            Dates to Remember is a shared google calendar. Running 4 shared calendars one each for wife, kid and me, and then the Dates to remember calendar.
            The sticky notes, chores, grocery list are shared Wunderlist lists.
            With the Wunderlist apps on our phones we can add or checkoff items. Kid wants more Ramen Noodles he can add to the grocery list Etc.
            ooom416354O 1 Reply Last reply Reply Quote 0
              ooom416354 @Wedee
              @Wedee that’s awesome, I have to look into wunderlist. Is it possible to add the dates to remember calendar into the default us holidays calendar so that special dates show up in the same module?
              • W Offline
                Wedee @ooom416354
                @ooom416354
                Not sure if the generic US Holiday calendar can be added to, but you could create a new Dates to remember calendar and add the US holidays into it.
                Wunderlist is pretty easy to use both the actual app, and adding in the module. Just be sure that you name your shared lists differently than the default ones… Grocery’s for example gets created on everybody’s account at setup… You need to add things to the shared list if you want it to show up.
                  bminer1
                  This is a great idea and I am trying to duplicate it but I’m stuck at the Wunderlist.
                  Is there a tutorial or walk through on requesting the API?
                  I am new to all of this and been holding my own for the most part (noob).
                  Thanks!
                  • W Offline
                    Wedee
                    To get to the API spot use the shortcuts “Here” located in the config section…
                    https://github.com/paviro/MMM-Wunderlist
                    As to what you want to fill in use this topic for assistance…
                    https://forum.magicmirror.builders/topic/388/wunderlist-acess-token
                      bminer1 @Wedee
                      @Wedee Thanks!
                      I can not find where the access token and client ID should go in the config.js file.
                      Any tips or pointers on where to put this information?
                              module: 'MMM-Wunderlist',
                              position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
                              header: 'Wunderlist', // This is optional
                      • W Offline
                        Wedee
                        It is added just below the config: {
                        Like this…
                                header: 'XXX', // This is optional
                                    accessToken: 'xxxxxxx',
                        	    clientID: 'xxxxxxx',
                        	    lists: ["XXXX"],
                        	    fade: false,
                        	    interval: "120"
                        • 1 / 4
