    Family Info Board
    Scheduled Pinned Locked Moved Showcase
    40 Posts 19 Posters 71.3k Views 33 Watching
    • W Offline
      Wedee @ooom416354
      @ooom416354
      Not sure if the generic US Holiday calendar can be added to, but you could create a new Dates to remember calendar and add the US holidays into it.
      Wunderlist is pretty easy to use both the actual app, and adding in the module. Just be sure that you name your shared lists differently than the default ones… Grocery’s for example gets created on everybody’s account at setup… You need to add things to the shared list if you want it to show up.
        bminer1
        This is a great idea and I am trying to duplicate it but I’m stuck at the Wunderlist.
        Is there a tutorial or walk through on requesting the API?
        I am new to all of this and been holding my own for the most part (noob).
        Thanks!
        • W Offline
          Wedee
          To get to the API spot use the shortcuts “Here” located in the config section…
          https://github.com/paviro/MMM-Wunderlist
          As to what you want to fill in use this topic for assistance…
          https://forum.magicmirror.builders/topic/388/wunderlist-acess-token
            bminer1 @Wedee
            @Wedee Thanks!
            I can not find where the access token and client ID should go in the config.js file.
            Any tips or pointers on where to put this information?
                    module: 'MMM-Wunderlist',
                    position: 'top_right',  // This can be any of the regions. Best results in left or right regions.
                    header: 'Wunderlist', // This is optional
            • W Offline
              Wedee
              It is added just below the config: {
              Like this…
                      header: 'XXX', // This is optional
                          accessToken: 'xxxxxxx',
              	    clientID: 'xxxxxxx',
              	    lists: ["XXXX"],
              	    fade: false,
              	    interval: "120"
                bminer1 @Wedee
                @Wedee Thanks! Works perfect now!
                  bhepler Module Developer
                  So… how did Christmas go? I hope everyone was amazed!
                  • W Offline
                    Wedee @bhepler
                    @bhepler
                    Sorry just got back from a work trip to Europe. Yes the Family loves the board. Already have made several improvements, and have several more ideas we want to try. I had bought an additional Raspberry Pi to play with and successfully set up Alexa, so I think that is the next major add to the info board.
                    After telling a few at work about the idea two more guys have set up a similar board at their place, and their families love it as well.
                    F 1 Reply Last reply Reply Quote 1
                    • F Offline
                      fox @Wedee
                      @Wedee said in Family Info Board:
                      @bhepler
                      It would be great if you could share your css.
                      Your calendar looks great but i am absolutely css noob.
                      Issues With MMM-WatchDog known?
                      https://forum.magicmirror.builders/post/29827
                      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                      1 1 Reply Last reply Reply Quote 2
                      • 1 Offline
                        1m2 @fox
                        @fox agreed.
                        would be cool if he would share that w/the rest of us. LOL
                          poekel
                          @fox agreed.
                          Weedee could you please share ?
                          • W Offline
                            Wedee
                            As I have already done for many, just shoot me a PM with your email address and I will send the custom.css and background.
                            • L Offline
                              lucallmon @Wedee
                              @Wedee can you post your custom.css file?
                                Padilla187
                                this is perfect!
                                  Padilla187 @Wedee
                                  @Wedee don’t want to be a wierdo but I fell in love with this I Just shot you a pm
                                  • O Offline
                                    Orca
                                    @Wedee : How did you the trick with several calendars? Could you please share some infos for me?
                                    Thx
                                    • L Offline
                                      lucallmon @Orca
                                      @Orca simply clone the module for the calendar and change the settings for login.
                                      • O Offline
                                        Orca
                                        @lucallmon: Can you give me a hint how to clone this module. I’ve copied the folder into …/modules and named it calendar1, but only black screen.
                                        Thx
                                        • W Offline
                                          Wedee
                                          No need to duplicate the module, in the config.js just repeat the module config but point to the second calendar settings.
                                          • Y Offline
                                            yawns Moderator
                                            You have two possibilities with the calendar module.
                                            Option 1:
                                            This shows one block and mixes both calendars, sorted by date
                                            		module: 'calendar',
                                            		header: 'both calendars'
                                            		position: 'top_left',
                                            				url: 'http://www.whatever.....xx.ics',
                                            				symbol: 'calendar',
                                            				url: 'http://www.justanother....zz.ics',
                                            				symbol: 'calendar',
                                            Option 2:
                                            This show calendar1 sorted by date and then shows calendar2 sorted by date, but in a seperate block with a seperate header
                                            		module: 'calendar',
                                            		header: 'calendar1'
                                            				symbol: 'calendar',
                                            		module: 'calendar',
                                            		header: 'calendar2'
                                            				symbol: 'calendar',
                                            JohanbaJ 1 Reply Last reply Reply Quote 3
