    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
    • F
      fedale
      How to get quicker update of the google calendar in Magic mirror?
        sdetweil @fedale
        @fedale u can change the updateInterval… but note that too fast might get you denied for a while…
        • F
          fedale @sdetweil
          @sdetweil I tried that earlier without any result. And seemed like the only thing updating was the screen flickering
          I put it under the module config in the config.js was that the correct postion?
            sdetweil @fedale
            @fedale ok, in the calendar its
            fetchInterval
            sorry,
            doc always wins!
            https://docs.magicmirror.builders/modules/calendar.html#configuration-options
            • F
              fedale @sdetweil
              @sdetweil I tried the fetchInterval. But have not been sucessfull with that one.
              But everytime i save my config file it update at once.
              Is there somewhere else than in the config.js file i need to change the fetchInterval?
                sdetweil @fedale
                @fedale that is inside the config:{} section of the calendar module, yes,
                and NOT in the place where url: is
                BKeyportB F 2 Replies Last reply Reply Quote 0
                • BKeyportB
                  This works. URL Blanked to prevent private data.
                  			module: "MMM-CalendarExt2", // https://github.com/MMM-CalendarExt2/MMM-CalendarExt2
                  				calendars : [
                  						url: "",
                  						name: "Main", // Optional, Recommended
                  						maxItems: 1,
                  						scanInterval: 1000*60*.5, // every 30 seconds, Appt Book, needs this speed
                  						beforeDays: 0,
                  						afterDays: 2,
                  						forceLocalTZ: false,
                  • F
                    fedale @sdetweil
                    • F
                      fedale @BKeyport
                      @BKeyport This solved the problem. Thank you
                      • F
                        fedale
                        How can i have week numbers as an own colum?
                        Showing the weeks separerat in its own colum?
                        And the yellow marking accross the week for the current week?
                        Like in this picture https://imgur.com/mwwPwEl
                        Today i have it in the first day of the week. Due to a small screen its not showing all the calendar inputs as it takes up a row by itself. limiting the amount of events i could have
                        • N
                          nschertz
                          Great Module!! I started customizing a CSS file to enhance the display. I was able to do everything I wanted to do except one mod. I’m trying to make the calendar title font larger on each of 2 calendars, but can’t seem to find where this property is set. Looking for help with this.
                          Thx Norb
                            sdetweil @nschertz
                            @nschertz I don’t know, but you can learn the css settings by using the developers window
                            see
                            https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1650761970911
                            • N
                              nschertz @sdetweil
                              @sdetweil Thanks. That redirect was very helpful. Problem solved.
                              • H
                                hrmax23
                                I’ve added a border around today’s date in the month view but I can’t seem to figure out how to adjust the actual events to not overlap the left border. Anyone know how to do this?
                                • F
                                  fedale
                                  How do i get an extra colium for week numbers? Today its in the field for monday in my calendar.How do i specify this in css?
                                  I have the weeksmark added. But unsure how to resolve this into its own colum. Any one have a surgestion?
                                    sdetweil @fedale
                                    @fedale use MMM-CalendarExt3.
                                    ext2 is no longer supported
                                    • F
                                      fedale @sdetweil
                                      @sdetweil okay thanks. I did not know that.
                                        justbob
                                        How can I make the calendar show more than two lines of text for each event?
                                        I’ve had start and end times set up, but that would leave room for a few letters and it would look like:
                                        ‘08:00-09:30 Ext…’
                                        Then I’ve used this:
                                        .CX2 .weekSlot .event:not(.fullday) .eventMain {
                                        height: auto;
                                        flex-wrap: wrap;
                                        flex-grow: 0;
                                        overflow: visible;
                                        and it allowed me to have time in one row, and text in another, however if the text alone is more than what could be fit in a single row, again I get 3 dots instead of having the box adjust to the size of the text.
                                        It would look like this:
                                        ‘08:00-09:30
                                        Extended line of t…’
                                        Also, whenever I have two enlarged boxes in the same day, the second one would partially go over the previous one, as if the previous one wasn’t enlarged.
                                        Any ideas how I could solve these two issues?
                                        BKeyportB M 2 Replies Last reply Reply Quote 0
                                        • BKeyportB
                                          BKeyport Module Developer @justbob
                                          @justbob I’d switch to CX3agenda, to be honest. Much better.
                                            MMRIZE @justbob
                                            @justbob
                                            That module doesn’t be designed like that. Of course, a heavy tweak of CSS could be the solution, but not recommended.
                                            First, unpretty.
                                            Second, The purpose of the module is to glance at outlines at once. Multi lines are not so easy to scan. I recommend transforming the title abbreviately or using color/symbol to distinguish the points rapidly.
                                            Third, technically not so easy to align the event cells with different lines(heights) in the same row. To accomplish it, that will inevitably waste space. So I haven’t designed so.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 24 / 25
