    [Remote-Control] Shutdown, Configure and Update your MagicMirror
    274 Posts 78 Posters 933.7k Views 77 Watching
      AAPS
      I know I probably sound dumb, but what is ipWhitelist, and will mine look different than yours?
      Thanks anyway.
      • L Offline
        lolobyte @AAPS
        @AAPS
        if you update to the new magic mirror, this will be a new option in the config.js.
        Take a look to the config.js.sample file witch is delivered with the new version of magicmirror.
          AAPS
          Cool! Do I just keep it the way it is, but format it differently, or do I have to add anything?
          • L Offline
            lolobyte @AAPS
            @AAPS
            if your ip is from germany and you use ip4, than u can take it like it is.
            It has just another format and added “::ffff:192.168.1.1/24”,
              AAPS
              I tried that and it didn’t work. Is it because I am in America?
              • L Offline
                lolobyte @AAPS
                @AAPS
                the you must change this…
                “::ffff:xxx.xxx.1.1/24”,
                Substitude the xxx with your American numbers.
                  AAPS
                  It still doesn’t allow me to remote control it from my computer. Does it have to end in 1.1/24, or should I put ::ffff:(MY IP ADRESS)/24?
                    AAPS
                    Nothing seems to work for me. I will just set it back to what it was.
                    • L Offline
                      lolobyte @AAPS
                      @AAPS
                      do not change the end.
                      In my case i change only this because it is standard in my region and given from my internet provider.
                      192.168.
                      In your internet region you have other access address from your provider and you must change my example with numbers of your region.
                        AAPS
                        My ip address starts with 192.168 too, but now that I try to change everything back, it doesn’t work.
                          AAPS
                          Everything is fine. I will figure things out later. Thank you! @lolobyte
                            AAPS
                            Are there any more problems with the Remote Control module? I want it perfect since my mirror will be a gift. If there are any more issues, what are they?
                            • L Offline
                              lolobyte @AAPS
                              @AAPS
                              see my last post in this part of the forum.
                              https://forum.magicmirror.builders/topic/1320/mmm-remote-control-after-upd-mm-to-2-1-0/10
                                Jopyth Moderator
                                If someone still has issues with the IP whitelist, please check this thread. For the other issues, if someone has clean steps to reproduce them, please post here or on the github issues linked in that post.
                                • F Offline
                                  febreezey
                                  I’m building my first MagicMirror. I tried to add MMM-Remote_Control, and have it showing the website on my MagicMirror that would be used to access the MMM-Remote-Control. The only problem is once I go to the website it says “This device is not allowed to access your mirror. Please check your config.js or config.js.sample to change this.” I am not sure how to know whether I am not running with ‘sudo’ rights like noted in the README.md
                                  • F Offline
                                    febreezey @febreezey
                                    @febreezey NVM!! I changed my ipwhitelist in my config.js like lolobyte noted. Works perfectly now!
                                    @lolobyte said in MMM-Remote-Control:
                                    Hi all,
                                    it works.
                                    That is my part of config with the ipwhitelist.
                                        ipWhitelist: [
                                                        "127.0.0.1",
                                                        "::ffff:127.0.0.1",
                                                        "::1",
                                                        "::ffff:192.168.1.1/24",
                                    hope it will help all other user.
                                      AlessandroRa
                                      It works, and it’s awesome!!
                                      Now, time for a stupid question: since I’m building a touch screen smart mirror, can I run the remote menu on an iFrame? I want to be able to manage the modules and shut down the mirror when I’m not using it
                                        AlessandroRa
                                        I just tried to use the “Hello World” module, but that’s what I’ve got 0_1483883271656_2017-01-08-144602_1920x1080_scrot.png
                                        • I Offline
                                          in_a_days @AlessandroRa
                                          @AlessandroRa said in MMM-Remote-Control:
                                          You might find this module more useful for your particular build. I don’t think it features power and restart buttons yet, but that will be a pretty simple addition.
                                          https://github.com/chr1syy/MM-navbar
                                          https://forum.magicmirror.builders/topic/1128/mm-navbar-navigation-bar-for-touchscreens-to-hide-show-modules
                                            AlessandroRa @in_a_days
                                            @in_a_days thank you, I tried that module and I really liked it! But I’m not really a good programmer so it would be complicate for me to add new icons for every module.
                                            Also, I don’t know why, with this module on, the Hide/show all module disappeared. How can I fix it?
                                            • 13
                                            • 14
                                            • 6 / 14
