    PIR sensor problem after restart Raspi
    20 Posts 4 Posters 7.1k Views 4 Watching
    • J Online
      JoeFranz
      i restarted my Raspi yesterday, since then the monitor hasn’t gone into standby anymore. I think some Raspian updates have been installed, could it be related to that? Nothing was changed in the MM configuration. Does somebody has any idea?
      Greetings Joerg
      kayakbabeK 1 Reply Last reply Reply Quote 0
      • kayakbabeK Offline
        kayakbabe @JoeFranz
        @JoeFranz have you checked the logs and see whats throwing errors? That is where I would start.
        • J Online
          JoeFranz @kayakbabe
          @kayakbabe There are no errors in the logs, nothing was changed in MM. Otherwise the screen was always black when MM started, and the monitor only came on after there was movement in front of the PIR sensor. Now the picture is there right after the start and the monitor no longer goes into standby. So I think it must be something to do with Raspian. Or maybe Electron? I have no idea what happened there… :-(
            sdetweil @JoeFranz
            @JoeFranz which pir module are you using?
            • J Online
              JoeFranz @sdetweil
              @sdetweil MMM-PIR-Sensor
              • E Offline
                Egnos @JoeFranz
                @JoeFranz I can recommend these two modules for the PIR (I just installed them, they also work with the S.O. bullseye):
                MMM-GPIO-Notifications: https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications
                MMM-Screen-Powersave-Notification: https://github.com/Tom-Hirschberger/MMM-Screen-Powersave-Notification
                • J Online
                  JoeFranz @Egnos
                  @Egnos Doesn’t work either, the monitor doesn’t go into standby :-( The Raspbian screensaver function does not seem to work. Can this be reinstalled?
                  • E Offline
                    Egnos @JoeFranz
                    @JoeFranz have you tried to run the two modules following this guide written by @wishmaster270 ?
                    https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications/blob/master/examples/HC-SR501/HC-SR501-GPIO4-README-EN.md
                    Which PIR sensor do you have?
                    • J Online
                      JoeFranz @Egnos
                      @Egnos I did it according to this guide (in German) have the same pir sensor as in the guide.
                      • E Offline
                        Egnos @JoeFranz
                        @JoeFranz said in PIR sensor problem after restart Raspi:
                        Have you checked that the PIR is on the correct pins of the GPIO?
