    PIR sensor problem after restart Raspi
    20 Posts 4 Posters 7.3k Views 4 Watching
      JoeFranz @sdetweil
      @sdetweil MMM-PIR-Sensor
      • E Offline
        Egnos @JoeFranz
        @JoeFranz I can recommend these two modules for the PIR (I just installed them, they also work with the S.O. bullseye):
        MMM-GPIO-Notifications: https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications
        MMM-Screen-Powersave-Notification: https://github.com/Tom-Hirschberger/MMM-Screen-Powersave-Notification
          JoeFranz @Egnos
          @Egnos Doesn’t work either, the monitor doesn’t go into standby :-( The Raspbian screensaver function does not seem to work. Can this be reinstalled?
          • E Offline
            Egnos @JoeFranz
            @JoeFranz have you tried to run the two modules following this guide written by @wishmaster270 ?
            https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications/blob/master/examples/HC-SR501/HC-SR501-GPIO4-README-EN.md
            Which PIR sensor do you have?
              JoeFranz @Egnos
              @Egnos I did it according to this guide (in German) have the same pir sensor as in the guide.
              • E Offline
                Egnos @JoeFranz
                @JoeFranz said in PIR sensor problem after restart Raspi:
                Have you checked that the PIR is on the correct pins of the GPIO?
                  JoeFranz @Egnos
                  @Egnos The sensor is correctly connected
                    sdetweil @JoeFranz
                    @JoeFranz and does it works correctly outside mm?
                    there are python scripts that will show it working
                      JoeFranz @sdetweil
                      @sdetweil How can I test this?
                        sdetweil @JoeFranz
                        @JoeFranz Google search is your friend
                        https://github.com/raspberrypilearning/physical-computing-guide/blob/master/test-pir-python.md
