    PIR sensor problem after restart Raspi
    20 Posts 4 Posters 7.7k Views 4 Watching
      JoeFranz
      i restarted my Raspi yesterday, since then the monitor hasn’t gone into standby anymore. I think some Raspian updates have been installed, could it be related to that? Nothing was changed in the MM configuration. Does somebody has any idea?
      Greetings Joerg
      kayakbabeK 1 Reply Last reply Reply Quote 0
      • kayakbabeK Offline
        kayakbabe @JoeFranz
        @JoeFranz have you checked the logs and see whats throwing errors? That is where I would start.
          JoeFranz @kayakbabe
          @kayakbabe There are no errors in the logs, nothing was changed in MM. Otherwise the screen was always black when MM started, and the monitor only came on after there was movement in front of the PIR sensor. Now the picture is there right after the start and the monitor no longer goes into standby. So I think it must be something to do with Raspian. Or maybe Electron? I have no idea what happened there… :-(
            sdetweil @JoeFranz
            @JoeFranz which pir module are you using?
              JoeFranz @sdetweil
              @sdetweil MMM-PIR-Sensor
              • E Offline
                Egnos @JoeFranz
                @JoeFranz I can recommend these two modules for the PIR (I just installed them, they also work with the S.O. bullseye):
                MMM-GPIO-Notifications: https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications
                MMM-Screen-Powersave-Notification: https://github.com/Tom-Hirschberger/MMM-Screen-Powersave-Notification
                  JoeFranz @Egnos
                  @Egnos Doesn’t work either, the monitor doesn’t go into standby :-( The Raspbian screensaver function does not seem to work. Can this be reinstalled?
                  • E Offline
                    Egnos @JoeFranz
                    @JoeFranz have you tried to run the two modules following this guide written by @wishmaster270 ?
                    https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications/blob/master/examples/HC-SR501/HC-SR501-GPIO4-README-EN.md
                    Which PIR sensor do you have?
                      JoeFranz @Egnos
                      @Egnos I did it according to this guide (in German) have the same pir sensor as in the guide.
                      • E Offline
                        Egnos @JoeFranz
                        @JoeFranz said in PIR sensor problem after restart Raspi:
                        Have you checked that the PIR is on the correct pins of the GPIO?
                          JoeFranz @Egnos
                          @Egnos The sensor is correctly connected
                            sdetweil @JoeFranz
                            @JoeFranz and does it works correctly outside mm?
                            there are python scripts that will show it working
                              JoeFranz @sdetweil
                              @sdetweil How can I test this?
                                sdetweil @JoeFranz
                                @JoeFranz Google search is your friend
                                https://github.com/raspberrypilearning/physical-computing-guide/blob/master/test-pir-python.md
                                  JoeFranz @sdetweil
                                  @sdetweil Ok, that tests the PIR sensor. But since the Raspi doesn’t even let the monitor go into standby, I suspect that it’s due to Raspian. Screen blanking is activated in Raspi-Config, so the monitor should switch off after 10 minutes, right? But that doesn’t work either. Or does that have nothing to do with the PIR function of MM?
                                    sdetweil @JoeFranz
                                    @JoeFranz well, its shouldn’t go off by itself… as then u would have two things fighting for on or off…
                                    do this, i assume you have pm2 controlling mm at boot
                                    so, do
                                    pm2 status
                                    should only be one thing… defined
                                      JoeFranz @sdetweil
                                      @sdetweil ┌─────┬────────────────┬─────────────┬─────────┬─────────┬──────────┬────────┬──────┬───────────┬──────────┬──────────┬──────────┬──────────┐
                                      │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                                      │ 0 │ MagicMirror │ default │ 2.20.0 │ fork │ 12738 │ 64s │ 0 │ online │ 0% │ 2.6mb │ pi │ disabled │
                                      pi@raspberrypi:~ $
                                        sdetweil @JoeFranz
                                        @JoeFranz ok, it’s not a second process getting in the way
                                        next to test the sensor w the python script
                                        stop mm
                                          JoeFranz @sdetweil
                                          @sdetweil Nothing happens in the window. :-( PIR sensor broken?
                                          • J JoeFranz referenced this topic on
                                            JoeFranz @JoeFranz
                                            @JoeFranz It is probably because of the current firmware 5.15
                                            With
                                            rpi-update b976c54917e240630c05a9b383010f1492bc61b4
                                            I installed version 5.10. It now works again with the standby on the HDMI connection.
                                            Greetings Joerg
                                            edited due to wrong quotes outside code block
