    Temperature/humidity on Magic Mirror
    12 Posts 5 Posters 5.7k Views 5 Watching
    • E
      Egnos
      Hello everybody,
      I would like to know the temperature/humidity in 3 points of the house (one also outside).
      Could you recommend both the WiFi sensor and the module to be used on MM?
      If it can be useful soon I should buy a NEST Audio …
      Thank you all.
      BKeyportB 1 Reply Last reply
      • BKeyportB
        BKeyport Module Developer @Egnos
        @Egnos I’d look to see what’s supported in the 3rd party modules, and work backwards from there… that being said, for outside modules, go with Davis or other commercial products, and use something like an iframe tool, I use MMM-HTMLSnippet - and just grab the panel I want from Davis’ choices.
        https://github.com/MichMich/MagicMirror/wiki/3rd-Party-Modules#utility--iot--3rd-party--integration
        In this picture, the “internal” and “room” temps are provided by MMM-Temperature via i2c/Stemma QT modules (Room being a BME 280 from Adafruit, Internal is a HTU21 also from Adafruit)
        The big panel is MMM-HTMLSnippet.
        CSS is modified a lot to fit my theming.
        E 1 Reply Last reply
        • E
          Egnos @BKeyport
          Thank you very much @BKeyport and I find your environment very ingenious!
          I was looking for something less complex, the sensors you mentioned must still be connected to Arduino/RPI…if I’m not mistaken!
          I was hoping there were temperature sensors that would connect to Google Home and some module was able to take this information and display it on the MM.
          But I think it’s science fiction! ;-)
          S BKeyportB 2 Replies Last reply
            sdetweil @Egnos
            @Egnos said in Temperature/humidity on Magic Mirror:
            no, it’s vendors protecting their data, regardless of what the users want…
            I have ecobee, w motion sensors… why should I need another motion sensor?
              Jimminy
              @Egnos
              You might want to have a look at https://tinyurl.com/WiFi-Temp-7-Humidity-Sensor. I have one on order so will have to wait and see if it does as advertised.
              • BKeyportB
                @Egnos the internal and room sensors are connected, yes. However, the outdoor sensors is actually not connected to anything. Solar powered, wireless to it’s controller, which then is connected to my network and uploaded to a website to create the panel.
                • E
                  Egnos @sdetweil
                  @sdetweil said in Temperature/humidity on Magic Mirror:
                  Motion sensor?!
                  Is the HUB done by the thermostat for all Ecobee sensors?
                  Which module do you use for Ecobee?
                  @Jimminy said in Temperature/humidity on Magic Mirror:
                  The link takes me to the “home” of AliExpress, could you put the correct link?
                  How do you think to share the info of this sensor with MM?
                  @BKeyport said in Temperature/humidity on Magic Mirror:
                  So they can be physically not connected to the RPI.
                  Could you tell me the type of sensor and how it connects (power supply, WiFi, etc …)?
                  How do you bring the information of these external sensors on the local network and then in the browser?
                  Thank you all for valuable information! :folded_hands:
                    sdetweil @Egnos
                    @Egnos all ecobee have motion detection in their thermostat and room sensors. that’s how they know the room is occupied… and could be used in temp averaging.
                    E J 2 Replies Last reply
                    • E
                      Egnos @sdetweil
                      Ah ok!
                      Does the HUB for these sensors do the thermostat?
                      What module do you use?
                        JohnGalt @sdetweil
                        @sdetweil : Sam, it sounds like you are integrating your Ecobee with your MagicMirror - true? If so, can you tell us how you get the data out of the Ecobee? I looked at it some time ago, and it appeared Ecobee uses [used?] a wireless band separate from basic WiFi, and I saw no way to tap into the information stream. I would be tempted to take another look at integrating data from the Ecobee into MagicMirror if feasible.
                          sdetweil @JohnGalt
                          @JohnGalt I have not integrated my ecobee to my MagicMirror
                          but it looks like there is an API
                          https://www.notion.so/API-Documentation-e4a7746e6a3f45dbb58ea6b45b8f9744
                          and one can get charts now
                          https://beestat.io/
                          I believe the section at sensor details shows the ‘occupancy’ … this is like a week of detail from my house.
                          in the live version there is floating info as the cursor passes over data
                          J 1 Reply Last reply
                            JohnGalt @sdetweil
                            @sdetweil Thanks, Sam. I may take a look at that Ecobee API and/or the charting. The Ecobee is currently not in use in my new house, but this may give me the added incentive to get going on that. Thanks again.
