    Internet Monitor
    108 Posts 27 Posters 166.3k Views 30 Watching
    • G
      GoodWillGustin
      I am also not getting the wifi icon to appear by itself. Hoping for an update/fix as I really love the idea of a wifi status icon on my MM.
        mattx38 @GoodWillGustin
        @GoodWillGustin I’d like to have it also.
        I experience some wifi disconnections and I sometimes notice it couple hours after the issue. So that would be great to have it on the mirror, just like on the graphical UI of the Pi.
        • N
          nickthebeer @mattx38
          @mattx38 I have just the Wifi icon on my MM, can you paste your config and I’ll take a look to at it. Also I setup a little script to restart my networking in the event of disconnection which I can share if that’ll help?
            bhepler Module Developer
            Is the missing WiFi icon still an issue? I haven’t looked into that area of the code. If there seems to be a problem I can dive into it.
            rafaelcotaR 1 Reply Last reply Reply Quote 0
            • rafaelcotaR
              rafaelcota @bhepler
              @bhepler I have the same problem, No Wifi icon. Have mirrors in MacOS and RPI and have same results.
                All right, I’ll dive back into it and see if I can fix it.
                Update: Some progress made but still a ways to go. I ended up refactoring a lot of the code.
                  Okay, I have completed my first pass at fixing the WiFi symbol. It works for me, so let’s see how it goes for you.
                  If you’re not using my repository, you’ll have to switch by deleting your modules/internet-monitor folder, cloning from my repository at https://github.com/BrianHepler/internet-monitor and then installing like normal. You’ll have to cd internet-monitor and then npm install.
                  If you’re already using my repository, just cd MagicMirror/modules/internet-monitor and git pull. It will probably tell you that you need to stash package-lock.json. Just delete that file and try again.
                  Warning: The custom WiFi icon doesn’t work yet. I got the default one to show up, but I’m still working on the one with the custom colors. But right now I want to verify that you guys can at least see the WiFi icon.
                  rafaelcotaR A 2 Replies Last reply Reply Quote 1
                  • rafaelcotaR
                    rafaelcota @bhepler
                    @bhepler said in Internet Monitor:
                    Now it works
                    • A
                      Axel51 @bhepler
                      @bhepler
                      I can see the wifi icon but no color icon is visible!!!
                      Something is missing in the source code to update the icon.
                      Can you have a look and correct it please?
                      best regards,
                      Adel
                        pgwr @Axel51
                        @Axel51 Is the wifi icon ovelaying the label “Internet Monitor” on yours? I’d like to be able to be able to see the full label. Maybe I missed something. Thanks
                          causerino
                          Has this died recently for anyone else? I have made no config changes and it’s stopped working. I’ve tried with a new server ID in case they have changed, but still no luck.
                          //New Module Internet Monitor
                                                  module: 'internet-monitor',
                                                  position: 'top_left',
                                                  header: 'SpeedTest',
                                                  config:{
                                                          type: '',
                                                          maxTime: 20000,
                                                          updateInterval: 0,
                                                          verbose: false,
                                                          serverId: "40788",
                          //                              displayStrength: true,
                                                          displaySpeed: true,
                                                          strengthIconSize: 50,
                                                          maxGaugeScale: 1000,
                          S B 3 Replies Last reply Reply Quote 0
                            sdetweil @causerino
                            @causerino comment out serverid and let it use any
                            add
                            to the beginning of the line
                              sdetweil @causerino
                              @causerino also, please use code blocks for any config data
                              paste text
                              select text
                              then push button that looks like
                              I have fixed your post
                                bhepler Module Developer @causerino
                                @causerino said in Internet Monitor:
                                I can confirm. It appears that the speedtest service is down. I’m troubleshooting now.
                                Update: Problem is with the speedtest-net package. Not sure what the problem is, but it has been down for the past week. They’ve opened an issue with the developers, so hopefully they’ll get around to it. The SpeedTest website and their paid services appear to be working, so something is up with the API.
                                I’m looking at my fork of the original repository and the latest changes to speedtest-net and I’m going to prep an update. Once it comes back, I’ll publish.
                                  causerino @bhepler
                                  Thanks very much for doing this :)
                                  bugsounetB 1 Reply Last reply Reply Quote 0
                                  • bugsounetB
                                    bugsounet Banned @causerino
                                    Are you really sure ?
                                    i use it with MMM-SpeedTest
                                    Result is:
                                      bhepler Module Developer @bugsounet
                                      @bugsounet - Pretty sure.
                                      Here is the GitHub discussion on the problem.
                                      EtA: I am having problems installing MMM-SpeedTest.
                                      PS J:\Development\MagicMirrors\MagicMirror\modules> git clone https://github.com/bugsounet/MMM-SpeedTest
                                      Cloning into 'MMM-SpeedTest'...
                                      remote: Enumerating objects: 78, done.
                                      remote: Counting objects: 100% (78/78), done.
                                      remote: Compressing objects: 100% (66/66), done.
                                      remote: Total 78 (delta 33), reused 33 (delta 10), pack-reused 0
                                      Unpacking objects: 100% (78/78), 120.78 KiB | 46.00 KiB/s, done.
                                      PS J:\Development\MagicMirrors\MagicMirror\modules> cd .\MMM-SpeedTest\
                                      PS J:\Development\MagicMirrors\MagicMirror\modules\MMM-SpeedTest> npm install
                                      > MMM-SpeedTest@1.0.3 preinstall J:\Development\MagicMirrors\MagicMirror\modules\MMM-SpeedTest
                                      > installer/preinstall.sh
                                      'installer' is not recognized as an internal or external command,
                                      operable program or batch file.
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! errno 1
                                      npm ERR! MMM-SpeedTest@1.0.3 preinstall: `installer/preinstall.sh`
                                      npm ERR! Exit status 1
                                      npm ERR!
                                      npm ERR! Failed at the MMM-SpeedTest@1.0.3 preinstall script.
                                      npm WARN Local package.json exists, but node_modules missing, did you mean to install?
                                      • bugsounetB
                                        bugsounet Banned @bhepler
                                        npm ERR! errno 1
                                        npm ERR!
                                        1. the real question is why using v1.6.2 version of SpeedTest library?
                                          v2.2.0 solve the problem ;)
                                        2. I’m glad that you use windows :anguished_face:
                                          Now retry with your pi, a linux env or … with wsl under windows ;)
                                        and result is:
                                        bugsounet@bugsounet-Kubuntu:~/MagicMirror/modules/MMM-SpeedTest$ npm install
                                        Welcome to MMM-SpeedTest v1.0.3
                                        > MMM-SpeedTest@1.0.3 postinstall
                                        > installer/postinstall.sh
                                        Building SpeedTest module, please wait...
                                        added 325 packages, and audited 326 packages in 53s
                                        28 packages are looking for funding
                                          run `npm fund` for details
                                        Screenshot:
                                        Logs in debug mode:
                                        [05.10.2022 17:25.06.650] [LOG]   [SPEED] Ping: 15.028 ms
                                        [05.10.2022 17:25.06.664] [LOG]   [SPEED] Ping: 14.293 ms
                                        [05.10.2022 17:25.06.679] [LOG]   [SPEED] Ping: 14.511 ms
                                        [05.10.2022 17:25.06.694] [LOG]   [SPEED] Ping: 14.89 ms
                                        [05.10.2022 17:25.06.709] [LOG]   [SPEED] Ping: 14.293 ms
                                        [05.10.2022 17:25.06.778] [LOG]   [SPEED] Download: 32.84 Mbps
                                        [05.10.2022 17:25.06.879] [LOG]   [SPEED] Download: 355.00 Mbps
                                        [05.10.2022 17:25.06.980] [LOG]   [SPEED] Download: 676.91 Mbps
                                        [05.10.2022 17:25.07.081] [LOG]   [SPEED] Download: 705.64 Mbps
                                        [05.10.2022 17:25.07.182] [LOG]   [SPEED] Download: 820.78 Mbps
                                        [05.10.2022 17:25.07.282] [LOG]   [SPEED] Download: 834.69 Mbps
                                        [05.10.2022 17:25.07.383] [LOG]   [SPEED] Download: 853.44 Mbps
                                        [05.10.2022 17:25.07.484] [LOG]   [SPEED] Download: 866.43 Mbps
                                        [05.10.2022 17:25.07.584] [LOG]   [SPEED] Download: 870.64 Mbps
                                        [05.10.2022 17:25.07.685] [LOG]   [SPEED] Download: 874.48 Mbps
                                        [05.10.2022 17:25.07.786] [LOG]   [SPEED] Download: 880.78 Mbps
                                        [05.10.2022 17:25.07.886] [LOG]   [SPEED] Download: 893.37 Mbps
                                        [05.10.2022 17:25.07.987] [LOG]   [SPEED] Download: 893.14 Mbps
                                        [05.10.2022 17:25.08.087] [LOG]   [SPEED] Download: 894.11 Mbps
                                        [05.10.2022 17:25.08.193] [LOG]   [SPEED] Download: 904.29 Mbps
                                        [05.10.2022 17:25.08.294] [LOG]   [SPEED] Download: 906.78 Mbps
                                        [05.10.2022 17:25.08.395] [LOG]   [SPEED] Download: 906.16 Mbps
                                        [05.10.2022 17:25.08.496] [LOG]   [SPEED] Download: 906.67 Mbps
                                        [05.10.2022 17:25.08.596] [LOG]   [SPEED] Download: 910.98 Mbps
                                        [05.10.2022 17:25.08.697] [LOG]   [SPEED] Download: 907.16 Mbps
                                        [05.10.2022 17:25.08.798] [LOG]   [SPEED] Download: 913.58 Mbps
                                        [05.10.2022 17:25.08.898] [LOG]   [SPEED] Download: 915.22 Mbps
                                        [05.10.2022 17:25.08.999] [LOG]   [SPEED] Download: 917.29 Mbps
                                        [05.10.2022 17:25.09.100] [LOG]   [SPEED] Download: 917.54 Mbps
                                        [05.10.2022 17:25.09.200] [LOG]   [SPEED] Download: 923.37 Mbps
                                        [05.10.2022 17:25.09.301] [LOG]   [SPEED] Download: 926.05 Mbps
                                        [05.10.2022 17:25.09.401] [LOG]   [SPEED] Download: 927.50 Mbps
                                        [05.10.2022 17:25.09.502] [LOG]   [SPEED] Download: 927.97 Mbps
                                        [05.10.2022 17:25.09.603] [LOG]   [SPEED] Download: 929.40 Mbps
                                        [05.10.2022 17:25.09.703] [LOG]   [SPEED] Download: 929.66 Mbps
                                        [05.10.2022 17:25.09.804] [LOG]   [SPEED] Download: 926.78 Mbps
                                        [05.10.2022 17:25.09.904] [LOG]   [SPEED] Download: 930.49 Mbps
                                        [05.10.2022 17:25.10.005] [LOG]   [SPEED] Download: 930.71 Mbps
                                        [05.10.2022 17:25.10.106] [LOG]   [SPEED] Download: 932.94 Mbps
                                        [05.10.2022 17:25.10.206] [LOG]   [SPEED] Download: 931.10 Mbps
                                        [05.10.2022 17:25.10.307] [LOG]   [SPEED] Download: 930.12 Mbps
                                        [05.10.2022 17:25.10.408] [LOG]   [SPEED] Download: 930.82 Mbps
                                        [05.10.2022 17:25.10.509] [LOG]   [SPEED] Download: 934.36 Mbps
                                        [05.10.2022 17:25.10.610] [LOG]   [SPEED] Download: 934.38 Mbps
                                        [05.10.2022 17:25.10.710] [LOG]   [SPEED] Download: 935.15 Mbps
                                        [05.10.2022 17:25.10.811] [LOG]   [SPEED] Download: 936.19 Mbps
                                        [05.10.2022 17:25.10.911] [LOG]   [SPEED] Download: 936.61 Mbps
                                        [05.10.2022 17:25.11.012] [LOG]   [SPEED] Download: 936.98 Mbps
                                        [05.10.2022 17:25.11.112] [LOG]   [SPEED] Download: 937.93 Mbps
                                        [05.10.2022 17:25.11.213] [LOG]   [SPEED] Download: 936.38 Mbps
                                        [05.10.2022 17:25.11.313] [LOG]   [SPEED] Download: 938.21 Mbps
                                        [05.10.2022 17:25.11.415] [LOG]   [SPEED] Download: 937.11 Mbps
                                        [05.10.2022 17:25.11.516] [LOG]   [SPEED] Download: 937.77 Mbps
                                        [05.10.2022 17:25.11.616] [LOG]   [SPEED] Download: 938.16 Mbps
                                        [05.10.2022 17:25.11.717] [LOG]   [SPEED] Download: 938.23 Mbps
                                        [05.10.2022 17:25.11.817] [LOG]   [SPEED] Download: 938.43 Mbps
                                        [05.10.2022 17:25.11.918] [LOG]   [SPEED] Download: 938.74 Mbps
                                        [05.10.2022 17:25.12.021] [LOG]   [SPEED] Download: 937.84 Mbps
                                        [05.10.2022 17:25.12.122] [LOG]   [SPEED] Download: 938.20 Mbps
                                        [05.10.2022 17:25.12.224] [LOG]   [SPEED] Download: 938.04 Mbps
                                        [05.10.2022 17:25.12.325] [LOG]   [SPEED] Download: 937.89 Mbps
                                        [05.10.2022 17:25.12.425] [LOG]   [SPEED] Download: 938.51 Mbps
                                        [05.10.2022 17:25.12.526] [LOG]   [SPEED] Download: 938.58 Mbps
                                        [05.10.2022 17:25.12.627] [LOG]   [SPEED] Download: 938.34 Mbps
                                        [05.10.2022 17:25.12.727] [LOG]   [SPEED] Download: 938.65 Mbps
                                        [05.10.2022 17:25.12.828] [LOG]   [SPEED] Download: 939.11 Mbps
                                        [05.10.2022 17:25.12.928] [LOG]   [SPEED] Download: 938.53 Mbps
                                        [05.10.2022 17:25.13.029] [LOG]   [SPEED] Download: 939.36 Mbps
                                        [05.10.2022 17:25.13.129] [LOG]   [SPEED] Download: 939.51 Mbps
                                        [05.10.2022 17:25.13.230] [LOG]   [SPEED] Download: 939.49 Mbps
                                        [05.10.2022 17:25.13.330] [LOG]   [SPEED] Download: 939.04 Mbps
                                        [05.10.2022 17:25.13.431] [LOG]   [SPEED] Download: 939.68 Mbps
                                        [05.10.2022 17:25.13.532] [LOG]   [SPEED] Download: 939.33 Mbps
                                        [05.10.2022 17:25.13.632] [LOG]   [SPEED] Download: 940.43 Mbps
                                        [05.10.2022 17:25.13.733] [LOG]   [SPEED] Download: 940.43 Mbps
                                        [05.10.2022 17:25.13.833] [LOG]   [SPEED] Download: 940.66 Mbps
                                        [05.10.2022 17:25.13.934] [LOG]   [SPEED] Download: 940.26 Mbps
                                        [05.10.2022 17:25.14.034] [LOG]   [SPEED] Download: 940.80 Mbps
                                        [05.10.2022 17:25.14.135] [LOG]   [SPEED] Download: 939.99 Mbps
                                        [05.10.2022 17:25.14.235] [LOG]   [SPEED] Download: 941.33 Mbps
                                        [05.10.2022 17:25.14.336] [LOG]   [SPEED] Download: 940.78 Mbps
                                        [05.10.2022 17:25.14.437] [LOG]   [SPEED] Download: 940.89 Mbps
                                        [05.10.2022 17:25.14.537] [LOG]   [SPEED] Download: 939.52 Mbps
                                        [05.10.2022 17:25.14.638] [LOG]   [SPEED] Download: 941.53 Mbps
                                        [05.10.2022 17:25.14.739] [LOG]   [SPEED] Download: 940.80 Mbps
                                        [05.10.2022 17:25.14.839] [LOG]   [SPEED] Download: 941.01 Mbps
                                        [05.10.2022 17:25.14.939] [LOG]   [SPEED] Download: 940.96 Mbps
                                        [05.10.2022 17:25.14.973] [LOG]   [SPEED] Download: 940.70 Mbps
                                        [05.10.2022 17:25.15.326] [LOG]   [SPEED] Upload: 571.68 Mbps
                                        [05.10.2022 17:25.15.427] [LOG]   [SPEED] Upload: 596.83 Mbps
                                        [05.10.2022 17:25.15.527] [LOG]   [SPEED] Upload: 615.15 Mbps
                                        [05.10.2022 17:25.15.629] [LOG]   [SPEED] Upload: 624.40 Mbps
                                        [05.10.2022 17:25.15.729] [LOG]   [SPEED] Upload: 631.77 Mbps
                                        [05.10.2022 17:25.15.830] [LOG]   [SPEED] Upload: 636.47 Mbps
                                        [05.10.2022 17:25.15.931] [LOG]   [SPEED] Upload: 640.61 Mbps
                                        [05.10.2022 17:25.16.031] [LOG]   [SPEED] Upload: 644.16 Mbps
                                        [05.10.2022 17:25.16.132] [LOG]   [SPEED] Upload: 646.54 Mbps
                                        [05.10.2022 17:25.16.233] [LOG]   [SPEED] Upload: 648.11 Mbps
                                        [05.10.2022 17:25.16.334] [LOG]   [SPEED] Upload: 650.32 Mbps
                                        [05.10.2022 17:25.16.434] [LOG]   [SPEED] Upload: 647.69 Mbps
                                        [05.10.2022 17:25.16.535] [LOG]   [SPEED] Upload: 649.62 Mbps
                                        [05.10.2022 17:25.16.636] [LOG]   [SPEED] Upload: 648.94 Mbps
                                        [05.10.2022 17:25.16.736] [LOG]   [SPEED] Upload: 649.55 Mbps
                                        [05.10.2022 17:25.16.837] [LOG]   [SPEED] Upload: 650.22 Mbps
                                        [05.10.2022 17:25.16.938] [LOG]   [SPEED] Upload: 651.65 Mbps
                                        [05.10.2022 17:25.17.039] [LOG]   [SPEED] Upload: 652.29 Mbps
                                        [05.10.2022 17:25.17.139] [LOG]   [SPEED] Upload: 655.27 Mbps
                                        [05.10.2022 17:25.17.240] [LOG]   [SPEED] Upload: 657.43 Mbps
                                        [05.10.2022 17:25.17.341] [LOG]   [SPEED] Upload: 658.04 Mbps
                                        [05.10.2022 17:25.17.442] [LOG]   [SPEED] Upload: 658.68 Mbps
                                        [05.10.2022 17:25.17.542] [LOG]   [SPEED] Upload: 667.05 Mbps
                                        [05.10.2022 17:25.17.643] [LOG]   [SPEED] Upload: 667.09 Mbps
                                        [05.10.2022 17:25.17.744] [LOG]   [SPEED] Upload: 667.35 Mbps
                                        [05.10.2022 17:25.17.844] [LOG]   [SPEED] Upload: 667.49 Mbps
                                        [05.10.2022 17:25.17.945] [LOG]   [SPEED] Upload: 666.08 Mbps
                                        [05.10.2022 17:25.18.046] [LOG]   [SPEED] Upload: 665.42 Mbps
                                        [05.10.2022 17:25.18.146] [LOG]   [SPEED] Upload: 665.49 Mbps
                                        [05.10.2022 17:25.18.247] [LOG]   [SPEED] Upload: 665.38 Mbps
                                        [05.10.2022 17:25.18.347] [LOG]   [SPEED] Upload: 666.88 Mbps
                                        [05.10.2022 17:25.18.449] [LOG]   [SPEED] Upload: 667.77 Mbps
                                        [05.10.2022 17:25.18.549] [LOG]   [SPEED] Upload: 668.95 Mbps
                                        [05.10.2022 17:25.18.649] [LOG]   [SPEED] Upload: 669.30 Mbps
                                        [05.10.2022 17:25.18.750] [LOG]   [SPEED] Upload: 669.47 Mbps
                                        [05.10.2022 17:25.18.851] [LOG]   [SPEED] Upload: 669.47 Mbps
                                        [05.10.2022 17:25.18.952] [LOG]   [SPEED] Upload: 669.74 Mbps
                                        [05.10.2022 17:25.19.052] [LOG]   [SPEED] Upload: 669.76 Mbps
                                        [05.10.2022 17:25.19.153] [LOG]   [SPEED] Upload: 668.45 Mbps
                                        [05.10.2022 17:25.19.254] [LOG]   [SPEED] Upload: 668.17 Mbps
                                        [05.10.2022 17:25.19.354] [LOG]   [SPEED] Upload: 666.30 Mbps
                                        [05.10.2022 17:25.19.455] [LOG]   [SPEED] Upload: 664.88 Mbps
                                        [05.10.2022 17:25.19.556] [LOG]   [SPEED] Upload: 663.21 Mbps
                                        [05.10.2022 17:25.19.658] [LOG]   [SPEED] Upload: 663.05 Mbps
                                        [05.10.2022 17:25.19.758] [LOG]   [SPEED] Upload: 662.47 Mbps
                                        [05.10.2022 17:25.19.859] [LOG]   [SPEED] Upload: 662.36 Mbps
                                        [05.10.2022 17:25.19.960] [LOG]   [SPEED] Upload: 661.67 Mbps
                                        [05.10.2022 17:25.20.060] [LOG]   [SPEED] Upload: 662.10 Mbps
                                        [05.10.2022 17:25.20.161] [LOG]   [SPEED] Upload: 662.88 Mbps
                                        [05.10.2022 17:25.20.262] [LOG]   [SPEED] Upload: 663.91 Mbps
                                        [05.10.2022 17:25.20.362] [LOG]   [SPEED] Upload: 664.68 Mbps
                                        [05.10.2022 17:25.20.463] [LOG]   [SPEED] Upload: 664.89 Mbps
                                        [05.10.2022 17:25.20.564] [LOG]   [SPEED] Upload: 664.85 Mbps
                                        [05.10.2022 17:25.20.665] [LOG]   [SPEED] Upload: 665.50 Mbps
                                        [05.10.2022 17:25.20.765] [LOG]   [SPEED] Upload: 665.55 Mbps
                                        [05.10.2022 17:25.20.866] [LOG]   [SPEED] Upload: 665.73 Mbps
                                        [05.10.2022 17:25.20.967] [LOG]   [SPEED] Upload: 665.68 Mbps
                                        [05.10.2022 17:25.21.067] [LOG]   [SPEED] Upload: 664.60 Mbps
                                        [05.10.2022 17:25.21.169] [LOG]   [SPEED] Upload: 666.06 Mbps
                                        [05.10.2022 17:25.21.269] [LOG]   [SPEED] Upload: 666.48 Mbps
                                        [05.10.2022 17:25.21.370] [LOG]   [SPEED] Upload: 666.63 Mbps
                                        [05.10.2022 17:25.21.471] [LOG]   [SPEED] Upload: 666.78 Mbps
                                        [05.10.2022 17:25.21.571] [LOG]   [SPEED] Upload: 666.96 Mbps
                                        [05.10.2022 17:25.21.672] [LOG]   [SPEED] Upload: 666.07 Mbps
                                        [05.10.2022 17:25.21.774] [LOG]   [SPEED] Upload: 665.40 Mbps
                                        [05.10.2022 17:25.21.874] [LOG]   [SPEED] Upload: 665.38 Mbps
                                        [05.10.2022 17:25.21.974] [LOG]   [SPEED] Upload: 665.46 Mbps
                                        [05.10.2022 17:25.22.076] [LOG]   [SPEED] Upload: 665.60 Mbps
                                        [05.10.2022 17:25.22.177] [LOG]   [SPEED] Upload: 665.71 Mbps
                                        [05.10.2022 17:25.22.244] [LOG]   [SPEED] Upload: 665.87 Mbps
                                        [05.10.2022 17:25.22.898] [LOG]   [SPEED] Result: {
                                          timestamp: 2022-10-05T15:25:22.000Z,
                                          ping: { jitter: 0.353, latency: 14.293 },
                                          download: { bandwidth: 117587756, bytes: 958119880, elapsed: 8206 },
                                          upload: { bandwidth: 83233466, bytes: 596812565, elapsed: 7211 },
                                          packetLoss: 0,
                                          isp: 'Free SAS',
                                          interface: {
                                            internalIp: '192.168.0.138',
                                            macAddr: 'xx:xx:xx:xx:xx:x',
                                            isVpn: false,
                                            externalIp: 'xxx.xxx.xxx'
                                          server: {
                                            country: 'Belgium',
                                            host: 'speedtest.arcadiz.net',
                                            port: 8080,
                                            ip: '185.160.128.145'
                                          result: {
                                            url: 'https://www.speedtest.net/result/c/82415bc5-9799-4ec2-949c-b1a69d1774a4'
                                        [05.10.2022 17:25.22.899] [LOG]   [SPEED] Done
                                        [05.10.2022 17:25.22.899] [LOG]   [SPEED] Update Programmed
                                        I’m not a magician :)
                                        I just follow speedtest v2.2.0 usage in the ReadMe file of this library.
                                        Note: That you can see in debug: https://www.speedtest.net/result/c/82415bc5-9799-4ec2-949c-b1a69d1774a4 is the shared link of this speedtest
                                        It’s the same like MM² return
                                        S B 2 Replies Last reply Reply Quote 0
                                          sdetweil @bugsounet
                                          @bugsounet said in Internet Monitor:
                                          the problem is under windows, this path is bad as it doesn’t have \
                                          unfortunately NPM is NOT platform neutral
                                          you can’t even do it with a .cmd (and bash script without .sh) in the current folder…
                                          as windows would work, but then linux would fail as current folder not in the PATH
                                          I wrote a js file that could be launched on either and launch the right thing
                                          but a pain in the rear
                                          bugsounetB 1 Reply Last reply Reply Quote 1
                                          • bugsounetB
                                            bugsounet Banned @sdetweil
                                            That why i says :
                                            I’m glad that you use windows 😧
                                            Now retry with your pi, a linux env or … with wsl under windows 😉
                                            • 5 / 6
