    Internet Monitor
    108 Posts 27 Posters 166.2k Views 30 Watching
    • A
      Axel51 @bhepler
      @bhepler
      I can see the wifi icon but no color icon is visible!!!
      Something is missing in the source code to update the icon.
      Can you have a look and correct it please?
      best regards,
      Adel
        pgwr @Axel51
        @Axel51 Is the wifi icon ovelaying the label “Internet Monitor” on yours? I’d like to be able to be able to see the full label. Maybe I missed something. Thanks
          causerino
          Has this died recently for anyone else? I have made no config changes and it’s stopped working. I’ve tried with a new server ID in case they have changed, but still no luck.
          //New Module Internet Monitor
                                  module: 'internet-monitor',
                                  position: 'top_left',
                                  header: 'SpeedTest',
                                  config:{
                                          type: '',
                                          maxTime: 20000,
                                          updateInterval: 0,
                                          verbose: false,
                                          serverId: "40788",
          //                              displayStrength: true,
                                          displaySpeed: true,
                                          strengthIconSize: 50,
                                          maxGaugeScale: 1000,
          S B 3 Replies Last reply Reply Quote 0
            sdetweil @causerino
            @causerino comment out serverid and let it use any
            add
            to the beginning of the line
              sdetweil @causerino
              @causerino also, please use code blocks for any config data
              paste text
              select text
              then push button that looks like
              I have fixed your post
                bhepler Module Developer @causerino
                @causerino said in Internet Monitor:
                I can confirm. It appears that the speedtest service is down. I’m troubleshooting now.
                Update: Problem is with the speedtest-net package. Not sure what the problem is, but it has been down for the past week. They’ve opened an issue with the developers, so hopefully they’ll get around to it. The SpeedTest website and their paid services appear to be working, so something is up with the API.
                I’m looking at my fork of the original repository and the latest changes to speedtest-net and I’m going to prep an update. Once it comes back, I’ll publish.
                  causerino @bhepler
                  @bhepler said in Internet Monitor:
                  Thanks very much for doing this :)
                  bugsounetB 1 Reply Last reply Reply Quote 0
                  • bugsounetB
                    bugsounet Banned @causerino
                    Are you really sure ?
                    i use it with MMM-SpeedTest
                    Result is:
                      bhepler Module Developer @bugsounet
                      @bugsounet - Pretty sure.
                      Here is the GitHub discussion on the problem.
                      EtA: I am having problems installing MMM-SpeedTest.
                      PS J:\Development\MagicMirrors\MagicMirror\modules> git clone https://github.com/bugsounet/MMM-SpeedTest
                      Cloning into 'MMM-SpeedTest'...
                      remote: Enumerating objects: 78, done.
                      remote: Counting objects: 100% (78/78), done.
                      remote: Compressing objects: 100% (66/66), done.
                      remote: Total 78 (delta 33), reused 33 (delta 10), pack-reused 0
                      Unpacking objects: 100% (78/78), 120.78 KiB | 46.00 KiB/s, done.
                      PS J:\Development\MagicMirrors\MagicMirror\modules> cd .\MMM-SpeedTest\
                      PS J:\Development\MagicMirrors\MagicMirror\modules\MMM-SpeedTest> npm install
                      > MMM-SpeedTest@1.0.3 preinstall J:\Development\MagicMirrors\MagicMirror\modules\MMM-SpeedTest
                      > installer/preinstall.sh
                      'installer' is not recognized as an internal or external command,
                      operable program or batch file.
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! MMM-SpeedTest@1.0.3 preinstall: `installer/preinstall.sh`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the MMM-SpeedTest@1.0.3 preinstall script.
                      npm WARN Local package.json exists, but node_modules missing, did you mean to install?
                      • bugsounetB
                        bugsounet Banned @bhepler
                        npm ERR! errno 1
                        npm ERR!
                        1. the real question is why using v1.6.2 version of SpeedTest library?
                          v2.2.0 solve the problem ;)
                        2. I’m glad that you use windows :anguished_face:
                          Now retry with your pi, a linux env or … with wsl under windows ;)
                        and result is:
                        bugsounet@bugsounet-Kubuntu:~/MagicMirror/modules/MMM-SpeedTest$ npm install
                        Welcome to MMM-SpeedTest v1.0.3
                        > MMM-SpeedTest@1.0.3 postinstall
                        > installer/postinstall.sh
                        Building SpeedTest module, please wait...
                        added 325 packages, and audited 326 packages in 53s
                        28 packages are looking for funding
                          run `npm fund` for details
                        Screenshot:
                        Logs in debug mode:
                        [05.10.2022 17:25.06.650] [LOG]   [SPEED] Ping: 15.028 ms
                        [05.10.2022 17:25.06.664] [LOG]   [SPEED] Ping: 14.293 ms
                        [05.10.2022 17:25.06.679] [LOG]   [SPEED] Ping: 14.511 ms
                        [05.10.2022 17:25.06.694] [LOG]   [SPEED] Ping: 14.89 ms
                        [05.10.2022 17:25.06.709] [LOG]   [SPEED] Ping: 14.293 ms
                        [05.10.2022 17:25.06.778] [LOG]   [SPEED] Download: 32.84 Mbps
                        [05.10.2022 17:25.06.879] [LOG]   [SPEED] Download: 355.00 Mbps
                        [05.10.2022 17:25.06.980] [LOG]   [SPEED] Download: 676.91 Mbps
                        [05.10.2022 17:25.07.081] [LOG]   [SPEED] Download: 705.64 Mbps
                        [05.10.2022 17:25.07.182] [LOG]   [SPEED] Download: 820.78 Mbps
                        [05.10.2022 17:25.07.282] [LOG]   [SPEED] Download: 834.69 Mbps
                        [05.10.2022 17:25.07.383] [LOG]   [SPEED] Download: 853.44 Mbps
                        [05.10.2022 17:25.07.484] [LOG]   [SPEED] Download: 866.43 Mbps
                        [05.10.2022 17:25.07.584] [LOG]   [SPEED] Download: 870.64 Mbps
                        [05.10.2022 17:25.07.685] [LOG]   [SPEED] Download: 874.48 Mbps
                        [05.10.2022 17:25.07.786] [LOG]   [SPEED] Download: 880.78 Mbps
                        [05.10.2022 17:25.07.886] [LOG]   [SPEED] Download: 893.37 Mbps
                        [05.10.2022 17:25.07.987] [LOG]   [SPEED] Download: 893.14 Mbps
                        [05.10.2022 17:25.08.087] [LOG]   [SPEED] Download: 894.11 Mbps
                        [05.10.2022 17:25.08.193] [LOG]   [SPEED] Download: 904.29 Mbps
                        [05.10.2022 17:25.08.294] [LOG]   [SPEED] Download: 906.78 Mbps
                        [05.10.2022 17:25.08.395] [LOG]   [SPEED] Download: 906.16 Mbps
                        [05.10.2022 17:25.08.496] [LOG]   [SPEED] Download: 906.67 Mbps
                        [05.10.2022 17:25.08.596] [LOG]   [SPEED] Download: 910.98 Mbps
                        [05.10.2022 17:25.08.697] [LOG]   [SPEED] Download: 907.16 Mbps
                        [05.10.2022 17:25.08.798] [LOG]   [SPEED] Download: 913.58 Mbps
                        [05.10.2022 17:25.08.898] [LOG]   [SPEED] Download: 915.22 Mbps
                        [05.10.2022 17:25.08.999] [LOG]   [SPEED] Download: 917.29 Mbps
                        [05.10.2022 17:25.09.100] [LOG]   [SPEED] Download: 917.54 Mbps
                        [05.10.2022 17:25.09.200] [LOG]   [SPEED] Download: 923.37 Mbps
                        [05.10.2022 17:25.09.301] [LOG]   [SPEED] Download: 926.05 Mbps
                        [05.10.2022 17:25.09.401] [LOG]   [SPEED] Download: 927.50 Mbps
                        [05.10.2022 17:25.09.502] [LOG]   [SPEED] Download: 927.97 Mbps
                        [05.10.2022 17:25.09.603] [LOG]   [SPEED] Download: 929.40 Mbps
                        [05.10.2022 17:25.09.703] [LOG]   [SPEED] Download: 929.66 Mbps
                        [05.10.2022 17:25.09.804] [LOG]   [SPEED] Download: 926.78 Mbps
                        [05.10.2022 17:25.09.904] [LOG]   [SPEED] Download: 930.49 Mbps
                        [05.10.2022 17:25.10.005] [LOG]   [SPEED] Download: 930.71 Mbps
                        [05.10.2022 17:25.10.106] [LOG]   [SPEED] Download: 932.94 Mbps
                        [05.10.2022 17:25.10.206] [LOG]   [SPEED] Download: 931.10 Mbps
                        [05.10.2022 17:25.10.307] [LOG]   [SPEED] Download: 930.12 Mbps
                        [05.10.2022 17:25.10.408] [LOG]   [SPEED] Download: 930.82 Mbps
                        [05.10.2022 17:25.10.509] [LOG]   [SPEED] Download: 934.36 Mbps
                        [05.10.2022 17:25.10.610] [LOG]   [SPEED] Download: 934.38 Mbps
                        [05.10.2022 17:25.10.710] [LOG]   [SPEED] Download: 935.15 Mbps
                        [05.10.2022 17:25.10.811] [LOG]   [SPEED] Download: 936.19 Mbps
                        [05.10.2022 17:25.10.911] [LOG]   [SPEED] Download: 936.61 Mbps
                        [05.10.2022 17:25.11.012] [LOG]   [SPEED] Download: 936.98 Mbps
                        [05.10.2022 17:25.11.112] [LOG]   [SPEED] Download: 937.93 Mbps
                        [05.10.2022 17:25.11.213] [LOG]   [SPEED] Download: 936.38 Mbps
                        [05.10.2022 17:25.11.313] [LOG]   [SPEED] Download: 938.21 Mbps
                        [05.10.2022 17:25.11.415] [LOG]   [SPEED] Download: 937.11 Mbps
                        [05.10.2022 17:25.11.516] [LOG]   [SPEED] Download: 937.77 Mbps
                        [05.10.2022 17:25.11.616] [LOG]   [SPEED] Download: 938.16 Mbps
                        [05.10.2022 17:25.11.717] [LOG]   [SPEED] Download: 938.23 Mbps
                        [05.10.2022 17:25.11.817] [LOG]   [SPEED] Download: 938.43 Mbps
                        [05.10.2022 17:25.11.918] [LOG]   [SPEED] Download: 938.74 Mbps
                        [05.10.2022 17:25.12.021] [LOG]   [SPEED] Download: 937.84 Mbps
                        [05.10.2022 17:25.12.122] [LOG]   [SPEED] Download: 938.20 Mbps
                        [05.10.2022 17:25.12.224] [LOG]   [SPEED] Download: 938.04 Mbps
                        [05.10.2022 17:25.12.325] [LOG]   [SPEED] Download: 937.89 Mbps
                        [05.10.2022 17:25.12.425] [LOG]   [SPEED] Download: 938.51 Mbps
                        [05.10.2022 17:25.12.526] [LOG]   [SPEED] Download: 938.58 Mbps
                        [05.10.2022 17:25.12.627] [LOG]   [SPEED] Download: 938.34 Mbps
                        [05.10.2022 17:25.12.727] [LOG]   [SPEED] Download: 938.65 Mbps
                        [05.10.2022 17:25.12.828] [LOG]   [SPEED] Download: 939.11 Mbps
                        [05.10.2022 17:25.12.928] [LOG]   [SPEED] Download: 938.53 Mbps
                        [05.10.2022 17:25.13.029] [LOG]   [SPEED] Download: 939.36 Mbps
                        [05.10.2022 17:25.13.129] [LOG]   [SPEED] Download: 939.51 Mbps
                        [05.10.2022 17:25.13.230] [LOG]   [SPEED] Download: 939.49 Mbps
                        [05.10.2022 17:25.13.330] [LOG]   [SPEED] Download: 939.04 Mbps
                        [05.10.2022 17:25.13.431] [LOG]   [SPEED] Download: 939.68 Mbps
                        [05.10.2022 17:25.13.532] [LOG]   [SPEED] Download: 939.33 Mbps
                        [05.10.2022 17:25.13.632] [LOG]   [SPEED] Download: 940.43 Mbps
                        [05.10.2022 17:25.13.733] [LOG]   [SPEED] Download: 940.43 Mbps
                        [05.10.2022 17:25.13.833] [LOG]   [SPEED] Download: 940.66 Mbps
                        [05.10.2022 17:25.13.934] [LOG]   [SPEED] Download: 940.26 Mbps
                        [05.10.2022 17:25.14.034] [LOG]   [SPEED] Download: 940.80 Mbps
                        [05.10.2022 17:25.14.135] [LOG]   [SPEED] Download: 939.99 Mbps
                        [05.10.2022 17:25.14.235] [LOG]   [SPEED] Download: 941.33 Mbps
                        [05.10.2022 17:25.14.336] [LOG]   [SPEED] Download: 940.78 Mbps
                        [05.10.2022 17:25.14.437] [LOG]   [SPEED] Download: 940.89 Mbps
                        [05.10.2022 17:25.14.537] [LOG]   [SPEED] Download: 939.52 Mbps
                        [05.10.2022 17:25.14.638] [LOG]   [SPEED] Download: 941.53 Mbps
                        [05.10.2022 17:25.14.739] [LOG]   [SPEED] Download: 940.80 Mbps
                        [05.10.2022 17:25.14.839] [LOG]   [SPEED] Download: 941.01 Mbps
                        [05.10.2022 17:25.14.939] [LOG]   [SPEED] Download: 940.96 Mbps
                        [05.10.2022 17:25.14.973] [LOG]   [SPEED] Download: 940.70 Mbps
                        [05.10.2022 17:25.15.326] [LOG]   [SPEED] Upload: 571.68 Mbps
                        [05.10.2022 17:25.15.427] [LOG]   [SPEED] Upload: 596.83 Mbps
                        [05.10.2022 17:25.15.527] [LOG]   [SPEED] Upload: 615.15 Mbps
                        [05.10.2022 17:25.15.629] [LOG]   [SPEED] Upload: 624.40 Mbps
                        [05.10.2022 17:25.15.729] [LOG]   [SPEED] Upload: 631.77 Mbps
                        [05.10.2022 17:25.15.830] [LOG]   [SPEED] Upload: 636.47 Mbps
                        [05.10.2022 17:25.15.931] [LOG]   [SPEED] Upload: 640.61 Mbps
                        [05.10.2022 17:25.16.031] [LOG]   [SPEED] Upload: 644.16 Mbps
                        [05.10.2022 17:25.16.132] [LOG]   [SPEED] Upload: 646.54 Mbps
                        [05.10.2022 17:25.16.233] [LOG]   [SPEED] Upload: 648.11 Mbps
                        [05.10.2022 17:25.16.334] [LOG]   [SPEED] Upload: 650.32 Mbps
                        [05.10.2022 17:25.16.434] [LOG]   [SPEED] Upload: 647.69 Mbps
                        [05.10.2022 17:25.16.535] [LOG]   [SPEED] Upload: 649.62 Mbps
                        [05.10.2022 17:25.16.636] [LOG]   [SPEED] Upload: 648.94 Mbps
                        [05.10.2022 17:25.16.736] [LOG]   [SPEED] Upload: 649.55 Mbps
                        [05.10.2022 17:25.16.837] [LOG]   [SPEED] Upload: 650.22 Mbps
                        [05.10.2022 17:25.16.938] [LOG]   [SPEED] Upload: 651.65 Mbps
                        [05.10.2022 17:25.17.039] [LOG]   [SPEED] Upload: 652.29 Mbps
                        [05.10.2022 17:25.17.139] [LOG]   [SPEED] Upload: 655.27 Mbps
                        [05.10.2022 17:25.17.240] [LOG]   [SPEED] Upload: 657.43 Mbps
                        [05.10.2022 17:25.17.341] [LOG]   [SPEED] Upload: 658.04 Mbps
                        [05.10.2022 17:25.17.442] [LOG]   [SPEED] Upload: 658.68 Mbps
                        [05.10.2022 17:25.17.542] [LOG]   [SPEED] Upload: 667.05 Mbps
                        [05.10.2022 17:25.17.643] [LOG]   [SPEED] Upload: 667.09 Mbps
                        [05.10.2022 17:25.17.744] [LOG]   [SPEED] Upload: 667.35 Mbps
                        [05.10.2022 17:25.17.844] [LOG]   [SPEED] Upload: 667.49 Mbps
                        [05.10.2022 17:25.17.945] [LOG]   [SPEED] Upload: 666.08 Mbps
                        [05.10.2022 17:25.18.046] [LOG]   [SPEED] Upload: 665.42 Mbps
                        [05.10.2022 17:25.18.146] [LOG]   [SPEED] Upload: 665.49 Mbps
                        [05.10.2022 17:25.18.247] [LOG]   [SPEED] Upload: 665.38 Mbps
                        [05.10.2022 17:25.18.347] [LOG]   [SPEED] Upload: 666.88 Mbps
                        [05.10.2022 17:25.18.449] [LOG]   [SPEED] Upload: 667.77 Mbps
                        [05.10.2022 17:25.18.549] [LOG]   [SPEED] Upload: 668.95 Mbps
                        [05.10.2022 17:25.18.649] [LOG]   [SPEED] Upload: 669.30 Mbps
                        [05.10.2022 17:25.18.750] [LOG]   [SPEED] Upload: 669.47 Mbps
                        [05.10.2022 17:25.18.851] [LOG]   [SPEED] Upload: 669.47 Mbps
                        [05.10.2022 17:25.18.952] [LOG]   [SPEED] Upload: 669.74 Mbps
                        [05.10.2022 17:25.19.052] [LOG]   [SPEED] Upload: 669.76 Mbps
                        [05.10.2022 17:25.19.153] [LOG]   [SPEED] Upload: 668.45 Mbps
                        [05.10.2022 17:25.19.254] [LOG]   [SPEED] Upload: 668.17 Mbps
                        [05.10.2022 17:25.19.354] [LOG]   [SPEED] Upload: 666.30 Mbps
                        [05.10.2022 17:25.19.455] [LOG]   [SPEED] Upload: 664.88 Mbps
                        [05.10.2022 17:25.19.556] [LOG]   [SPEED] Upload: 663.21 Mbps
                        [05.10.2022 17:25.19.658] [LOG]   [SPEED] Upload: 663.05 Mbps
                        [05.10.2022 17:25.19.758] [LOG]   [SPEED] Upload: 662.47 Mbps
                        [05.10.2022 17:25.19.859] [LOG]   [SPEED] Upload: 662.36 Mbps
                        [05.10.2022 17:25.19.960] [LOG]   [SPEED] Upload: 661.67 Mbps
                        [05.10.2022 17:25.20.060] [LOG]   [SPEED] Upload: 662.10 Mbps
                        [05.10.2022 17:25.20.161] [LOG]   [SPEED] Upload: 662.88 Mbps
                        [05.10.2022 17:25.20.262] [LOG]   [SPEED] Upload: 663.91 Mbps
                        [05.10.2022 17:25.20.362] [LOG]   [SPEED] Upload: 664.68 Mbps
                        [05.10.2022 17:25.20.463] [LOG]   [SPEED] Upload: 664.89 Mbps
                        [05.10.2022 17:25.20.564] [LOG]   [SPEED] Upload: 664.85 Mbps
                        [05.10.2022 17:25.20.665] [LOG]   [SPEED] Upload: 665.50 Mbps
                        [05.10.2022 17:25.20.765] [LOG]   [SPEED] Upload: 665.55 Mbps
                        [05.10.2022 17:25.20.866] [LOG]   [SPEED] Upload: 665.73 Mbps
                        [05.10.2022 17:25.20.967] [LOG]   [SPEED] Upload: 665.68 Mbps
                        [05.10.2022 17:25.21.067] [LOG]   [SPEED] Upload: 664.60 Mbps
                        [05.10.2022 17:25.21.169] [LOG]   [SPEED] Upload: 666.06 Mbps
                        [05.10.2022 17:25.21.269] [LOG]   [SPEED] Upload: 666.48 Mbps
                        [05.10.2022 17:25.21.370] [LOG]   [SPEED] Upload: 666.63 Mbps
                        [05.10.2022 17:25.21.471] [LOG]   [SPEED] Upload: 666.78 Mbps
                        [05.10.2022 17:25.21.571] [LOG]   [SPEED] Upload: 666.96 Mbps
                        [05.10.2022 17:25.21.672] [LOG]   [SPEED] Upload: 666.07 Mbps
                        [05.10.2022 17:25.21.774] [LOG]   [SPEED] Upload: 665.40 Mbps
                        [05.10.2022 17:25.21.874] [LOG]   [SPEED] Upload: 665.38 Mbps
                        [05.10.2022 17:25.21.974] [LOG]   [SPEED] Upload: 665.46 Mbps
                        [05.10.2022 17:25.22.076] [LOG]   [SPEED] Upload: 665.60 Mbps
                        [05.10.2022 17:25.22.177] [LOG]   [SPEED] Upload: 665.71 Mbps
                        [05.10.2022 17:25.22.244] [LOG]   [SPEED] Upload: 665.87 Mbps
                        [05.10.2022 17:25.22.898] [LOG]   [SPEED] Result: {
                          timestamp: 2022-10-05T15:25:22.000Z,
                          ping: { jitter: 0.353, latency: 14.293 },
                          download: { bandwidth: 117587756, bytes: 958119880, elapsed: 8206 },
                          upload: { bandwidth: 83233466, bytes: 596812565, elapsed: 7211 },
                          packetLoss: 0,
                          isp: 'Free SAS',
                          interface: {
                            internalIp: '192.168.0.138',
                            macAddr: 'xx:xx:xx:xx:xx:x',
                            isVpn: false,
                            externalIp: 'xxx.xxx.xxx'
                          server: {
                            country: 'Belgium',
                            host: 'speedtest.arcadiz.net',
                            port: 8080,
                            ip: '185.160.128.145'
                          result: {
                            url: 'https://www.speedtest.net/result/c/82415bc5-9799-4ec2-949c-b1a69d1774a4'
                        [05.10.2022 17:25.22.899] [LOG]   [SPEED] Done
                        [05.10.2022 17:25.22.899] [LOG]   [SPEED] Update Programmed
                        I’m not a magician :)
                        I just follow speedtest v2.2.0 usage in the ReadMe file of this library.
                        Note: That you can see in debug: https://www.speedtest.net/result/c/82415bc5-9799-4ec2-949c-b1a69d1774a4 is the shared link of this speedtest
                        It’s the same like MM² return
                        S B 2 Replies Last reply Reply Quote 0
                          sdetweil @bugsounet
                          @bugsounet said in Internet Monitor:
                          the problem is under windows, this path is bad as it doesn’t have \
                          unfortunately NPM is NOT platform neutral
                          you can’t even do it with a .cmd (and bash script without .sh) in the current folder…
                          as windows would work, but then linux would fail as current folder not in the PATH
                          I wrote a js file that could be launched on either and launch the right thing
                          but a pain in the rear
                          bugsounetB 1 Reply Last reply Reply Quote 1
                          • bugsounetB
                            bugsounet Banned @sdetweil
                            That why i says :
                            I’m glad that you use windows 😧
                            Now retry with your pi, a linux env or … with wsl under windows 😉
                              Because using speedtest-net after this version requires a code change.
                              Oh, great. I develop on Windows so I can make use of a proper IDE. Fine. I’ll dig up something.
                              @sdetweil said in Internet Monitor:
                              Sigh. It figures. Not tonight, but I’ll work on it in the near future.
                                Okay, I believe I have it fixed for this module. Please switch over to the 2022-fix branch and give it a pull & install. Let me know if it works for you and I’ll issue a PR.
                                Big shout out to @bugsounet for figuring it out and from whom I blatantly stole a lot of code. At some point I remembered that this isn’t my module and I’m just trying to get it functioning again. It helped me ignore a lot of things I would have changed.
                                  mayfield @bhepler
                                  @bhepler Where do you find the update? is this the right link? https://github.com/ronny3050/internet-monitor
                                    bhepler Module Developer @mayfield
                                    @mayfield - No. Install from here: https://github.com/BrianHepler/internet-monitor.git
                                    If you have installed from Ronny3050’s repository, you’ll need to delete that folder and clone from mine.
                                      bhepler Module Developer @bhepler
                                      I suppose more detailed instructions are in order. To use my development branch of my fork of the internet-monitor module, give this a try.
                                      cd MagicMirror/modules
                                      sudo rm -rf internet-monitor
                                      git clone https://github.com/BrianHepler/internet-monitor.git
                                      cd internet-monitor
                                      switch 2022-fix
                                      npm install
                                      Once it is done, you should be able to use your existing configuration. Let me know if you encounter any problems.
                                        My fork of the module has been updated and the new code has been merged to the master branch. Let me know if you hit any issues with it.
                                        • E
                                          ebourne @bhepler
                                          @bhepler what do you mean by switch 2022-fix?
                                          I am trying to get this module working but it seems the config file example has an error in it or something because when i run the mirror after copy pasting the module array it gives the error page
                                            bhepler Module Developer @ebourne
                                            @ebourne I had a branch of the internet-monitor module that I was using to test a fix. Before I merge it into the master branch, I wanted people to try out the fix and give me some feedback. I guess I never got around to deleting it. The master branch had the updates, so it’s not a big deal.
                                            Thanks to @KristjanESPERANTO I have a new fix in place and it has been merged into the master branch. It should be easy to update the module:
                                            • get an SSH connection to your mirror.
                                            • navigate to the internet-monitor folder
                                            • pull the latest updates with git pull
                                            • install the changes with npm install
                                            Restart your magic mirror process and it should work again.
                                            Just a quick note: I don’t really maintain this module. I created a fork to get it running a long time ago after the author abandoned it. I try to help out from time to time, but this is not one of my priorities. Hence, the README file and example configuration are a bit of a mess.
                                            • 5 / 6
