    Internet Monitor
    108 Posts 27 Posters 166.2k Views 30 Watching
      bhepler Module Developer
      Okay, I have completed my first pass at fixing the WiFi symbol. It works for me, so let’s see how it goes for you.
      If you’re not using my repository, you’ll have to switch by deleting your modules/internet-monitor folder, cloning from my repository at https://github.com/BrianHepler/internet-monitor and then installing like normal. You’ll have to cd internet-monitor and then npm install.
      If you’re already using my repository, just cd MagicMirror/modules/internet-monitor and git pull. It will probably tell you that you need to stash package-lock.json. Just delete that file and try again.
      Warning: The custom WiFi icon doesn’t work yet. I got the default one to show up, but I’m still working on the one with the custom colors. But right now I want to verify that you guys can at least see the WiFi icon.
      rafaelcotaR A 2 Replies Last reply Reply Quote 1
      • rafaelcotaR
        rafaelcota @bhepler
        @bhepler said in Internet Monitor:
        Now it works
        • A
          Axel51 @bhepler
          @bhepler
          I can see the wifi icon but no color icon is visible!!!
          Something is missing in the source code to update the icon.
          Can you have a look and correct it please?
          best regards,
          Adel
            pgwr @Axel51
            @Axel51 Is the wifi icon ovelaying the label “Internet Monitor” on yours? I’d like to be able to be able to see the full label. Maybe I missed something. Thanks
              causerino
              Has this died recently for anyone else? I have made no config changes and it’s stopped working. I’ve tried with a new server ID in case they have changed, but still no luck.
              //New Module Internet Monitor
                                      module: 'internet-monitor',
                                      position: 'top_left',
                                      header: 'SpeedTest',
                                      config:{
                                              type: '',
                                              maxTime: 20000,
                                              updateInterval: 0,
                                              verbose: false,
                                              serverId: "40788",
              //                              displayStrength: true,
                                              displaySpeed: true,
                                              strengthIconSize: 50,
                                              maxGaugeScale: 1000,
              S B 3 Replies Last reply Reply Quote 0
                sdetweil @causerino
                @causerino comment out serverid and let it use any
                add
                to the beginning of the line
                  sdetweil @causerino
                  @causerino also, please use code blocks for any config data
                  paste text
                  select text
                  then push button that looks like
                  I have fixed your post
                    bhepler Module Developer @causerino
                    @causerino said in Internet Monitor:
                    I can confirm. It appears that the speedtest service is down. I’m troubleshooting now.
                    Update: Problem is with the speedtest-net package. Not sure what the problem is, but it has been down for the past week. They’ve opened an issue with the developers, so hopefully they’ll get around to it. The SpeedTest website and their paid services appear to be working, so something is up with the API.
                    I’m looking at my fork of the original repository and the latest changes to speedtest-net and I’m going to prep an update. Once it comes back, I’ll publish.
                      causerino @bhepler
                      Thanks very much for doing this :)
                      bugsounetB 1 Reply Last reply Reply Quote 0
                      • bugsounetB
                        bugsounet Banned @causerino
                        Are you really sure ?
                        i use it with MMM-SpeedTest
                        Result is:
                          bhepler Module Developer @bugsounet
                          @bugsounet - Pretty sure.
                          Here is the GitHub discussion on the problem.
                          EtA: I am having problems installing MMM-SpeedTest.
                          PS J:\Development\MagicMirrors\MagicMirror\modules> git clone https://github.com/bugsounet/MMM-SpeedTest
                          Cloning into 'MMM-SpeedTest'...
                          remote: Enumerating objects: 78, done.
                          remote: Counting objects: 100% (78/78), done.
                          remote: Compressing objects: 100% (66/66), done.
                          remote: Total 78 (delta 33), reused 33 (delta 10), pack-reused 0
                          Unpacking objects: 100% (78/78), 120.78 KiB | 46.00 KiB/s, done.
                          PS J:\Development\MagicMirrors\MagicMirror\modules> cd .\MMM-SpeedTest\
                          PS J:\Development\MagicMirrors\MagicMirror\modules\MMM-SpeedTest> npm install
                          > MMM-SpeedTest@1.0.3 preinstall J:\Development\MagicMirrors\MagicMirror\modules\MMM-SpeedTest
                          > installer/preinstall.sh
                          'installer' is not recognized as an internal or external command,
                          operable program or batch file.
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno 1
                          npm ERR! MMM-SpeedTest@1.0.3 preinstall: `installer/preinstall.sh`
                          npm ERR! Exit status 1
                          npm ERR!
                          npm ERR! Failed at the MMM-SpeedTest@1.0.3 preinstall script.
                          npm WARN Local package.json exists, but node_modules missing, did you mean to install?
                          • bugsounetB
                            bugsounet Banned @bhepler
                            npm ERR! errno 1
                            npm ERR!
                            1. the real question is why using v1.6.2 version of SpeedTest library?
                              v2.2.0 solve the problem ;)
                            2. I’m glad that you use windows :anguished_face:
                              Now retry with your pi, a linux env or … with wsl under windows ;)
                            and result is:
                            bugsounet@bugsounet-Kubuntu:~/MagicMirror/modules/MMM-SpeedTest$ npm install
                            Welcome to MMM-SpeedTest v1.0.3
                            > MMM-SpeedTest@1.0.3 postinstall
                            > installer/postinstall.sh
                            Building SpeedTest module, please wait...
                            added 325 packages, and audited 326 packages in 53s
                            28 packages are looking for funding
                              run `npm fund` for details
                            Screenshot:
                            Logs in debug mode:
                            [05.10.2022 17:25.06.650] [LOG]   [SPEED] Ping: 15.028 ms
                            [05.10.2022 17:25.06.664] [LOG]   [SPEED] Ping: 14.293 ms
                            [05.10.2022 17:25.06.679] [LOG]   [SPEED] Ping: 14.511 ms
                            [05.10.2022 17:25.06.694] [LOG]   [SPEED] Ping: 14.89 ms
                            [05.10.2022 17:25.06.709] [LOG]   [SPEED] Ping: 14.293 ms
                            [05.10.2022 17:25.06.778] [LOG]   [SPEED] Download: 32.84 Mbps
                            [05.10.2022 17:25.06.879] [LOG]   [SPEED] Download: 355.00 Mbps
                            [05.10.2022 17:25.06.980] [LOG]   [SPEED] Download: 676.91 Mbps
                            [05.10.2022 17:25.07.081] [LOG]   [SPEED] Download: 705.64 Mbps
                            [05.10.2022 17:25.07.182] [LOG]   [SPEED] Download: 820.78 Mbps
                            [05.10.2022 17:25.07.282] [LOG]   [SPEED] Download: 834.69 Mbps
                            [05.10.2022 17:25.07.383] [LOG]   [SPEED] Download: 853.44 Mbps
                            [05.10.2022 17:25.07.484] [LOG]   [SPEED] Download: 866.43 Mbps
                            [05.10.2022 17:25.07.584] [LOG]   [SPEED] Download: 870.64 Mbps
                            [05.10.2022 17:25.07.685] [LOG]   [SPEED] Download: 874.48 Mbps
                            [05.10.2022 17:25.07.786] [LOG]   [SPEED] Download: 880.78 Mbps
                            [05.10.2022 17:25.07.886] [LOG]   [SPEED] Download: 893.37 Mbps
                            [05.10.2022 17:25.07.987] [LOG]   [SPEED] Download: 893.14 Mbps
                            [05.10.2022 17:25.08.087] [LOG]   [SPEED] Download: 894.11 Mbps
                            [05.10.2022 17:25.08.193] [LOG]   [SPEED] Download: 904.29 Mbps
                            [05.10.2022 17:25.08.294] [LOG]   [SPEED] Download: 906.78 Mbps
                            [05.10.2022 17:25.08.395] [LOG]   [SPEED] Download: 906.16 Mbps
                            [05.10.2022 17:25.08.496] [LOG]   [SPEED] Download: 906.67 Mbps
                            [05.10.2022 17:25.08.596] [LOG]   [SPEED] Download: 910.98 Mbps
                            [05.10.2022 17:25.08.697] [LOG]   [SPEED] Download: 907.16 Mbps
                            [05.10.2022 17:25.08.798] [LOG]   [SPEED] Download: 913.58 Mbps
                            [05.10.2022 17:25.08.898] [LOG]   [SPEED] Download: 915.22 Mbps
                            [05.10.2022 17:25.08.999] [LOG]   [SPEED] Download: 917.29 Mbps
                            [05.10.2022 17:25.09.100] [LOG]   [SPEED] Download: 917.54 Mbps
                            [05.10.2022 17:25.09.200] [LOG]   [SPEED] Download: 923.37 Mbps
                            [05.10.2022 17:25.09.301] [LOG]   [SPEED] Download: 926.05 Mbps
                            [05.10.2022 17:25.09.401] [LOG]   [SPEED] Download: 927.50 Mbps
                            [05.10.2022 17:25.09.502] [LOG]   [SPEED] Download: 927.97 Mbps
                            [05.10.2022 17:25.09.603] [LOG]   [SPEED] Download: 929.40 Mbps
                            [05.10.2022 17:25.09.703] [LOG]   [SPEED] Download: 929.66 Mbps
                            [05.10.2022 17:25.09.804] [LOG]   [SPEED] Download: 926.78 Mbps
                            [05.10.2022 17:25.09.904] [LOG]   [SPEED] Download: 930.49 Mbps
                            [05.10.2022 17:25.10.005] [LOG]   [SPEED] Download: 930.71 Mbps
                            [05.10.2022 17:25.10.106] [LOG]   [SPEED] Download: 932.94 Mbps
                            [05.10.2022 17:25.10.206] [LOG]   [SPEED] Download: 931.10 Mbps
                            [05.10.2022 17:25.10.307] [LOG]   [SPEED] Download: 930.12 Mbps
                            [05.10.2022 17:25.10.408] [LOG]   [SPEED] Download: 930.82 Mbps
                            [05.10.2022 17:25.10.509] [LOG]   [SPEED] Download: 934.36 Mbps
                            [05.10.2022 17:25.10.610] [LOG]   [SPEED] Download: 934.38 Mbps
                            [05.10.2022 17:25.10.710] [LOG]   [SPEED] Download: 935.15 Mbps
                            [05.10.2022 17:25.10.811] [LOG]   [SPEED] Download: 936.19 Mbps
                            [05.10.2022 17:25.10.911] [LOG]   [SPEED] Download: 936.61 Mbps
                            [05.10.2022 17:25.11.012] [LOG]   [SPEED] Download: 936.98 Mbps
                            [05.10.2022 17:25.11.112] [LOG]   [SPEED] Download: 937.93 Mbps
                            [05.10.2022 17:25.11.213] [LOG]   [SPEED] Download: 936.38 Mbps
                            [05.10.2022 17:25.11.313] [LOG]   [SPEED] Download: 938.21 Mbps
                            [05.10.2022 17:25.11.415] [LOG]   [SPEED] Download: 937.11 Mbps
                            [05.10.2022 17:25.11.516] [LOG]   [SPEED] Download: 937.77 Mbps
                            [05.10.2022 17:25.11.616] [LOG]   [SPEED] Download: 938.16 Mbps
                            [05.10.2022 17:25.11.717] [LOG]   [SPEED] Download: 938.23 Mbps
                            [05.10.2022 17:25.11.817] [LOG]   [SPEED] Download: 938.43 Mbps
                            [05.10.2022 17:25.11.918] [LOG]   [SPEED] Download: 938.74 Mbps
                            [05.10.2022 17:25.12.021] [LOG]   [SPEED] Download: 937.84 Mbps
                            [05.10.2022 17:25.12.122] [LOG]   [SPEED] Download: 938.20 Mbps
                            [05.10.2022 17:25.12.224] [LOG]   [SPEED] Download: 938.04 Mbps
                            [05.10.2022 17:25.12.325] [LOG]   [SPEED] Download: 937.89 Mbps
                            [05.10.2022 17:25.12.425] [LOG]   [SPEED] Download: 938.51 Mbps
                            [05.10.2022 17:25.12.526] [LOG]   [SPEED] Download: 938.58 Mbps
                            [05.10.2022 17:25.12.627] [LOG]   [SPEED] Download: 938.34 Mbps
                            [05.10.2022 17:25.12.727] [LOG]   [SPEED] Download: 938.65 Mbps
                            [05.10.2022 17:25.12.828] [LOG]   [SPEED] Download: 939.11 Mbps
                            [05.10.2022 17:25.12.928] [LOG]   [SPEED] Download: 938.53 Mbps
                            [05.10.2022 17:25.13.029] [LOG]   [SPEED] Download: 939.36 Mbps
                            [05.10.2022 17:25.13.129] [LOG]   [SPEED] Download: 939.51 Mbps
                            [05.10.2022 17:25.13.230] [LOG]   [SPEED] Download: 939.49 Mbps
                            [05.10.2022 17:25.13.330] [LOG]   [SPEED] Download: 939.04 Mbps
                            [05.10.2022 17:25.13.431] [LOG]   [SPEED] Download: 939.68 Mbps
                            [05.10.2022 17:25.13.532] [LOG]   [SPEED] Download: 939.33 Mbps
                            [05.10.2022 17:25.13.632] [LOG]   [SPEED] Download: 940.43 Mbps
                            [05.10.2022 17:25.13.733] [LOG]   [SPEED] Download: 940.43 Mbps
                            [05.10.2022 17:25.13.833] [LOG]   [SPEED] Download: 940.66 Mbps
                            [05.10.2022 17:25.13.934] [LOG]   [SPEED] Download: 940.26 Mbps
                            [05.10.2022 17:25.14.034] [LOG]   [SPEED] Download: 940.80 Mbps
                            [05.10.2022 17:25.14.135] [LOG]   [SPEED] Download: 939.99 Mbps
                            [05.10.2022 17:25.14.235] [LOG]   [SPEED] Download: 941.33 Mbps
                            [05.10.2022 17:25.14.336] [LOG]   [SPEED] Download: 940.78 Mbps
                            [05.10.2022 17:25.14.437] [LOG]   [SPEED] Download: 940.89 Mbps
                            [05.10.2022 17:25.14.537] [LOG]   [SPEED] Download: 939.52 Mbps
                            [05.10.2022 17:25.14.638] [LOG]   [SPEED] Download: 941.53 Mbps
                            [05.10.2022 17:25.14.739] [LOG]   [SPEED] Download: 940.80 Mbps
                            [05.10.2022 17:25.14.839] [LOG]   [SPEED] Download: 941.01 Mbps
                            [05.10.2022 17:25.14.939] [LOG]   [SPEED] Download: 940.96 Mbps
                            [05.10.2022 17:25.14.973] [LOG]   [SPEED] Download: 940.70 Mbps
                            [05.10.2022 17:25.15.326] [LOG]   [SPEED] Upload: 571.68 Mbps
                            [05.10.2022 17:25.15.427] [LOG]   [SPEED] Upload: 596.83 Mbps
                            [05.10.2022 17:25.15.527] [LOG]   [SPEED] Upload: 615.15 Mbps
                            [05.10.2022 17:25.15.629] [LOG]   [SPEED] Upload: 624.40 Mbps
                            [05.10.2022 17:25.15.729] [LOG]   [SPEED] Upload: 631.77 Mbps
                            [05.10.2022 17:25.15.830] [LOG]   [SPEED] Upload: 636.47 Mbps
                            [05.10.2022 17:25.15.931] [LOG]   [SPEED] Upload: 640.61 Mbps
                            [05.10.2022 17:25.16.031] [LOG]   [SPEED] Upload: 644.16 Mbps
                            [05.10.2022 17:25.16.132] [LOG]   [SPEED] Upload: 646.54 Mbps
                            [05.10.2022 17:25.16.233] [LOG]   [SPEED] Upload: 648.11 Mbps
                            [05.10.2022 17:25.16.334] [LOG]   [SPEED] Upload: 650.32 Mbps
                            [05.10.2022 17:25.16.434] [LOG]   [SPEED] Upload: 647.69 Mbps
                            [05.10.2022 17:25.16.535] [LOG]   [SPEED] Upload: 649.62 Mbps
                            [05.10.2022 17:25.16.636] [LOG]   [SPEED] Upload: 648.94 Mbps
                            [05.10.2022 17:25.16.736] [LOG]   [SPEED] Upload: 649.55 Mbps
                            [05.10.2022 17:25.16.837] [LOG]   [SPEED] Upload: 650.22 Mbps
                            [05.10.2022 17:25.16.938] [LOG]   [SPEED] Upload: 651.65 Mbps
                            [05.10.2022 17:25.17.039] [LOG]   [SPEED] Upload: 652.29 Mbps
                            [05.10.2022 17:25.17.139] [LOG]   [SPEED] Upload: 655.27 Mbps
                            [05.10.2022 17:25.17.240] [LOG]   [SPEED] Upload: 657.43 Mbps
                            [05.10.2022 17:25.17.341] [LOG]   [SPEED] Upload: 658.04 Mbps
                            [05.10.2022 17:25.17.442] [LOG]   [SPEED] Upload: 658.68 Mbps
                            [05.10.2022 17:25.17.542] [LOG]   [SPEED] Upload: 667.05 Mbps
                            [05.10.2022 17:25.17.643] [LOG]   [SPEED] Upload: 667.09 Mbps
                            [05.10.2022 17:25.17.744] [LOG]   [SPEED] Upload: 667.35 Mbps
                            [05.10.2022 17:25.17.844] [LOG]   [SPEED] Upload: 667.49 Mbps
                            [05.10.2022 17:25.17.945] [LOG]   [SPEED] Upload: 666.08 Mbps
                            [05.10.2022 17:25.18.046] [LOG]   [SPEED] Upload: 665.42 Mbps
                            [05.10.2022 17:25.18.146] [LOG]   [SPEED] Upload: 665.49 Mbps
                            [05.10.2022 17:25.18.247] [LOG]   [SPEED] Upload: 665.38 Mbps
                            [05.10.2022 17:25.18.347] [LOG]   [SPEED] Upload: 666.88 Mbps
                            [05.10.2022 17:25.18.449] [LOG]   [SPEED] Upload: 667.77 Mbps
                            [05.10.2022 17:25.18.549] [LOG]   [SPEED] Upload: 668.95 Mbps
                            [05.10.2022 17:25.18.649] [LOG]   [SPEED] Upload: 669.30 Mbps
                            [05.10.2022 17:25.18.750] [LOG]   [SPEED] Upload: 669.47 Mbps
                            [05.10.2022 17:25.18.851] [LOG]   [SPEED] Upload: 669.47 Mbps
                            [05.10.2022 17:25.18.952] [LOG]   [SPEED] Upload: 669.74 Mbps
                            [05.10.2022 17:25.19.052] [LOG]   [SPEED] Upload: 669.76 Mbps
                            [05.10.2022 17:25.19.153] [LOG]   [SPEED] Upload: 668.45 Mbps
                            [05.10.2022 17:25.19.254] [LOG]   [SPEED] Upload: 668.17 Mbps
                            [05.10.2022 17:25.19.354] [LOG]   [SPEED] Upload: 666.30 Mbps
                            [05.10.2022 17:25.19.455] [LOG]   [SPEED] Upload: 664.88 Mbps
                            [05.10.2022 17:25.19.556] [LOG]   [SPEED] Upload: 663.21 Mbps
                            [05.10.2022 17:25.19.658] [LOG]   [SPEED] Upload: 663.05 Mbps
                            [05.10.2022 17:25.19.758] [LOG]   [SPEED] Upload: 662.47 Mbps
                            [05.10.2022 17:25.19.859] [LOG]   [SPEED] Upload: 662.36 Mbps
                            [05.10.2022 17:25.19.960] [LOG]   [SPEED] Upload: 661.67 Mbps
                            [05.10.2022 17:25.20.060] [LOG]   [SPEED] Upload: 662.10 Mbps
                            [05.10.2022 17:25.20.161] [LOG]   [SPEED] Upload: 662.88 Mbps
                            [05.10.2022 17:25.20.262] [LOG]   [SPEED] Upload: 663.91 Mbps
                            [05.10.2022 17:25.20.362] [LOG]   [SPEED] Upload: 664.68 Mbps
                            [05.10.2022 17:25.20.463] [LOG]   [SPEED] Upload: 664.89 Mbps
                            [05.10.2022 17:25.20.564] [LOG]   [SPEED] Upload: 664.85 Mbps
                            [05.10.2022 17:25.20.665] [LOG]   [SPEED] Upload: 665.50 Mbps
                            [05.10.2022 17:25.20.765] [LOG]   [SPEED] Upload: 665.55 Mbps
                            [05.10.2022 17:25.20.866] [LOG]   [SPEED] Upload: 665.73 Mbps
                            [05.10.2022 17:25.20.967] [LOG]   [SPEED] Upload: 665.68 Mbps
                            [05.10.2022 17:25.21.067] [LOG]   [SPEED] Upload: 664.60 Mbps
                            [05.10.2022 17:25.21.169] [LOG]   [SPEED] Upload: 666.06 Mbps
                            [05.10.2022 17:25.21.269] [LOG]   [SPEED] Upload: 666.48 Mbps
                            [05.10.2022 17:25.21.370] [LOG]   [SPEED] Upload: 666.63 Mbps
                            [05.10.2022 17:25.21.471] [LOG]   [SPEED] Upload: 666.78 Mbps
                            [05.10.2022 17:25.21.571] [LOG]   [SPEED] Upload: 666.96 Mbps
                            [05.10.2022 17:25.21.672] [LOG]   [SPEED] Upload: 666.07 Mbps
                            [05.10.2022 17:25.21.774] [LOG]   [SPEED] Upload: 665.40 Mbps
                            [05.10.2022 17:25.21.874] [LOG]   [SPEED] Upload: 665.38 Mbps
                            [05.10.2022 17:25.21.974] [LOG]   [SPEED] Upload: 665.46 Mbps
                            [05.10.2022 17:25.22.076] [LOG]   [SPEED] Upload: 665.60 Mbps
                            [05.10.2022 17:25.22.177] [LOG]   [SPEED] Upload: 665.71 Mbps
                            [05.10.2022 17:25.22.244] [LOG]   [SPEED] Upload: 665.87 Mbps
                            [05.10.2022 17:25.22.898] [LOG]   [SPEED] Result: {
                              timestamp: 2022-10-05T15:25:22.000Z,
                              ping: { jitter: 0.353, latency: 14.293 },
                              download: { bandwidth: 117587756, bytes: 958119880, elapsed: 8206 },
                              upload: { bandwidth: 83233466, bytes: 596812565, elapsed: 7211 },
                              packetLoss: 0,
                              isp: 'Free SAS',
                              interface: {
                                internalIp: '192.168.0.138',
                                macAddr: 'xx:xx:xx:xx:xx:x',
                                isVpn: false,
                                externalIp: 'xxx.xxx.xxx'
                              server: {
                                country: 'Belgium',
                                host: 'speedtest.arcadiz.net',
                                port: 8080,
                                ip: '185.160.128.145'
                              result: {
                                url: 'https://www.speedtest.net/result/c/82415bc5-9799-4ec2-949c-b1a69d1774a4'
                            [05.10.2022 17:25.22.899] [LOG]   [SPEED] Done
                            [05.10.2022 17:25.22.899] [LOG]   [SPEED] Update Programmed
                            I’m not a magician :)
                            I just follow speedtest v2.2.0 usage in the ReadMe file of this library.
                            Note: That you can see in debug: https://www.speedtest.net/result/c/82415bc5-9799-4ec2-949c-b1a69d1774a4 is the shared link of this speedtest
                            It’s the same like MM² return
                            S B 2 Replies Last reply Reply Quote 0
                              sdetweil @bugsounet
                              @bugsounet said in Internet Monitor:
                              the problem is under windows, this path is bad as it doesn’t have \
                              unfortunately NPM is NOT platform neutral
                              you can’t even do it with a .cmd (and bash script without .sh) in the current folder…
                              as windows would work, but then linux would fail as current folder not in the PATH
                              I wrote a js file that could be launched on either and launch the right thing
                              but a pain in the rear
                              bugsounetB 1 Reply Last reply Reply Quote 1
                              • bugsounetB
                                bugsounet Banned @sdetweil
                                That why i says :
                                I’m glad that you use windows 😧
                                Now retry with your pi, a linux env or … with wsl under windows 😉
                                  Because using speedtest-net after this version requires a code change.
                                  Oh, great. I develop on Windows so I can make use of a proper IDE. Fine. I’ll dig up something.
                                  @sdetweil said in Internet Monitor:
                                  Sigh. It figures. Not tonight, but I’ll work on it in the near future.
                                    Okay, I believe I have it fixed for this module. Please switch over to the 2022-fix branch and give it a pull & install. Let me know if it works for you and I’ll issue a PR.
                                    Big shout out to @bugsounet for figuring it out and from whom I blatantly stole a lot of code. At some point I remembered that this isn’t my module and I’m just trying to get it functioning again. It helped me ignore a lot of things I would have changed.
                                      mayfield @bhepler
                                      @bhepler Where do you find the update? is this the right link? https://github.com/ronny3050/internet-monitor
                                        bhepler Module Developer @mayfield
                                        @mayfield - No. Install from here: https://github.com/BrianHepler/internet-monitor.git
                                        If you have installed from Ronny3050’s repository, you’ll need to delete that folder and clone from mine.
                                          bhepler Module Developer @bhepler
                                          I suppose more detailed instructions are in order. To use my development branch of my fork of the internet-monitor module, give this a try.
                                          sudo rm -rf internet-monitor
                                          git clone https://github.com/BrianHepler/internet-monitor.git
                                          cd internet-monitor
                                          switch 2022-fix
                                          npm install
                                          Once it is done, you should be able to use your existing configuration. Let me know if you encounter any problems.
                                            My fork of the module has been updated and the new code has been merged to the master branch. Let me know if you hit any issues with it.
                                            • 5 / 6
