    frameless mirror
    17 Posts 9 Posters 23.8k Views 8 Watching
    • BangeeB
      Bangee Module Developer
      I did it by my self.
      The glass is a 4mm two way mirror and the frame is aluminium 1.5 mm.
      and the complete mirror is about 5 cm thick
        PaulB
        @Bangee
        Your Mirror looks awesome. Which components did you used to built the Mirrorframe and furthermore, how did you manage that the mirror is fixed on the Display?
        Kind regards from Bayreuth, Germany.
        Paul B
        • BangeeB
          Hi @PaulB
          I’ve used an aluminium sheet, 1.5 mm thik. I made a sketch and went to a Sheet metal processing company.
          But the coast are very high. :-)
          The fixing is included in to the mirrorframe and its built in one pice of aluminium.
          Bangee
            PaulB
            @Bangee Your mirror looks so well, but I think I am going with a frame made out of wood for my first attempt. Nevertheless I am very interested in your mirror project, and still looking for a way to rebuild it with wood.
            • BangeeB
              Here is my latest project. I have integrated the PIR sensor in my the glass 😏
              binderthB A 2 Replies Last reply
              Reply Quote 5
              • binderthB
                binderth @Bangee
                @Bangee that Looks so great!
                I’m looking into planning my frame at the moment. How do you attach the Monitor to the mirror and how do you place it on the wall, could you please add some information/pictures on that?
                Thanks!
                • BangeeB
                  Hi @binderth
                  The monitor is put in the frame and hold by the glass and some lashes.
                  This frame very thin an built with 1.5mm aluminium.
                  The Weight ist only 1 kg.
                  I’ve used a 3mm 12% twoway mirror.
                  If someone is interested in this, I will produce some more pices.
                  PM me if you’re interested in it.
                    PindaPower
                    Looking great, hope you get the PIR working.
                    I will appreciate if you share you work(step) to your finishing mirror. Trying to upgrade my mirror with PIR sensor in the future. So your step/choice would help me later on.
                    • K
                      KrawallKurt
                      Wow… I was actually thinking of getting a 3% mirror. Will rethink that. What display are you using? Is it a 250cd/m² one?
                      • BangeeB
                        yes its a 250 cd/m2
                        • A
                          Atheose @Bangee
                          @Bangee Looks looks really great! I love how you integrated the PIR into the mirror itself.
                          What did you use to cut the hole? Was it difficult? Were you concerned about breaking the glass?
                          • BangeeB
                            I’ve ordered the mirror with the hole in it.
                            I don’t know how to do this by your selve :-)
                            • DæmonEyesD
                              DæmonEyes
                              Can you show how you built that case/frame for your frameless mirror? I would love to do a similar build, cause I am almost done with my own smart mirror, I finished everything - EXCEPT THE FRAME…been putting off what frame to get.
